Home » Language IDEs » C / C++ IDE (CDT) » unmanaged scons
unmanaged scons [message #173347] Thu, 20 July 2006 11:35 Go to next message
Originally posted by: jan_hoeft.gmx.de
I try to use scons instead of make. I changed everything on the "make
builder" tab. I've even created a new build target. Everything looks
fine to me.
When i select "Build Project" nothing happens. Not even an error on the
console comes up. Sometimes, I wasn't able to figure out when, it does a
make clean(scons -c). Sometimes bressing build the indexer starts, no
errors, no build. Why?
Got eclipse 3.1.2 and cdt 3.0.2.
Cheers
Jan
Re: unmanaged scons [message #173363 is a reply to message #173347] Thu, 20 July 2006 16:59 Go to previous messageGo to next message
Originally posted by: asdf.dd.dd
> I've even created a new build target. Everything looks fine to me.
How excactly do you do that ?
Have you tried to double click the build target in the window on the left ?
tpt
Re: unmanaged scons [message #173897 is a reply to message #173347] Thu, 27 July 2006 05:33 Go to previous message
I solved my own problem. Since there is no "make clean all" equivalent
using scons, I unchecked the "rebuild" checkbox. This has been the
error. Checking it again leaving the edit box behind empty everything
worked fine.
Cheers
Jan
> fine to me.
> Cheers
> Jan
Previous Topic:Displaying only a section of code
Next Topic:CDT with Microsoft compiler
Current Time: Thu Sep 25 12:58:04 EDT 2025
Powered by FUDForum. Page generated in 0.03236 seconds
