Home » Language IDEs » ServerTools (WTP) » NoClassDefFoundError when deploying with
NoClassDefFoundError when deploying with [message #177287] |
Fri, 18 August 2006 01:27 |
Originally posted by: craig.haenterprises.com.au
I have a J2EE Project (lets call it XXX) that depends on three other
normal Java projects (A, B, and C). I go into my XXX's J2EE Module
Depencencies tab and select A, B, and C (as well as adding a couple of
other JAR libraries that those guys are dependent on).
When I click on publish, and check the .../tmp0/webapps/XXX/WEB-INF/lib
directory, I see that jars have been dynamically created for A/B/C and the
other dependent jars have been added. Love your work! I start Tomcat
(5.0) in Eclipse and everything looks OK at this point.
However, when I try to browse to a page in my Struts application, I get a
NoClassDefFoundError. In project XXX, I have a class called
XXXActionServlet that subclasses CCCActionServlet (which is in project C).
The error message is saying that it can't find CCCActionServlet - which I
can see has been successfully included in C.jar in WEB-INF/lib.
Any thoughts? I saw in other threads that if I add the dependent projects
to the J2EE Modules tab, then they should be removed from the Java Build
Path, but if I do that, then my project doesn't compile... and in any
case, the jars for the dependent projects seem to be successfully created
and published. Tomcat just doesn't seem to pick them up properly...
Do projects A,B,C have to be J2EE projects as well, or can they be Java
projects?
Running Eclipse 3.2 on Ubuntu Drake with WST 1.5.0.v200606092300. Any
advice would be much appreciated. Thanks a lot.
Craig
Re: NoClassDefFoundError when deploying with [message #177651 is a reply to message #177635] |
Tue, 22 August 2006 15:45 |
Originally posted by: avinh.verizon.net
Craig,
Sometimes the description of the error may not be accurate. For me, when
it said that my class was not found when it was right there in the classes
directory or in one of the jar files, I was confused just like you.
I suggest that you try migrating your application and its dependencies to
the Application Server's (Tomcat's) webapps directory and try running it
there instead. Tomcat may give you better/truer error msgs as far as which
class failed. In my case, it was some dependencies involving the Axis jar
and what other jar files that Axis needed (the version of Axis that came
with WTP 1.02 was older too, I think the latest for Axis is 1.3(?)). Once
I put those dependent jar files into the webapps/xxx/WEB-INF/lib
directory, the application was happy.
Good luck - Alan
Re: NoClassDefFoundError when deploying with [message #177820 is a reply to message #177287] |
Thu, 24 August 2006 19:51 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
Craig,
What you describe should work, implying there is a missing piece to this
puzzle. Is this still not working?
Larry
> the other dependent jars have been added. Love your work! I start
> Tomcat (5.0) in Eclipse and everything looks OK at this point.
> a NoClassDefFoundError. In project XXX, I have a class called
> C). The error message is saying that it can't find CCCActionServlet -
> which I can see has been successfully included in C.jar in WEB-INF/lib.
> projects to the J2EE Modules tab, then they should be removed from the
> Java Build Path, but if I do that, then my project doesn't compile...
> and in any case, the jars for the dependent projects seem to be
> successfully created and published. Tomcat just doesn't seem to pick
> them up properly...
> projects?
> Craig
Re: NoClassDefFoundError when deploying with [message #185316 is a reply to message #177820] |
Wed, 20 December 2006 17:24 |
Originally posted by: kenk.agitar.com
Craig,
Did you get resolution on your NoClassDefFoundError?
I've experienced a similar problem. When my tomcat instance tries to
load a struts class from a jar (and I've verified that the jar is in
WEB-INF/lib and that the class is in the jar), tomcat reports a
NoClassDefFoundError. I stepping through the tomcat classloading code
and noticed that it got an IOException when trying to get the manifest
of the jar file that contained the class in question. The IOException
reported that there was a bad header.
Manually unjarring and rejarring the jar file fixed the
Interestingly this happened on my windows install, but not my linux install.
Has anyone else seen this or does anyone know how to prevent it?
Ken
Larry Isaacs wrote:
> Craig,
> Cheers,
> Larry
>> .../tmp0/webapps/XXX/WEB-INF/lib directory, I see that jars have been
>> dynamically created for A/B/C and the other dependent jars have been
>> added. Love your work! I start Tomcat (5.0) in Eclipse and
>> get a NoClassDefFoundError. In project XXX, I have a class called
>> them up properly...
>> Java projects?
>> Craig
Re: NoClassDefFoundError when deploying with [message #185349 is a reply to message #185316] |
Wed, 20 December 2006 21:19 |
I found out what my problem was. The auto-generated manifest.mf file
had been incorrectly checked out by a windows client. The resulting
manifest had windows line-separators in it, which was causing tomcat to
get those IOExceptions when reading out the jar's manifest. Removing
the checked in manifest caused it to get properly regenerated and fixed
the problem.
--Ken
Ken Koster wrote:
> Craig,
> install.
> Ken
> Larry Isaacs wrote:
>> Craig,
>> this puzzle. Is this still not working?
>> Cheers,
>> Larry
>>> of other JAR libraries that those guys are dependent on).
>>> project C). The error message is saying that it can't find
>>> CCCActionServlet - which I can see has been successfully included in
>>> the Java Build Path, but if I do that, then my project doesn't
>>> compile... and in any case, the jars for the dependent projects seem
>>> to be successfully created and published. Tomcat just doesn't seem
>>> Java projects?
>>> Any advice would be much appreciated. Thanks a lot.
>>> Craig
Current Time: Fri Apr 26 21:51:18 GMT 2024
Powered by FUDForum. Page generated in 0.03358 seconds
