Home » Modeling » GMF (Graphical Modeling Framework) » Taipan Example ... Some Doubts
Taipan Example ... Some Doubts [message #171716] Wed, 06 February 2008 22:25 Go to next message
Originally posted by: annamalai.ancitconsulting.com
Hi There
I downloaded the Taipan Example from the CVSRoot to check out the code and
understand GMF ...
But to my surprise, i didnt find any GMFGraph, GMFTool or GMFMap model ..
there was only GMFGen model ... So this left me wondering how is the
Taipan Example created as conventionally all the tutorials talk about
creating the Graph Model, Tool Model and Map Model before the GMFGen Model.
Also i found this extra file called as Sketch .. wasnt sure what is that
now ...
Also when i checked out the code i got error on WrappingLabel .. it seems
there is no class like that .. i replaced it with WrapLabel it was working
.. so wanted to understand what is correct .. wrapLabel or wrappinglabel.
Looking forward for reply .. as i need to start on a hi priority GMF Task.
regards
Malai
Re: Taipan Example ... Some Doubts [message #171834 is a reply to message #171716] Thu, 07 February 2008 15:06 Go to previous messageGo to next message
Originally posted by: gxquarel.txin.it
Search the messages about Taipan example and WrappingLabel and you'll find
that it isn't update with the last version of GMF. There is still a bug
about label icons.
I'm a new GMF user too... A tip: don't waste much time with GMFGraph,
GMFMap, ... they makes the creation of GMFGen simpler, but at the end it's
better to understand to modify directly this last file. How? Searching
tutorial, wiki and this ng.
At the very end you'll will always have to customize the classes generated
by GMFGen if you really would like something fitting your needs.
Ciao
Giovanni
"Annamalai C" <annamalai@ancitconsulting.com> ha scritto nel messaggio
news:f81e42926ff50ad9d174bce7d975d8b3$1@www.eclipse.org...
> Hi There
> understand GMF ...
> Model.
> now ...
> regards
> Malai
Re: Taipan Example ... Some Doubts [message #172714 is a reply to message #171834] Sat, 16 February 2008 15:43 Go to previous message
There are several ways for working with GMF. While the combination of
graph/tool/map is common used and stable, other attempts grew up. Which
one you use becomes important when it comes to the customizing.
GMF has a lot of power, but only a small part of it is being covered
"with a GUI". Which way you go depends on your requirements - as soon as
customizing becomes important you'll need to leave the regular path in
order to achieve some goals...
Sketch models are very lightweight models based on general graph terms
(node, edge, aso.) - you need the GMF Experimental SDK to use them. The
advantage is that they are quite straight forward and you get a gmfgen
quickly.
All possibilities of extending generated editors (like generated @NOT or
extension points) have one disadvantage: they are performed *after* the
generation has been performed.
For my project I prefer extending the generation templates with
decorator models and dynamical XPand templates. For this you need the
Experimental SDK again. Then you can change your editors *before* they
are created. This way all customizations keep consistent. To learn more
about XPand visit the oAW homepage www.openarchitectureware.org
Greetings,
Axel Guckelsberger
Previous Topic:Setting Attributes of Custom Figure
Next Topic:problem with notifications
Current Time: Tue Oct 28 20:01:52 EDT 2025
Powered by FUDForum. Page generated in 0.03349 seconds
