Re: EngineException Error [message #1137122 is a reply to message #1137082] |
Mon, 14 October 2013 09:17 |
Hwang Juyeon Messages: 3 Registered: May 2013 |
Junior Member |
Thank you for advice.
But H2 JDBC is already add in '<Eclipse home>/plugins/org.eclipse.birt.report.data.oda.jdbc_<version>/drivers'.
Error message is..
The following items have errors:
org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details:
Failed to prepare the query execution for the data set: SYSTEM
Failed to prepare the following query for the data set type (org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet).
[select ID as SYSTEM_ID
, ALIAS as SYSTEM_ALIAS
, DESCRIPTION as SYSTEM_DESCRIPTION
from CONFIG_SYSTEM
where ID = ?]
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Error preparing SQL statement.
SQL error #1:Table "CONFIG_SYSTEM" not found; SQL statement:
from CONFIG_SYSTEM
where ID = ? [42102-157]
org.h2.jdbc.JdbcSQLException: Table "CONFIG_SYSTEM" not found; SQL statement:
from CONFIG_SYSTEM
where ID = ? [42102-157] (Element ID:4403)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1237)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1216)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.DataItemExecutor.execute(DataItemExecutor.java:75)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:937)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:386)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
at org.eclipse.jetty.server.Server.handle(Server.java:350)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
at java.lang.Thread.run(Unknown Source)
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred during processing. Please see the following message for details:
from CONFIG_SYSTEM
where ID = ?]
from CONFIG_SYSTEM
from CONFIG_SYSTEM
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:644)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:158)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:267)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1939)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
... 100 more
Caused by: org.eclipse.birt.data.engine.core.DataException: Failed to prepare the query execution for the data set: SYSTEM
from CONFIG_SYSTEM
where ID = ?]
from CONFIG_SYSTEM
from CONFIG_SYSTEM
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:345)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:455)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:145)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:624)
... 104 more
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Failed to prepare the following query for the data set type (org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet).
from CONFIG_SYSTEM
where ID = ?]
from CONFIG_SYSTEM
from CONFIG_SYSTEM
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:54)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareOdaQuery(Connection.java:298)
at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareStatement(Connection.java:197)
at org.eclipse.birt.data.engine.executor.DataSource.prepareStatement(DataSource.java:302)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepare(DataSourceQuery.java:281)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:442)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:341)
... 109 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: Error preparing SQL statement.
from CONFIG_SYSTEM
from CONFIG_SYSTEM
at org.eclipse.birt.report.data.oda.jdbc.Statement.prepare(Statement.java:135)
at org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.prepare(BidiStatement.java:52)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doPrepare(OdaQuery.java:229)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.prepare(OdaQuery.java:186)
at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareOdaQuery(Connection.java:290)
... 114 more
Caused by: org.h2.jdbc.JdbcSQLException: Table "CONFIG_SYSTEM" not found; SQL statement:
from CONFIG_SYSTEM
at org.h2.message.DbException.getJdbcSQLException(DbException.java:327)
at org.h2.message.DbException.get(DbException.java:167)
at org.h2.message.DbException.get(DbException.java:144)
at org.h2.command.Parser.readTableOrView(Parser.java:4729)
at org.h2.command.Parser.readTableFilter(Parser.java:1071)
at org.h2.command.Parser.parseSelectSimpleFromPart(Parser.java:1675)
at org.h2.command.Parser.parseSelectSimple(Parser.java:1782)
at org.h2.command.Parser.parseSelectSub(Parser.java:1669)
at org.h2.command.Parser.parseSelectUnion(Parser.java:1514)
at org.h2.command.Parser.parseSelect(Parser.java:1502)
at org.h2.command.Parser.parsePrepared(Parser.java:405)
at org.h2.command.Parser.parse(Parser.java:279)
at org.h2.command.Parser.parse(Parser.java:251)
at org.h2.command.Parser.prepareCommand(Parser.java:217)
at org.h2.engine.Session.prepareLocal(Session.java:415)
at org.h2.engine.Session.prepareCommand(Session.java:364)
at org.h2.jdbc.JdbcConnection.prepareCommand(JdbcConnection.java:1119)
at org.h2.jdbc.JdbcPreparedStatement.<init>(JdbcPreparedStatement.java:71)
at org.h2.jdbc.JdbcConnection.prepareStatement(JdbcConnection.java:267)
at org.eclipse.birt.report.data.oda.jdbc.Statement.prepare(Statement.java:131)
... 118 more
[Updated on: Mon, 14 October 2013 09:21] Report message to a moderator
FUDForum. Page generated in 0.03204 seconds
