| Re: Google Maps Integration [message #1128158 is a reply to message #1125372] |
Mon, 07 October 2013 07:55  |
Hi.
One possible cause of this is simply that the RAP application needs
longer to start than the browser. In that case simply wait a few seconds
and hit F5. However, in case of the gmaps demo things are a bit
complicated since it was designed to be able to run both in RCP or RAP.
Somehow the RAP specific launch config was removed at one point, so I'm
not sure what you use to launch the demo. I added the launch config
again, so now you should just have to check out the
com.eclipsesource.widgets.gmaps.demo bundle and start
GMapsDemoRAP2_2.launch.
Greetings,
Tim
Am 04.10.2013 14:49, schrieb Alex B:
> I solve this problem by removing all "demo" & "example" bundels from my
> "RAP application" configuration running.
> So now I don't see any error messages but I can't see the example :(
> When I open the browser at URL 127.0.0.1:8080/rap, I see:
> HTTP ERROR: 404
> Problem accessing /rap. Reason:
> ProxyServlet: /rap
> Powered by Jetty://
> So, I see that in "resources" folder of my project there is a Gmap.html
> file.
> Probably wrong URL?
Tim Buschtöns
Twitter: @EclipseRAP
FUDForum. Page generated in 0.03954 seconds
