Re: How Install Spring in Eclipse 3.7 [message #1129349 is a reply to message #1129012] |
Tue, 08 October 2013 14:38 |
On 10/8/2013 1:52 AM, Missing name Mising name wrote:
> Hello.
> I need to work with Spring in Eclipse. I have install the Spring IDE
> http://marketplace.eclipse.org/content/spring-ide#.UlOvFIa9Vn1 however
> when I have create a Spring project, Eclipse not found de libraries I am
> getting a import error.
> For example, it does not found the next libraries:
> import org.springframework.context.ApplicationContext;
> import org.springframework.context.support. ClassPathXmlApplicationContext
> What is the problem? I need install another plugin? do I need add to the
> classpath the libraries?
> Thanks you.
> Jose
You might get more and better help if you consult the Spring community
which built their IDE atop Eclipse (and not the reverse). If you ask
here, you're taking the chance that someone might happen to know whereas
in a Spring forum, they almost surely know.
Best of luck.
FUDForum. Page generated in 0.08805 seconds
