Home » Archived » BIRT » Scripting DS, Custom POJO and Classpath.
Scripting DS, Custom POJO and Classpath. [message #171685] Tue, 20 June 2006 09:34 Go to next message
Originally posted by: ""z a r o u b i ( removespaces)\".q u an t risk . com"
Here is my setup :
1) Created my own viewer using the Engine API using a web interface
(Tomcat)
2) All my POJO's are in my webapp directory
3) I am trying to write daemons to create pdf reports that should be
generated once a day and use these POJO Objects.
4) When I follow the example in
http://download.eclipse.org/birt/downloads/examples/scriptin g/scripteddatasource/scripteddatasource.html
I don't have a problem. But as soon as I try to instanciate one of my
own objects that is in the my webapp, I have a problem.
Note: My CLASSPATH environment variable is set up correctly.
Question: Is there a way that I can, in javascript say: "Here is where
you have to look my java objects" ?
Thank you for your time.
Re: Scripting DS, Custom POJO and Classpath. [message #171702 is a reply to message #171685] Tue, 20 June 2006 10:01 Go to previous messageGo to next message
Originally posted by: m.n.com
What are the indications that you have a problem?
removespaces wrote:
> Here is my setup :
> (Tomcat)
> where you have to look my java objects" ?
Re: Scripting DS, Custom POJO and Classpath. [message #171717 is a reply to message #171702] Tue, 20 June 2006 10:29 Go to previous messageGo to next message
Thank you Mark for your prompt reply,
Following you will find, what I have tried, what worked and what failed.
1) Create a new datasource (scripted)
2) Create a new data set (Output columns: ID, date)
3) In the open of the dataset use:
// start of open method
d = new Packages.java.util.Date();
i = 0;
// end of open method
4) In the fetch of the DS
// start of fetch
if(i > 0){
return false;
row.ID = i;
row.date = Packages.java.lang.System.getenv("CLASSPATH")
i++;
return true;
//end of fetch.
I then dumped the DS as a table, clicked preview, and it correctly
dumped the classpath (Which contains the the path to my objects)
5) The I modified the open method:
To:
// START OF MODIFIED OPEN METHOD
d = new Packages.trader.main.com.quantrisk.DateConverter("2006-01-01 ",
3); // which is a valid constructor of the DateConverter object and is
in my classpath
i = 0;
// END OF MODIFIED OPEN METHOD
6) That didn't work.
The error message that I get is:
Error0 : Error.ScriptEvaluationError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are
errors evaluating script "<Insert my method body here>"
Things to note:
1) Birt Sees java objects as it can dump The env vars; and I get
instanciate a java.util.Date object
2) As soon as I change the 1 line of code to instatiate one of my custom
POJO Objects it stops working. (The object is infact in my classpath)
> removespaces wrote:
>> Here is my setup :
>> interface (Tomcat)
>> be generated once a day and use these POJO Objects.
Re: Scripting DS, Custom POJO and Classpath. [message #171773 is a reply to message #171717] Tue, 20 June 2006 11:51 Go to previous messageGo to next message
Where do you have your classes located? Are they in the viewer's web lib?
Can you provide the whole error message? Or is that all you get?
> i = 0;
> // start of fetch
> if(i > 0){
> return false;
> row.ID = i;
> i++;
> return true;
> //end of fetch.
> To:
> in my classpath
> i = 0;
> Things to note:
>> removespaces wrote:
>>> Here is my setup :
>>> interface (Tomcat)
>>> my own objects that is in the my webapp, I have a problem.
Re: Scripting DS, Custom POJO and Classpath. [message #171782 is a reply to message #171773] Tue, 20 June 2006 11:58 Go to previous messageGo to next message
>> i = 0;
>> // start of fetch
>> if(i > 0){
>> return false;
>> row.ID = i;
>> i++;
>> return true;
>> //end of fetch.
>> To:
>> in my classpath
>> i = 0;
>> Things to note:
>> custom POJO Objects it stops working. (The object is infact in my
>> classpath)
>>> removespaces wrote:
>>>> Here is my setup :
>>>> interface (Tomcat)
>>>> should be generated once a day and use these POJO Objects.
Thank you again Mark for your reply (I reconfigured my news client to
display my name)
I was just able to get the thing to work.
What was wrong is that as I mentioned I have written Servlet to view the
rptdesign files. I was viewing the reports using the "preview" button,
as soon as I used my Servlet everything was fine. It found the classes.
My classes are in the c:/program
files/tomcat/webapps/sampleWeb/WEB-INF/classes
But my birt report designer is in : c:/birt/reportDesigner
I tried to move my classes directory into the report
designer/org.eclipse.birt.report.viewer_X.Y.Z\birt\WEB-INF\l ib
Restarted birt but viewing my reports in the viewer still didn't work.
The reason I can't sent you the complete dump of the error message is
that it's running on a computer that is not connected to the net. (It
would take a long time to re-type everything).
Re: Scripting DS, Custom POJO and Classpath. [message #171804 is a reply to message #171782] Tue, 20 June 2006 12:04 Go to previous messageGo to next message
your classes should go in
designer/org.eclipse.birt.report.viewer_X.Y.Z\birt\WEB-INF\c lasses
Or was that just a typo?
Re: Scripting DS, Custom POJO and Classpath. [message #171812 is a reply to message #171804] Tue, 20 June 2006 12:19 Go to previous message
Yup just a typo.
Now I got my system to "see" (instantiate) some of my classes. But some
other one are just causing the system to crash ..
I will bash my head on this for another hour, if that doesn't work ...
Well I will hear the "I am paying you and you are not producing" line
from my boss. I guess at which point I will have to try to find another
solution to our problem.
Thank you again.
Previous Topic:Date Report Parameters only work in designer
Next Topic:Problem with multiple emf jar files?
Current Time: Sat Jul 05 03:29:42 EDT 2025
Powered by FUDForum. Page generated in 0.06573 seconds
