Home » Eclipse Projects » e(fx)clipse » e4 dynamic menu contributions not work?
e4 dynamic menu contributions not work? [message #1128400] Mon, 07 October 2013 12:51 Go to next message
I tried to add dynamic menu items following this article:
www.descher.at/descher-vu/2012/12/dynamic-menu-contributions
Hear is my code to add menu:
public class TestMenuHandler {
    @AboutToShow
    public void aboutToShow(List<MMenuElement> items) {
        for(int i=0 ; i< 5; i++) {
            MDirectMenuItem menuItem = MMenuFactory.INSTANCE.createDirectMenuItem();
            menuItem.setLabel("Test  menu " + i);
            menuItem.setElementId("test.dynamicmenucontribution"+ i);
            menuItem.setContributorURI("platform:/plugin/testApp.menu.test");
            menuItem.setContributionURI("bundleclass://testApp/test.TestHandler");
            items.add(menuItem);
There is nothing added to the menu. No error message.
I added DynamicMenuContribution to the menu and I tried from SWT e4 application and same code worked.
And this is handler for the menu, but I don't think it is matter at this stage:
public class TestHandler {
    @Execute
    public void canExecute(MDirectMenuItem menuItem) {
        System.out.println(menuItem.getElementId());
Thanks in advance
[Updated on: Mon, 07 October 2013 13:17] by Moderator
Re: e4 dynamic menu contributions not work? [message #1128462 is a reply to message #1128400] Mon, 07 October 2013 14:19 Go to previous messageGo to next message
So against which target-platform do you work? Is it
http://download.eclipse.org/efxclipse/runtime-nightly/site/ there it
should work.
Unfortunately we are currently not honoring the way it works in SWT so
I've filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=418850
Tom
> @AboutToShow
> stage:
> @Execute
> Thanks in advance
Re: e4 dynamic menu contributions not work? [message #1128488 is a reply to message #1128462] Mon, 07 October 2013 14:58 Go to previous messageGo to next message
I was using a week old runtime but just update to the latest and it seems working but found two differences. I guess these are the ones you already mentioned as bug but just in case:
1. It only works when there is at least one other menu item. Not work if the menu has only DynamicMenuContribution.
2. @AboutToShow method is called every time access the menu - ends up multiple sets of menus.
Thanks a lot for very fast replay. Wow, it is almost like real time.
Re: e4 dynamic menu contributions not work? [message #1128514 is a reply to message #1128488] Mon, 07 October 2013 15:37 Go to previous messageGo to next message
sounds interesting - need to look at it
yep - fixed with in git and i've started a new build (should be done in
a about 15 minutes). i'll look into your first comment.
Tom
Re: e4 dynamic menu contributions not work? [message #1128540 is a reply to message #1128514] Mon, 07 October 2013 16:13 Go to previous messageGo to next message
Wow. Already. Yes it worked. Great !!! I used work around - use flag to check menus are added - but obviously it is much better this way. Thanks
Re: e4 dynamic menu contributions not work? [message #1128546 is a reply to message #1128514] Mon, 07 October 2013 16:20 Go to previous messageGo to next message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=418867 which fixed in
git, next buil is on its way
Tom
Re: e4 dynamic menu contributions not work? [message #1128565 is a reply to message #1128546] Mon, 07 October 2013 16:42 Go to previous messageGo to next message
Amazing! Yes it is fixed now with latest build. Thanks.
[Updated on: Mon, 07 October 2013 16:43] by Moderator
Re: e4 dynamic menu contributions not work? [message #1128743 is a reply to message #1128565] Mon, 07 October 2013 21:04 Go to previous messageGo to next message
Hi Tom,
Sorry to bothering you again but it seems it stopped working. I'm not 100% sure but I think I saw it working some time today (with one of today's build) but not anymore. I confirmed with your testcase application.
The problem is:
When accessing (top) menu ("M1") with dynamic menu contributions, it prints error message like this and clicking dynamic menu (Test menu 0 ~5) doesn't do anything:
"org.eclipse.fx.ui.workbench.renderers.base.BaseItemRenderer getContributionObject
SEVERE: No contribution uri defined"
By the way I had to commented out @CanExecute from DiHandler as all "i" are null and all menus are disabled. I guess it is not right and it may be related.
Re: e4 dynamic menu contributions not work? [message #1129021 is a reply to message #1128743] Tue, 08 October 2013 03:59 Go to previous messageGo to next message
On 08.10.13 03:04, Dennis Lee wrote:
> Hi Tom,
well so do the items show up or not?
> The problem is:
> be related.
I've modified the example so that the enablement checks are succeeding
in case you toggle the "Check - H 1"-Toolitem
Tom
Re: e4 dynamic menu contributions not work? [message #1129257 is a reply to message #1129021] Tue, 08 October 2013 08:57 Go to previous messageGo to next message
Yes the menu items are shown. Just the menu do nothing when access. Also when accessing (top) menu that has those dynamic menu items ("M1" in testcase), it prints error message - "SEVERE: No contribution uri defined"
Re: e4 dynamic menu contributions not work? [message #1129261 is a reply to message #1129257] Tue, 08 October 2013 09:03 Go to previous messageGo to next message
Sorry I didn't see the bottom part. I'll check again and let's you know
Re: e4 dynamic menu contributions not work? [message #1129286 is a reply to message #1129261] Tue, 08 October 2013 09:33 Go to previous messageGo to next message
I just check with latest build and testcase but it seems the same.
When accessing the test menu, only thing run is ath method from DMContribution.
@AboutToHide
	public void ath(List<MMenuItem> items)
Btw, "Check - H 1"-Toolitem is working.
Re: e4 dynamic menu contributions not work? [message #1129290 is a reply to message #1129286] Tue, 08 October 2013 09:39 Go to previous messageGo to next message
So you want to tell me that no "Test Menu 1" item is shown in M1 or Bla?
Tom
> DMContribution.
> @AboutToHide
Re: e4 dynamic menu contributions not work? [message #1129326 is a reply to message #1129290] Tue, 08 October 2013 10:17 Go to previous messageGo to next message
No. I can see "Test Menu 1" under the M1 menu and also it is enabled/disable by "Check - H 1"-Toolitem. The problem is that "Test Menu 1" doesn't do anything when clicking.
Re: e4 dynamic menu contributions not work? [message #1129331 is a reply to message #1129326] Tue, 08 October 2013 10:21 Go to previous messageGo to next message
You are completely right - sorry my bad! Let me see what's going on there!
Tom
Re: e4 dynamic menu contributions not work? [message #1129350 is a reply to message #1129331] Tue, 08 October 2013 10:42 Go to previous messageGo to next message
Logged as https://bugs.eclipse.org/bugs/show_bug.cgi?id=418925 and fixed
with.
http://git.eclipse.org/c/efxclipse/org.eclipse.efxclipse.git/commit/?id=a35b8afb0a43318ac6b60c6e9203780c5297b1e1
Please note that there are 2 problems:
a) the execute method wanted a MToolItem which makes no sense because
this is a menu
b) for direct-menu items the CIF.invoke was wrong
You already know the procedure, a build is underway. You can naturally
also import the e4 projects from our git repo and pull the changes ;-)
Thanks for not insisting that this did NOT work!
Tom
> Tom
Re: e4 dynamic menu contributions not work? [message #1129367 is a reply to message #1129350] Tue, 08 October 2013 11:04 Go to previous messageGo to next message
Great. It is working now.
I failed to notice that you were using MToolItem. I was using MDirectMenuItem and it is also working but MItem seem better.
Btw, it is not a big deal and not sure it is worth to look but just let you know that whenever assessing M1 menu, the console prints some error message - SEVERE: No contribution uri defined.
Thanks a lot.
Re: e4 dynamic menu contributions not work? [message #1129380 is a reply to message #1129367] Tue, 08 October 2013 11:13 Go to previous messageGo to next message
I think this is from MenuLifecycle which adds the first item which has
no contribution URI set - so this to expected!
Tom
> Thanks a lot.
Re: e4 dynamic menu contributions not work? [message #1129387 is a reply to message #1129380] Tue, 08 October 2013 11:24 Go to previous message
Yes it's nothing.
Thanks for all your help/effort. I thought I have to re-plan dynamic menu a few weeks or more later but I'm amazed that I don't need to change the plan at all. Wonderful.
Previous Topic:ESelectionService
Next Topic:(no subject)
Current Time: Sat Aug 02 17:40:50 EDT 2025
Powered by FUDForum. Page generated in 0.12262 seconds
