Home » Archived » BIRT » Multiple datasets for a chart
Multiple datasets for a chart [message #175133] Tue, 04 July 2006 13:49 Go to next message
Originally posted by: hjm.holos.pt
Hi..
I need to make a chart with two series. One with the real values, and
another with the real data. My problem is that some values are on a
dataset and anothers are in a diferent one.
Is it possible to use more than 1 dataset in a chart, or how can i do to
make a combination of all values?
Hugo
Re: Multiple datasets for a chart [message #175415 is a reply to message #175133] Wed, 05 July 2006 16:39 Go to previous message
Have you tried using a Joined Data Set?
If the two Data Sets can be joined using an inner or outer join
this should work.
Jason
<hjm@holos.pt> wrote in message
news:15c604bc7cd5fc6b299fa28a85562ea4$1@www.eclipse.org...
> Hi..
> Thanks
> Hugo
Previous Topic:JdbcBridge
Next Topic:Has birt-report-designer-all-in-one-2_1_0.zip been build correctly?
Current Time: Sun Nov 09 19:23:16 EST 2025
Powered by FUDForum. Page generated in 0.03057 seconds
