Home » Archived » BIRT » How to fit to whole - export in pdf format(How to fit to whole - export in pdf format)
How to fit to whole - export in pdf format [message #1138158] Mon, 14 October 2013 20:47 Go to next message
Hi for all,
I want to export a report to pdf format and fit it to whole page. Using the birt web viewer I can do it using the tool bar. The generated report has only two pages. Now I'm trying export to pdf using the parameters in the url but the pdf generated is not fitting to page like using the toolbar resource. The file generated is showing 3 pages. I'm using the __format=PDF and __fittopage=true parameters.
Sammy
Re: How to fit to whole - export in pdf format [message #1143060 is a reply to message #1138158] Thu, 17 October 2013 21:28 Go to previous message
Any way you can show me what you mean by attaching a sample report that I can run that shows the issue?
Previous Topic:HTML content not rendered in BIRT. Throws exception
Next Topic:What is the difference between table column binding and data element column binding
Current Time: Wed Sep 24 13:59:28 EDT 2025
Powered by FUDForum. Page generated in 0.02575 seconds
