Re: EMF Installation [message #1124546 is a reply to message #1124440] |
Thu, 03 October 2013 16:45 |
Ed Merks Messages: 33142 Registered: July 2009 |
Aditya,
Use a repo like Kepler or Juno to be sure you also have all the needed
dependencies available (e.g., the data tools project's features).
On 03/10/2013 4:37 PM, Aditya Pavan Devisetty wrote:
> I'm unable to install a EMF plguin in eclipse Juno, when I'm trying to
> install the plugin it is showing the following error
> Your original request has been modified.
> "EMF Common" is already installed, so an update will be performed
> instead.
> "EMF - Eclipse Modeling Framework Core Runtime" is already installed,
> so an update will be performed instead.
> Cannot complete the install because one or more required items could
> not be found.
> Software being installed: EMF ODA Ecore UI 1.1.0.v20130902-0605
> (org.eclipse.emf.oda.ecore.ui.feature.group 1.1.0.v20130902-0605)
> Missing requirement: EMF ODA Ecore UI 1.1.0.v20130902-0605
> requires 'org.eclipse.datatools.connectivity.oda.design.ui 0.0.0' but
> it could not be found
Ed Merks
FUDForum. Page generated in 0.03630 seconds
