Home » Eclipse Projects » e(fx)clipse » How to build Test Project
Re: How to build Test Project [message #1124436 is a reply to message #1124349] |
Thu, 03 October 2013 14:34 |
Filip Deleersnijder Messages: 10 Registered: October 2013 |
I pushed the workspace to git github.com/FilipDeleersnijder/JavaFX-and-OSGi-Proof-Of-Concept.
I tried modifying the Pom.XML from the relang project according to this post (http://www.eclipse.org/forums/index.php/mv/msg/532712/1122008/#msg_1122008) and ran the file with Maven. The following error output occurred :
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: slf4j.org/codes.html#StaticLoggerBinder for further details.
[INFO] Scanning for projects...
[INFO] Computing target platform for MavenProject: TestApplication:TestApplication.app:1.0.0-SNAPSHOT @ /Users/filip/Desktop/Workspaces/JunoWorkspace/Git/JavaFX-and-OSGi-Proof-Of-Concept/JavaFX-and-OSGi-Proof-Of-Concept/TestApplication.app/pom.xml
[INFO] Adding repository http://download.eclipse.org/efxclipse/runtime-nightly/site
[INFO] Adding repository downloads.efxclipse.org/efxclipse.bestsolution.at/p2-repos/runtime/nightly/site
[INFO] Resolving dependencies of MavenProject: TestApplication:TestApplication.app:1.0.0-SNAPSHOT @ /Users/filip/Desktop/Workspaces/JunoWorkspace/Git/JavaFX-and-OSGi-Proof-Of-Concept/JavaFX-and-OSGi-Proof-Of-Concept/TestApplication.app/pom.xml
[INFO] Cannot complete the request. Generating details.
[INFO] {osgi.ws=noenv, osgi.os=noenv, osgi.arch=noenv, org.eclipse.update.install.features=true}
[ERROR] Cannot resolve project dependencies:
[ERROR] Software being installed: TestApplication.app 1.0.0.qualifier
[ERROR] Missing requirement: TestApplication.app 1.0.0.qualifier requires 'package testapplication.buttonprovider 0.0.0' but it could not be found
[ERROR]
[ERROR] Internal error: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from TestApplication.app 1.0.0.qualifier to package testapplication.buttonprovider 0.0.0.", "No solution found because the problem is unsatisfiable."] -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from TestApplication.app 1.0.0.qualifier to package testapplication.buttonprovider 0.0.0.", "No solution found because the problem is unsatisfiable."]
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:168)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
Caused by: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from TestApplication.app 1.0.0.qualifier to package testapplication.buttonprovider 0.0.0.", "No solution found because the problem is unsatisfiable."]
at org.eclipse.tycho.p2.resolver.AbstractResolutionStrategy.newResolutionException(AbstractResolutionStrategy.java:98)
at org.eclipse.tycho.p2.resolver.ProjectorResolutionStrategy.resolve(ProjectorResolutionStrategy.java:88)
at org.eclipse.tycho.p2.resolver.AbstractResolutionStrategy.resolve(AbstractResolutionStrategy.java:63)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveDependencies(P2ResolverImpl.java:126)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveDependencies(P2ResolverImpl.java:81)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.doResolvePlatform(P2TargetPlatformResolver.java:374)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.resolveDependencies(P2TargetPlatformResolver.java:350)
at org.eclipse.tycho.core.resolver.DefaultTychoDependencyResolver.resolveProject(DefaultTychoDependencyResolver.java:109)
at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:82)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:274)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
... 11 more
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] cwiki.apache.org/confluence/display/MAVEN/InternalErrorException
Re: How to build Test Project [message #1124442 is a reply to message #1124436] |
Thu, 03 October 2013 14:39 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Ok - I'll take a look later on ;-)
Tom
On 03.10.13 16:34, Filip Deleersnijder wrote:
> post
> be found
> [ERROR] [ERROR] Internal error: java.lang.RuntimeException: "No solution
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 11 more
> [ERROR] [ERROR] To see the full stack trace of the errors, re-run Maven
> with the -e switch.
> [ERROR] [ERROR] For more information about the errors and possible
> [ERROR] [Help 1]
Re: How to build Test Project [message #1125379 is a reply to message #1124442] |
Fri, 04 October 2013 12:53 |
Ok - I found the problem - I'll try to push my changes and create a pull
request to you.
Tom
> Tom
>> Hi,
>> post
>> be found
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 11 more
>> with the -e switch.
>> [ERROR] [Help 1]
Re: How to build Test Project [message #1125792 is a reply to message #1125379] |
Fri, 04 October 2013 22:16 |
So the problems have been:
a) you added a new bundle but did not:
- add it to the build [1,2]
- add it to the feature [3]
b) a "bug" was in the generated feature.xml so that the final packaging
into an using the build.xml failed [4]
I've pushed all changes to my github-repo and created a pull request for
you [5]. If you accept the pull and then do a
a) execute mvn with the goals "clean package"
b) run the build.xml
You should get a completely package application (on OS-X it is a DMG,
for windows you need to install some extra software to get a setup.exe/msi)
Tom
[1]https://github.com/tomsontom/JavaFX-and-OSGi-Proof-Of-Concept/commit/fc472c63dd82b8eca8d9430e94f6b55d88df96a4
[2]https://github.com/tomsontom/JavaFX-and-OSGi-Proof-Of-Concept/commit/54da2fa47b18f350a9b557281f7d4776bf372a40
[3]https://github.com/tomsontom/JavaFX-and-OSGi-Proof-Of-Concept/commit/f0ae75f085a08b8d860c1f2d7e0b97e0465fa582
[4]https://bugs.eclipse.org/bugs/show_bug.cgi?id=418709
[5]https://github.com/FilipDeleersnijder/JavaFX-and-OSGi-Proof-Of-Concept/pull/1
> request to you.
> Tom
>> Tom
>>> Hi,
>>> post
>>> be found
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 11 more
>>> with the -e switch.
>>> [ERROR] [Help 1]
Current Time: Fri Apr 26 00:25:56 GMT 2024
Powered by FUDForum. Page generated in 0.04635 seconds
