Eclipse 3.2 with WTP [message #171687] |
Tue, 20 June 2006 13:08 |
Originally posted by: maha.nagarjuna.gmail.com
Where can I find the Eclipse 3.2 INCLUDING WTP project?
Nagarjuna
Re: Eclipse 3.2 with WTP [message #172251 is a reply to message #172105] |
Fri, 23 June 2006 13:45 |
Originally posted by: thisisnot.mymail.com
Randy D. Smith wrote:
> lmandel@ca.ibm.com wrote:
>> Eclipse 3.2 and WTP 1.5 are set to release on June 30.
>> 8 days left and counting...
>> Lawrence
> That's the Callisto release train... I think the original question was
> asking about a new "all-in-one" type of packaging. With Callisto you can
> download a platform base and then update to what you want (include WTP,
> with all dependencies easily fulfilled in the update process using the
> "Select Required" button)... but I'm not sure that meets the original
> query specs or not.
I think a all-in-one release that contains both wtp 1.5 and eclipse 3.2
should be done only when they get final. Even so, I've been using
Callisto and it rocks (except one hast to manually select dependencies,
that's... a bummer) so as far as updating it makes a much more pleasant
experience, putting the plugins in a separate extension points and all.
Srgjan
FUDForum. Page generated in 0.03211 seconds
