Re: Oracle DB setup with multiple users. [message #1140241 is a reply to message #1139380] |
Wed, 16 October 2013 08:11 |
Hi Todd,
your IT department is right: the easiest way is to use one account and share it amongst all team members. There are ways to use different accounts and work on one schema, but we don't support this any longer in the tool since it used to confuse the hell out of our users.
Jubula does take care of several people working on the same project. There are items which can only be changed by one person at a time. As a rule of thumb you can say that everything that is modified in an editor is locked against changes by other users. There are a few more items which are locked if changed, but you will get an info dialog telling you that someone else is working on this aspect of your tests.
- Achim
FUDForum. Page generated in 0.03259 seconds
