Re: Generating model project .. only available if source level is 1.5 or greater -- but I AM greater [message #1123517 is a reply to message #1123493] |
Wed, 02 October 2013 16:47 |
Ed Merks Messages: 33142 Registered: July 2009 |
Michael,
Are you generating only the model, or also things like the edit and
editor projects? Which Facade Helper Class is specified? What's the
workspace default setting for the compliance level? Can you run it
under debug control to see which file is causing the problem? Is it
parsing some existing file or parsing some newly generated thing in memory?
On 02/10/2013 6:16 PM, Michael Vorburger wrote:
> We're trying to regenerate a (very old, had it for many years) model,
> and it fails with:
> Generating Java class ... failed with an unhandled exception
> A problem was detected while parsing a Java file
> Line 92: Syntax error, type parameters are only available if
> OK, indeed the genmodel's Compliance Level shows as 1.4 in Properties
> (in fact looking at the *.genmodel file it didn't even have a
> complianceLevel, probably it's from before that was introduced).
> No big deal, changing that to 7.0... let's also change Project >
> Properties > Java Compiler > Enable project specific settings >
> Compiler compliance level 1.7.
> Regenerate again - same error! :( So just WHICH "source level" WHERE
> is it trying to tell us about? ;) (If it would help to know exact EMF
> versions used, please let me know and I'll dump it somewhere - but its
> a mixed of 2.9.0/2.8.0/2.7.0 bundles.)
> Thanks!
Ed Merks
Re: Generating model project .. only available if source level is 1.5 or greater -- but I AM greater [message #1124531 is a reply to message #1123545] |
Thu, 03 October 2013 16:35 |
Michael,
I'd need to see the projects in question but it sounds likely that there
is some inconsistency in the project's settings. E.g., what does the
MANIFEST.MF specify for the BREE? What do you see exactly in the
..classpath file? We do have tests that we generate 1.4 compliant code
for that setting so the problem is likely more one of parsing the
existing contents and the settings used for that not agreeing with what
the GenModel says and what the project's various settings specify... If
you can't fix it, please open a bugzilla with a project that I can use
to reproduce the issue you see...
On 02/10/2013 7:27 PM, Michael Vorburger wrote:
> Ed, thank you for your support. Your reactivity is incredible. As always.
> in this case, only Generate Model Code, not the edit and editor projects.
> Properties view says
> org.eclipse.emf.codegen.merge.java.facade.ast.ASTFacadeHelper.
>> What's the workspace default setting for the compliance level?
> It was 1.6.
>> Can you run it under debug control to see which file is causing the
>> problem? Is it
> memory?
> It's parsing existing *.java files; the "..." I omitted in the
> original post are exiting classes which use generics. (Someone, long
> ago, manually hacked those; not bothering about being able to
> regenerate anymore.)
Ed Merks
FUDForum. Page generated in 0.03384 seconds
