Home » Archived » BIRT » Property binding with XML datasource
Property binding with XML datasource [message #171930] Tue, 20 June 2006 17:58
Originally posted by: t.gertler.netzwerk-design.de
i would like to create a XML Datasource. The URL to the XML File has to
be build with a parameter.
Per example :
I have two Files :
c:\temp\file1.xml
c:\temp\file2.xml
I created a Parameter with a value file1 or file2 (file1 is default)
URL of the XML datasource should be c:\temp\*Parameter*.xml
I tried to do it with a property binding :
"c:\temp\" + params["FileName"]+".xml"
but it does not work.
Any hint ?
Kind regards,
Thomas
Previous Topic:Cannot seem to get beforeOpen script to work
Next Topic:Adding styles to dynamic fields
Current Time: Tue Sep 23 01:41:16 EDT 2025
Powered by FUDForum. Page generated in 0.05423 seconds
