Eclipse problem [message #1142077] |
Thu, 17 October 2013 07:35 |
Hi, im new on Eclipse forums so Im really sorry to post this here because i cant find the right page, well this is my problem, Eclipse worked really good for me, but now if i start Eclipse and select my default Workspace or any others, i try to make a project i get an error:
'Marketplace DND Initialization' has encountered a problem.
An internal error has occured
[ OK ] [ << Details ]
Details:
Cannot initialize Drop
And after i click Ok it gives me this:
An SWT error has occured
You are recommended to exit the workbench
Subsequent errors may happen and may terminate the workbench without warning.
See the .log file for more details
Do you want to exit the Workbench?
.log file:
Quote:!SESSION 2013-07-08 16:40:34.925 -----------------------------------------------
eclipse.buildId=4.3.0.I20130605-2000
java.version=1.7.0_21
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=nl_NL
Framework arguments: -product org.eclipse.epp.package.standard.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.standard.product
!ENTRY org.eclipse.egit.ui 2 0 2013-07-08 16:41:20.086
!MESSAGE Warning: EGit couldn't detect the installation path "gitPrefix" of native Git. Hence EGit can't respect system level
Git settings which might be configured in ${gitPrefix}/etc/gitconfig under the native Git installation directory.
The most important of these settings is core.autocrlf. Git for Windows by default sets this parameter to true in
this system level configuration. The Git installation location can be configured on the
Team > Git > Configuration preference page's 'System Settings' tab.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\Luc'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
!SESSION 2013-10-17 12:02:12.559 -----------------------------------------------
eclipse.buildId=4.3.0.M20130911-1000
java.version=1.7.0_40
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-10-17 12:02:40.590
!MESSAGE Unable to create class 'org.eclipse.ui.internal.e4.compatibility.CompatibilityView' from bundle '234'
!STACK 0
org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTError: Cannot initialize Drop
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:526)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:511)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:61)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1096)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:61)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:676)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1042)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Caused by: org.eclipse.swt.SWTError: Cannot initialize Drop
at org.eclipse.swt.dnd.DND.error(DND.java:266)
at org.eclipse.swt.dnd.DND.error(DND.java:227)
at org.eclipse.swt.dnd.DropTarget.<init>(DropTarget.java:144)
at org.eclipse.jface.viewers.StructuredViewer.addDropSupport(StructuredViewer.java:567)
at org.eclipse.jdt.internal.ui.dnd.JdtViewerDropSupport.start(JdtViewerDropSupport.java:65)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.initDrop(PackageExplorerPart.java:825)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.initDragAndDrop(PackageExplorerPart.java:815)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.createPartControl(PackageExplorerPart.java:487)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:142)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:174)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:323)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 98 more
!ENTRY org.eclipse.equinox.event 4 0 2013-10-17 12:02:40.661
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/UIElement/widget/SET] to handler org.eclipse.e4.ui.services.internal.events.UIEventHandler@6722eb
!STACK 0
at org.eclipse.ui.internal.WorkbenchPage.installAreaDropSupport(WorkbenchPage.java:2782)
at org.eclipse.ui.internal.WorkbenchPage.access$5(WorkbenchPage.java:2777)
at org.eclipse.ui.internal.WorkbenchPage$3.handleEvent(WorkbenchPage.java:824)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4688)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setWidget(UIElementImpl.java:248)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.bindWidget(SWTPartRenderer.java:123)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:951)
!ENTRY org.eclipse.ui 4 4 2013-10-17 12:03:00.093
!MESSAGE An internal error has occurred.
!STACK 0
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceDropAdapter.installDropTarget(MarketplaceDropAdapter.java:59)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceDropAdapter$1.runInUIThread(MarketplaceDropAdapter.java:48)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4145)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3762)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:826)
at org.eclipse.jface.window.Window.open(Window.java:802)
at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:135)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
!ENTRY org.eclipse.egit.ui 2 0 2013-10-17 12:03:06.748
!ENTRY org.eclipse.egit.ui 2 0 2013-10-17 12:03:06.749
!ENTRY org.eclipse.ui 4 0 2013-10-17 12:03:06.750
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4397)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
Caused by: java.lang.NullPointerException
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.selectReveal(PackageExplorerPart.java:846)
at org.eclipse.ui.wizards.newresource.BasicNewResourceWizard$1.run(BasicNewResourceWizard.java:175)
... 23 more
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2013-10-17 12:03:10.704
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:386)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:132)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:76)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:70)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:171)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.clearContext(PartRenderingEngine.java:940)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:920)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$3(PartRenderingEngine.java:828)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$8.run(PartRenderingEngine.java:823)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.removeGui(PartRenderingEngine.java:808)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.disposeWidget(ElementReferenceRenderer.java:109)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:899)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:860)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:853)
at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1606)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:1239)
at org.eclipse.ui.internal.WorkbenchWindow.access$14(WorkbenchWindow.java:1206)
at org.eclipse.ui.internal.WorkbenchWindow$10.run(WorkbenchWindow.java:1269)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1267)
at org.eclipse.ui.internal.Workbench$14.run(Workbench.java:1096)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1079)
at org.eclipse.ui.internal.Workbench.access$19(Workbench.java:1024)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1327)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1325)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1298)
at org.eclipse.ui.internal.handlers.QuitHandler.execute(QuitHandler.java:36)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:420)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.disposeSite(CompatibilityView.java:267)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.internalDisposeSite(CompatibilityPart.java:405)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.invalidate(CompatibilityPart.java:233)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.destroy(CompatibilityPart.java:392)
... 114 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-10-17 12:03:10.707
!MESSAGE Exception occurred while unrendering: org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl@6321dc (elementId: org.eclipse.jdt.ui.PackageExplorer, tags: [View, categoryTag:Java], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.e4.compatibility.CompatibilityView, object: null, context: null, variables: [], label: Package Explorer, iconURI: platform:/plugin/org.eclipse.jdt.ui/icons/full/eview16/package.gif, tooltip: Workspace, dirty: false, closeable: true, description: null)
!STACK 0
... 114 more
!SESSION 2013-10-17 13:21:43.474 -----------------------------------------------
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-10-17 13:22:04.966
!STACK 0
at sun.reflect.DelegatingMethodAccessorImpl.in
FUDForum. Page generated in 0.08397 seconds
