Re: GMF Diagram performance [message #1130145 is a reply to message #1130117] |
Wed, 09 October 2013 08:55 |
Ed Merks Messages: 33141 Registered: July 2009 |
Martin,
Comments below.
On 09/10/2013 10:37 AM, Martin Jacob wrote:
> I have a diagram generated from ecore model doing all the steps
> necessary as on the GMF Dashboard. The model size is typical 3,000
> nodes and 6,000 connections but larger models could include 100,000
> nodes and 200,000 connections. The smaller model is displayed in a
> reasonable time. But the large model takes ages.
> The application setup is as follow. The model is build in C++ code and
> used for fast calculations. From the C++ model the appropriate XMI
> file is generated. This XMI file is the input for the GMF Diagram.
> Recently a JNI wrapper from the C++ model to Java exists.
> To overcome the performance issues I looking for a way to skip the XMI
> file and use the JNI wrapper.
Do you know this to be a performance bottleneck based on measurements?
> I know by using GEF its possible to use an own model. This is what we
> did but the performance for the large model is not much better as
> loading the XMI file into the GMF diagram. The only time saving is
> because the XMI file is not needed.
Yes, and how significant is that?
> I tried already to reduce features in the GMF diagram as we only need
> to display the model and modifications are reduced to move node and
> bend connections but not adding or deleting model elements. Did not
> have luck with that one as well to get a satisfying performance.
Have you done any measurements with a profiler? Often the killer for
performance nasty O(n^2) algorithms and perhaps you can specialize parts
of the framework to avoid that.
> Does any one have similar experience and found a solution to quickly
> display a diagram?
> May be GEF is not the right framework to use? Zest seams to be not
> much faster as I tried this as well.
Laying out 100,000 nodes with 200,000 connections might well just be an
inherently expensive operation...
> any hint are highly appreciated, Martin
Maybe someone else has some experience...
Ed Merks
Re: GMF Diagram performance [message #1130158 is a reply to message #1130145] |
Wed, 09 October 2013 09:14 |
Martin Jacob Messages: 191 Registered: July 2009 |
Comments below
schrieb Ed Merks, Am 09.10.2013 10:55:
> Martin,
> Comments below.
>> Hi,
>> I have a diagram generated from ecore model doing all the steps necessary as on the GMF Dashboard.
>> The model size is typical 3,000 nodes and 6,000 connections but larger models could include
>> 100,000 nodes and 200,000 connections. The smaller model is displayed in a reasonable time. But
>> The application setup is as follow. The model is build in C++ code and used for fast calculations.
>> From the C++ model the appropriate XMI file is generated. This XMI file is the input for the GMF
>> Diagram. Recently a JNI wrapper from the C++ model to Java exists.
>> To overcome the performance issues I looking for a way to skip the XMI file and use the JNI wrapper.
The time saved is the generation of the XMI file itself. As this takes minutes.
>> I know by using GEF its possible to use an own model. This is what we did but the performance for
>> the large model is not much better as loading the XMI file into the GMF diagram. The only time
>> saving is because the XMI file is not needed.
>> I tried already to reduce features in the GMF diagram as we only need to display the model and
>> modifications are reduced to move node and bend connections but not adding or deleting model
>> elements. Did not have luck with that one as well to get a satisfying performance.
> Have you done any measurements with a profiler? Often the killer for performance nasty O(n^2)
> algorithms and perhaps you can specialize parts of the framework to avoid that.
I am using Java Monitor but could not figure out how to get the most time consuming code sequence.
What profiler you recommend?
>> Does any one have similar experience and found a solution to quickly display a diagram?
>> May be GEF is not the right framework to use? Zest seams to be not much faster as I tried this as
>> well.
> Laying out 100,000 nodes with 200,000 connections might well just be an inherently expensive
> operation...
The code to calculate the nodes coordinates is done within a second or two. So this is not the issue.
Re: GMF Diagram performance [message #1130177 is a reply to message #1130158] |
Wed, 09 October 2013 09:32 |
Martin,
Comments below.
On 09/10/2013 11:14 AM, Martin Jacob wrote:
> Comments below
>> Martin,
>> Comments below.
>>> Hi,
> minutes.
That's very long! This is all in the C++ code I assume...
>> avoid that.
> time consuming code sequence. What profiler you recommend?
I use YourKit, which is excellent, but not cheap, though they do provide
licenses for open source development if you publicly acknowledge using
their tool...
>>> display a diagram?
>>> well.
>> operation...
That's reassuring...
Ed Merks
FUDForum. Page generated in 0.03326 seconds
