Re: Reusing EMF.Edit property sheet [message #1135028 is a reply to message #1134115] |
Sat, 12 October 2013 23:26 |
Dénes Harmath Messages: 157 Registered: July 2009 |
Hi Vladimir,
thanks for your reply! I also tried EEF, but when I Initialize EEF models from my genmodel, the generation throws an exception, which is kind of a showstopper issue, that's why I want to go with the good old EMF.Edit-generated code.
at org.eclipse.emf.eef.codegen.core.initializer.ViewTransformer.eStructuralFeature2ViewElement(ViewTransformer.java:156)
at org.eclipse.emf.eef.codegen.core.initializer.ViewTransformer.genClass2Views(ViewTransformer.java:108)
at org.eclipse.emf.eef.codegen.core.initializer.ViewTransformer.genPackage2ViewsRepository(ViewTransformer.java:85)
at org.eclipse.emf.eef.codegen.core.initializer.PropertiesInitializer.initialize(PropertiesInitializer.java:103)
at org.eclipse.emf.eef.codegen.ui.initializer.actions.InitializeEEFModelsAction.run(InitializeEEFModelsAction.java:77)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4166)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1489)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1474)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1279)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4012)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:487)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
[Updated on: Sat, 12 October 2013 23:26] Report message to a moderator
FUDForum. Page generated in 0.06381 seconds
