Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #17499 is a reply to message #16728] |
Sat, 22 November 2008 19:14 |
Originally posted by: ekkehard.gentz-software.de
Vel schrieb:
> Ekke, Are you planning to show examples of Riena UI too? I do RCP
> applications and an wondering if someone in this group is going to talk
> UI also.
yes !
But I'm using Riena UI only partly - not the strict UI - only Views with
Ridgets / Markers / Validation in a RCP app communicating with the
server thru Riena Remote Services and also using Riena
ObjectTransactions to transfer deltas of changed entity attributes only
....and we just started a subproject (redView - Riena EMF Dynamic View)
where we generate the Riena Views and create the View dynamically
....please expect some weeks until Client - UI - Examples will come
and before you ask: at the moment there's no source code published -
but will come soon (Open Source EPL)
ekke
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #17620 is a reply to message #17606] |
Fri, 28 November 2008 10:24 |
Christian Campo Messages: 597 Registered: July 2009 |
Vel schrieb:
> Sure Christian.
> I am a UI fan. I love colors and the arrangements of controls in
> Eclipse. I never bothered to open Eclipse source code until I started
> building a relatively full-fledged application an year back. o.e.pde.ui
> was my target. I still refer it for better usage of JFace viewers.
> Coming to Firefox themes, I am sure you will be using Firefox and
> Thunderbird. Both these applications have themes that can be downloaded
> from mozilla.com. As you download a theme and install, the new theme
> plugs seamlessly into the application.
> I read about Riena themes and am going to try it. I want to explore if
> this possible in the final application. We change the editor font in
> Preferences. In a similar, can we give the user a way to choose a
> pre-packaged Riena theme using a preference? Your EclipseCon ppt shows
> two examples for new RCP appearance. Since the possibilities are
> endless, I asked if theme can be put into the application at runtime. Am
> I asking for more :) ?
You can plugin Themes at runtime but only at starttime at this point in time I believe. But you can
certainly switch Thema without changing your application code.
However the EclipseCon presentations only contains UI-Visions which we had at the that time which was
based on a pre-Riena application based on Swing. Swing quite naturally comes with Themes.
Riena now also has Themes for SWT and you can see a good example for them in this presentation
http://www.eclipsecon.org/summiteurope2008/sessions?id=39 (slide 24) so that is changing color, font, moving
logos navigation and things like that without touching or recompiling the code just by supplying a differnt
system property at start.
Beyond that you can also modify the "Look". We have yet not alternate Look implemented but that would include
having different renders for everything navigation (on the left) like ModuleGroup, Module, Submodule and also for the
top SubApplication switcher and top bar.
any more feedback questions, let me know
christian
p.s. the riena.example.app has two launch files for the different themes
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #577066 is a reply to message #16728] |
> UI also.
yes !
ekke
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #577275 is a reply to message #17606] |
Vel schrieb:
> Sure Christian.
christian
FUDForum. Page generated in 0.05488 seconds
