Building Jubula and documentation [message #1146030] |
Sat, 19 October 2013 23:43 |
Egor Sukhanov Messages: 3 Registered: October 2013 |
Hello there!
It happened that the topic of my master thesis is going to be connected to Jubula.
Due to this fact, lately I'm attempting to build it from the source code, in order to get an idea how it works (debugging usually helps in this, right?).
Unfortunately, the main source of information I found was this brief guide: http://wiki.eclipse.org/Jubula/JubulaContribGuide
Following these steps, after I import projects from GIT to Eclipse, target platform is probably not read correctly by Eclipse - it shows me no locations included into each of the target platform definitions (although the target platform definitions are included in the Eclipse preferences) and as a result i get some thousands errors. Somehow was able to create target definition (generally by building project via maven and then copying all the downloaded bundles, using local folder as target platform for Eclipse).
Anyways, the point is, that after all these actions, I'm still not able to run testexec in debug mode. Generally, if I set no command line arguments, it works fine - shows me help in the console (list of possible parameters). But, if I include working command line arguments into debug configuration - I get an error. Trying to debug "org.eclipse.jubula.app.testexec" project to be precise.
This is the error log I get:
!SESSION 2013-10-20 01:23:20.777 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_22
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -application org.eclipse.jubula.app.cmd.launcher -project FinalProject -version 1.0 -testsuite Adding -server localhost -port 59999 -autid addrswing AddingSwing -datadir C:\dataresult -resultdir C:\dataresult -language en_US -dbscheme Default Embedded (H2) -dbuser sa -dbpw pause
Command-line arguments: -application org.eclipse.jubula.app.cmd.launcher -data J:\IDE\workspace\jubula_dev/../runtime-org.eclipse.jubula.app.cmd.launcher -dev file:J:/IDE/workspace/jubula_dev/.metadata/.plugins/org.eclipse.pde.core/org.eclipse.jubula.app.cmd.launcher/dev.properties -project FinalProject -version 1.0 -testsuite Adding -server localhost -port 59999 -autid addrswing AddingSwing -datadir C:\dataresult -resultdir C:\dataresult -language en_US -dbscheme Default Embedded (H2) -dbuser sa -dbpw pause
!ENTRY org.eclipse.osgi 4 0 2013-10-20 01:23:27.985
!MESSAGE An error occurred while automatically activating bundle org.eclipse.jubula.toolkit.common (352).
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.jubula.toolkit.common.PluginStarter for bundle org.eclipse.jubula.toolkit.common is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320)
at org.eclipse.jubula.app.testexec.TestexecClient.preRun(TestexecClient.java:62)
at org.eclipse.jubula.client.cmd.AbstractCmdlineClient.run(AbstractCmdlineClient.java:401)
at org.eclipse.jubula.client.cmd.AbstractLauncher.start(AbstractLauncher.java:26)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/ui/plugin/AbstractUIPlugin
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClassHoldingLock(ClasspathManager.java:632)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:614)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:568)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:492)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:465)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:165)
... 32 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2013-10-20 01:23:27.992
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/jubula/toolkit/common/exception/ToolkitPluginException
Looking forward to receive a feedback and thanks in advance for your help
Re: Building Jubula and documentation [message #1160092 is a reply to message #1149520] |
Tue, 29 October 2013 00:33 |
Dear Alexandra,
the problem is still in place. The only advice I found useful from mailing archive - that I have to build project via maven before running it in eclipse.
But it doesn't work. Tried different branches (indigo-sr1, helios, kepler) on different versions of Eclipse (Indigo/Helios/Kepler), but there is always a problem for maven with computing target platform.
E.g. in Eclipse Kepler with kepler git branch, upon running maven install i get the following message:
[INFO] Fetching org.eclipse.ui.workbench_3.104.0.v20130204-164612.jar.pack.gz from h_ttp://artfiles.org/eclipse.org//releases/juno/201303010900/plugins/ (1,71kB of 1,04MB at 0B/s)
[INFO] Fetching org.eclipse.ui.workbench_3.104.0.v20130204-164612.jar.pack.gz from h_ttp://artfiles.org/eclipse.org//releases/juno/201303010900/plugins/ (738,1kB of 1,04MB at 731,32kB/s)
[ERROR] Internal error: java.lang.RuntimeException: "Messages while trying children repositories.": ["Messages while trying children repositories.": ["": ["Retry another mirror": ["Unable to read repository at f_tp://eclipse.c3sl.ufpr.br/eclipse/releases/juno/201303010900/plugins/org.eclipse.emf.common_2.8.0.v20130125-0546.jar.pack.gz."], "Retry another mirror": ["Unable to read repository at h_ttp://mirror.selfnet.de/eclipse/releases/juno/201303010900/plugins/org.eclipse.ui_3.104.0.v20121024-145224.jar.pack.gz."]]]] -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: "Messages while trying children repositories.": ["Messages while trying children repositories.": ["": ["Retry another mirror": ["Unable to read repository at f_tp://eclipse.c3sl.ufpr.br/eclipse/releases/juno/201303010900/plugins/org.eclipse.emf.common_2.8.0.v20130125-0546.jar.pack.gz."], "Retry another mirror": ["Unable to read repository at h_ttp://mirror.selfnet.de/eclipse/releases/juno/201303010900/plugins/org.eclipse.ui_3.104.0.v20121024-145224.jar.pack.gz."]]]]
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:168)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
Caused by: java.lang.RuntimeException: "Messages while trying children repositories.": ["Messages while trying children repositories.": ["": ["Retry another mirror": ["Unable to read repository at f_tp://eclipse.c3sl.ufpr.br/eclipse/releases/juno/201303010900/plugins/org.eclipse.emf.common_2.8.0.v20130125-0546.jar.pack.gz."], "Retry another mirror": ["Unable to read repository at h_ttp://mirror.selfnet.de/eclipse/releases/juno/201303010900/plugins/org.eclipse.ui_3.104.0.v20121024-145224.jar.pack.gz."]]]]
at org.eclipse.tycho.p2.target.P2ArtifactDownloadTool.downloadArtifactsToLocalMavenRepository(P2ArtifactDownloadTool.java:59)
at org.eclipse.tycho.p2.target.TargetPlatformImpl.downloadArtifacts(TargetPlatformImpl.java:213)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveProject(P2ResolverImpl.java:128)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveProject(P2ResolverImpl.java:80)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.doResolvePlatform(P2TargetPlatformResolver.java:377)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.resolveDependencies(P2TargetPlatformResolver.java:354)
at org.eclipse.tycho.core.resolver.DefaultTychoDependencyResolver.resolveProject(DefaultTychoDependencyResolver.java:103)
at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:82)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:274)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
... 11 more
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] h_ttp://cwiki.apache.org/confluence/display/MAVEN/InternalErrorException
The error upon launching command line client in debug mode from Eclipse is different, but idea is the same - with no command line arguments it seems working fine, showing me help entries, but with working arguments - it shows me errors and not launching client.
I'm a bit desperate after trying different version of source code in different versions of Eclipse and playing around target platform. Can I get any feedback from developers on this forum or should I somehow write to mailing list?
FUDForum. Page generated in 0.03871 seconds
