Home » Eclipse Projects » Eclipse Scout » Exception with anchors in HtmlField
Exception with anchors in HtmlField [message #1133210] Fri, 11 October 2013 17:44 Go to next message
Uli B is currently offline Uli BFriend
Member
I have an HtmlField displaying html containing local links of the form
<A href="#anchor">
<A name="anchor">
When clicking on the link I get
       at org.eclipse.scout.rt.client.ui.form.fields.htmlfield.AbstractHtmlField.doHyperlinkAction(AbstractHtmlField.java:128)
       at org.eclipse.scout.rt.client.ui.form.fields.htmlfield.AbstractHtmlField$P_UIFacade.fireHyperlinkActionFromUI(AbstractHtmlField.java:239)
       at org.eclipse.scout.rt.ui.swing.form.fields.htmlfield.SwingScoutHtmlField$2.run(SwingScoutHtmlField.java:286)
       at org.eclipse.scout.rt.ui.swing.concurrency.SwingScoutSynchronizer$1.runVoid(SwingScoutSynchronizer.java:66)
       at org.eclipse.scout.rt.client.ClientJob.runStatus(ClientJob.java:189)
       at org.eclipse.scout.rt.client.ClientJob.runTransactionWrapper(ClientJob.java:172)
       at org.eclipse.scout.rt.client.ClientJob.run(ClientJob.java:159)
       at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
In standard browsers everything works perfect. What can I do to get this work in the HtmlField?
Re: Exception with anchors in HtmlField [message #1197158 is a reply to message #1133210] Tue, 19 November 2013 19:43 Go to previous message
Lukas Huser is currently offline Lukas HuserFriend
Member
Hi Uli
It seems that your use case is simply not implemented for the Swing UI Sad (I verified that it works with the SWT and RAP clients.)
The current implementation for the Swing UI always assumes a valid URL as the link target, ignoring the possibility of local anchors. It should be technically feasible to implement this feature (scrolling to a local anchor) also for the Swing client.
Would you mind opening a Bugzilla ticket?
Lukas
Previous Topic:Switch Tabs programatically
Next Topic:Table in Table Column
Current Time: Sat Apr 27 02:37:21 GMT 2024
Powered by FUDForum. Page generated in 0.03042 seconds
