Home » Modeling » TMF (Xtext) » Appending notifiyObservers call to a XBlockExpression using jvmInferrer(We are creating model objects using a jvmInferrer and they extend Observable. In case a model's method cause side effects, we'd like to notify it's observers adding method call to method's body)
Appending notifiyObservers call to a XBlockExpression using jvmInferrer [message #1137595] Mon, 14 October 2013 15:56 Go to next message
Miguel Carboni is currently offline Miguel CarboniFriend
Hi all!
We are creating model objects using a jvmInferrer and they extend Observable. In case a model's method cause side effects, we'd like to notify it's observers adding method call to method's body.
Grammar look's something like this:
Entity:
       features+=Feature*
Feature:
 Property | Message;
Property:
  name=ValidID ':' type=JvmTypeReference ('=' value=XExpression)?;
Message:
  'op' name=ValidID
    '('(params+=FullJvmFormalParameter
      (',' params+=FullJvmFormalParameter)*)?')'
    body=XBlockExpression;
Then, we have an jvm inferrer very similar to the one in the example but with a little tunning:
	jvmGenericType.superTypes.add(element.newTypeRef(typeof(Observable)))
		for (feature : element.features) {
			switch feature {
				Message: {
					if (feature.body.hasSideEffects) {
						// add setHasChanged() and notifyObservers() calls to feature body
					members += feature.toMethod(feature.name, feature.type) [
						documentation = feature.documentation
						for (p : feature.params) {
							parameters += p.toParameter(p.name, p.parameterType)
						body = feature.body
I'd like to add this.setHasChanged() and this.notifyObservers() at method body's end.
I can't find a proper way.
Any help?
Best regards and thanks in advance!
Miguel
Re: Appending notifiyObservers call to a XBlockExpression using jvmInferrer [message #1137681 is a reply to message #1137595] Mon, 14 October 2013 17:09 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi this is currently not possible. You might infer two methods
instead: one that takes the body from the model and another that
calls this method and the notification stuff with a body written as
string
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Twitter : @chrdietrich
Re: Appending notifiyObservers call to a XBlockExpression using jvmInferrer [message #1138169 is a reply to message #1137681] Tue, 15 October 2013 01:00 Go to previous message
Thanks for the quick answer. It worked.
Miguel
Previous Topic:Strip comments during serialization?
Next Topic:platform:/resource when projects sit outside the workspace?
Current Time: Fri Apr 26 15:00:00 GMT 2024
Powered by FUDForum. Page generated in 0.03584 seconds
