Home » Language IDEs » Java Development Tools (JDT) » Java int[] Array [I@24a1a602](Eclipse error when using int array)
Java int[] Array [I@24a1a602] [message #1125692] Fri, 04 October 2013 15:58 Go to next message
Hello all, I'm having an immense amount of trouble creating integer arrays.
I try to declare them like this:
int[] intArray = new int[5]
And when I try to print the output to the console, I receive this:
[I@24a1a602]
I'm not sure what this means, if I'm doing something wrong, or what's happening.
I'm very sorry if this is in the wrong section, or if this has been answered before. I tried doing some searches but nothing seemed to have come up.
Thank you in advance for any help you can provide!
Re: Java int[] Array [I@24a1a602] [message #1126154 is a reply to message #1125692] Sat, 05 October 2013 03:54 Go to previous messageGo to next message
Preston,
Comments below.
> arrays.
> [I@24a1a602]
Yes, that's expected. The toString implementation of any array is not
all that pretty. It follows the basic default pattern of
<class-name>@<system-hash-code>. In this case, because it's an array
class, it starts with [, and because it's "int" the special short name
for that is I so you see "[I" as the class name.
> happening.
Nothing is wrong.
> have come up.
Re: Java int[] Array [I@24a1a602] [message #1126478 is a reply to message #1126154] Sat, 05 October 2013 12:09 Go to previous messageGo to next message
Use Arrays.toString(intArray) to get the behavior you probably want.
On 10/5/2013 3:54 AM, Ed Merks wrote:
> Preston,
> Comments below.
>> [I@24a1a602]
> Yes, that's expected. The toString implementation of any array is not all that pretty. It follows the basic default pattern of <class-name>@<system-hash-code>. In this case, because it's an array
> class, it starts with [, and because it's "int" the special short name for that is I so you see "[I" as the class name.
> Nothing is wrong.
Re: Java int[] Array [I@24a1a602] [message #1126485 is a reply to message #1126154] Sat, 05 October 2013 12:16 Go to previous messageGo to next message
Fantastic, thank you very much for the explanation.
I guess my next question is then, if I want to display the contents of an integer array, how would I do that?
I apologize if I'm a bit ignorant here, I'm trying to gain some experience.
Re: Java int[] Array [I@24a1a602] [message #1126516 is a reply to message #1126485] Sat, 05 October 2013 13:05 Go to previous messageGo to next message
Preston,
You saw the other answer to your question from Bill?
> experience.
Re: Java int[] Array [I@24a1a602] [message #1126551 is a reply to message #1126516] Sat, 05 October 2013 14:01 Go to previous message
I must have posted right after Bill and completely missed it!
Sorry about that, and thank you so much for all your help!
Previous Topic:Hamcrest conflict with JUnit runner - signed/unsigned jars
Next Topic:JDT auto completion error
Current Time: Wed Nov 05 20:19:29 EST 2025
Powered by FUDForum. Page generated in 0.06996 seconds
