Re: Java was started but returned exit code=1 [message #1145785 is a reply to message #1144505] |
Sat, 19 October 2013 19:48 |
> C;\windows\system32\java.exe
> -Dosgi.requiredJavaVersion=1.6
> -Xms40m
> -Xmx512m
> -XX:MaxPermSize=256m
> -jar C:\Program
> Files\eclipse\\plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
> -os win32
> -ws win32
> -arch x86_64
> -showsplash C:\Program
> -launcher C:\Program Files\eclipse\eclipsec.exe
> -name Eclipsec
> --launcher.library C:\Program
> Files\eclipse\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20130807-1835\eclipse_1503.dll
> -startup C:\Program
> --launcher.appendVmargs
> -exitdata 15f8_54
> -product org.eclipse.epp.package.java.product
> -vm C:\windows\system32\java.exe
> -vmargs
> -Xms40m
> -Xmx512m
> -jar C:\Program
You should get a proper JRE and not use the one stuffed down under
C:\windows\system32. Make sure that the width of the JRE you choose
matches that of Eclipse (32-bit JRE with 32-bit Eclipse or 64-bit JRE
with 64-bit Eclipse).
Re: Java was started but returned exit code=1 [message #1385203 is a reply to message #1385185] |
Thu, 05 June 2014 00:30 |
On 06/04/2014 02:21 PM, arun kumar wrote:
> I have the same problem. When I click on MyEclipseBlue, I get the same
> exact error message in a Window. so far I have not seen any solution
> that works. Senior staff in my office suggested that I re-install
> Eclipse. There's got to be a better solution.
> Russell Bateman: what do you mean by get a proper JRE? I'm a new Java
> Developer. So please elaborate your statement.
As Eric suggests, you should take this up in a MyEclipse forum. No
matter, the problem is very likely that you do not have a JDK downloaded
from, for example, Sun. Go to java.sun.com, click Downloads, Popular
Downloads, Downloads for Developers, etc. and download the appropriate
copy of the Java 7 developer kit for your OS/hardware.
FUDForum. Page generated in 0.08184 seconds
