Home » Language IDEs » ServerTools (WTP) » Re: %WTP_Tests in my menu
Re: %WTP_Tests in my menu [message #177311] |
Fri, 18 August 2006 10:56 |
Alain
You asked the same question on the WTP newsgroup. When posting to
multiple newsgroups, use a single cross posting not multiple separate
postings or you'll just create more work for more people who try to
answer the same question independently. I wonder what version you installed?
--== Alain ==-- wrote:
> I've installed Eclipse for the first time and i have some issue in the
> main men of the application.
> %WTP_Test is displayed instead of the real name/value for this menu item.
> where is the problem ?
> thanks a lot,
> Alain
Re: %WTP_Tests in my menu [message #177318 is a reply to message #177311] |
Fri, 18 August 2006 11:17 |
Originally posted by: nospam.noemail.com
Sorry Ed,
I was not sure were to post it.
I've install Eclipse SDK 3.2, UML2 20060803, PHP ide all in one 0.1.9
and CDT 3.1.0
Any idea ?
Al.
Ed Merks wrote:
> Alain
> installed?
>> Hi,
>> thanks a lot,
>> Alain
Re: %WTP_Tests in my menu [message #177348 is a reply to message #177318] |
Fri, 18 August 2006 12:09 |
Alain,
I know it won't come from Eclipse and UML2. And I would not expect it
to come from CDT nor PHP for that matter. And I'd be shocked if WTP
had such a glaring error. You'd need to search the plugin.xml of each
of your installed plugins to find out where this comes from (and that's
harder to do now that plugins are jarred). Normally this represents a
reference to a property in the corresponding plugin.properies file, so
showing this represents a missing property. Both the plugin.xml and the
plugin.properties will be in the root of the jarred plugins. (I don't
support running eclipse.exe -clean will clean up the problem?)
> Sorry Ed,
> and CDT 3.1.0
> Any idea ?
> Al.
> Ed Merks wrote:
>> Alain
>> installed?
>>> Hi,
>>> the main men of the application.
>>> item.
>>> thanks a lot,
>>> Alain
Re: %WTP_Tests in my menu [message #177365 is a reply to message #177348] |
Fri, 18 August 2006 12:34 |
Ed,
I've seen %WTP_Tests at only 1 place...in plugin.xml file.
Alain
Ed Merks wrote:
> Alain,
>> Sorry Ed,
>> and CDT 3.1.0
>> Any idea ?
>> Al.
>> Ed Merks wrote:
>>> Alain
>>> installed?
>>>> Hi,
>>>> item.
>>>> thanks a lot,
>>>> Alain
Re: %WTP_Tests in my menu [message #177373 is a reply to message #177365] |
Fri, 18 August 2006 12:37 |
the plugin.xml of 'org.eclipse.wst.common.tests.collector_1.1.0'
> Ed,
> Alain
> Ed Merks wrote:
>> Alain,
>> that's harder to do now that plugins are jarred). Normally this
>> represents a reference to a property in the corresponding
>> plugin.properies file, so showing this represents a missing property.
>> Both the plugin.xml and the plugin.properties will be in the root of
>> the jarred plugins. (I don't support running eclipse.exe -clean will
>>> Sorry Ed,
>>> and CDT 3.1.0
>>> Any idea ?
>>> Al.
>>> Ed Merks wrote:
>>>> Alain
>>>> separate postings or you'll just create more work for more people
>>>> who try to answer the same question independently. I wonder what
>>>>> Hi,
>>>>> item.
>>>>> thanks a lot,
>>>>> Alain
Re: %WTP_Tests in my menu [message #177578 is a reply to message #177373] |
Sat, 19 August 2006 22:07 |
--------------050909040608040808090700
Alain,
The plugins.properties appears to have the property:
org.eclipse.wst.common.tests.collector=org.eclipse.wst.commo n.tests.collector
suites=suites
Test_Collector=Test Collector
*WTP_Tests=WTP Tests*
Open=Open
You're sure this isn't a stale configuration problem solved by running
eclipse.exe -clean?
>> Ed,
>> Alain
>> Ed Merks wrote:
>>> Alain,
>>> it to come from CDT nor PHP for that matter. And I'd be shocked if
>>> WTP had such a glaring error. You'd need to search the plugin.xml
>>> of each of your installed plugins to find out where this comes from
>>> (and that's harder to do now that plugins are jarred). Normally
>>> this represents a reference to a property in the corresponding
>>> property. Both the plugin.xml and the plugin.properties will be in
>>> the root of the jarred plugins. (I don't support running
>>>> Sorry Ed,
>>>> 0.1.9 and CDT 3.1.0
>>>> Any idea ?
>>>> Al.
>>>> Ed Merks wrote:
>>>>> Alain
>>>>>> Hi,
>>>>>> in the main men of the application.
>>>>>> menu item.
>>>>>> thanks a lot,
>>>>>> Alain
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Alain,<br>
<br>
The plugins.properties appears to have the property:<br>
<blockquote> org.eclipse.wst.common.tests.collector=org.eclipse.wst.commo n.tests.collector <br>
suites=suites<br>
Test_Collector=Test Collector<br>
<b>WTP_Tests=WTP Tests</b><br>
Open=Open<br>
</blockquote>
eclipse.exe -clean?<br>
<br>
<br>
<blockquote cite="midec4ca2$4m4$2@utils.eclipse.org" type="cite">the
<br>
<br>
<br>
<blockquote type="cite">Ed,
<br>
<br>
<br>
<br>
Alain
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Alain,
<br>
<br>
the plugin.properties will be in the root of the jarred plugins. (I
don't support running eclipse.exe -clean will clean up the problem?)
<br>
<br>
<br>
<br>
<blockquote type="cite">Sorry Ed,
<br>
<br>
<br>
<br>
and CDT 3.1.0
<br>
<br>
Any idea ?
<br>
<br>
Al.
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
installed?
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
item.
<br>
<br>
<br>
<br>
thanks a lot,
<br>
Alain
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------050909040608040808090700--
Re: %WTP_Tests in my menu [message #177594 is a reply to message #177578] |
Sun, 20 August 2006 16:54 |
Ed,
I've tried with -clean, but nothing changed :-(
Al.
Ed Merks wrote:
> Alain,
> suites=suites
> Open=Open
> eclipse.exe -clean?
>>> Ed,
>>> Alain
>>> Ed Merks wrote:
>>>> Alain,
>>>>> Sorry Ed,
>>>>> 0.1.9 and CDT 3.1.0
>>>>> Any idea ?
>>>>> Al.
>>>>> Ed Merks wrote:
>>>>>> Alain
>>>>>>> Hi,
>>>>>>> menu item.
>>>>>>> thanks a lot,
>>>>>>> Alain
Re: %WTP_Tests in my menu [message #177611 is a reply to message #177594] |
Mon, 21 August 2006 11:07 |
Alain,
It doesn't even sound like you've intentionally installed WTP. I wonder
why what you installed would have installed WTP's tests as a side
effect? I'm not really sure what to suggest since that property
appears to have been there in the very first version in CVS. Is that
property present in the corresponding plugin.properties in your
installation? Perhaps try deleting the plugin or starting a clean
installation and keep track of where WTP is coming from. There should
be no need to install the tests and if you don't, you shouldn't see this
problem...
> Ed,
> Al.
> Ed Merks wrote:
>> Alain,
>> suites=suites
>> Open=Open
>> running eclipse.exe -clean?
>>>> Ed,
>>>> Alain
>>>> Ed Merks wrote:
>>>>> Alain,
>>>>> expect it to come from CDT nor PHP for that matter. And I'd be
>>>>> shocked if WTP had such a glaring error. You'd need to search the
>>>>> plugin.xml of each of your installed plugins to find out where
>>>>> this comes from (and that's harder to do now that plugins are
>>>>> jarred). Normally this represents a reference to a property in
>>>>> the corresponding plugin.properies file, so showing this
>>>>>> Sorry Ed,
>>>>>> 0.1.9 and CDT 3.1.0
>>>>>> Any idea ?
>>>>>> Al.
>>>>>> Ed Merks wrote:
>>>>>>> Alain
>>>>>>> to multiple newsgroups, use a single cross posting not multiple
>>>>>>> people who try to answer the same question independently. I
>>>>>>>> Hi,
>>>>>>>> menu item.
>>>>>>>> thanks a lot,
>>>>>>>> Alain
Current Time: Thu Sep 26 05:46:40 GMT 2024
Powered by FUDForum. Page generated in 0.04223 seconds
