Home » Eclipse Projects » JFace » TreeViewer, how to jump say what element to show on top?
Re: TreeViewer, how to jump say what element to show on top? [message #1123213 is a reply to message #1123124] |
Wed, 02 October 2013 10:15 |
Thorsten Schlathölter Messages: 312 Registered: February 2012 Location: Düsseldorf |
probably it is to easy to be the proper solution but try this:
treeViewer.getTree().setTopItem(toBeToRevealed);
Here is the modified Snippet002TreeViewer showing the functionality:
import java.util.ArrayList;
import org.eclipse.jface.viewers.ITreeContentProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.TreeViewer;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.TreeItem;
* A simple TreeViewer to demonstrate usage
* @author Tom Schindl <tom.schindl@bestsolution.at>
public class Snippet002TreeViewer {
private class MyContentProvider implements ITreeContentProvider {
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.IStructuredContentProvider#getElements(java.lang.Object)
public Object[] getElements(Object inputElement) {
return ((MyModel)inputElement).child.toArray();
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.IContentProvider#dispose()
public void dispose() {
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.IContentProvider#inputChanged(org.eclipse.jface.viewers.Viewer, java.lang.Object, java.lang.Object)
public void inputChanged(Viewer viewer, Object oldInput, Object newInput) {
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.ITreeContentProvider#getChildren(java.lang.Object)
public Object[] getChildren(Object parentElement) {
return getElements(parentElement);
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.ITreeContentProvider#getParent(java.lang.Object)
public Object getParent(Object element) {
if( element == null) {
return null;
return ((MyModel)element).parent;
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.ITreeContentProvider#hasChildren(java.lang.Object)
public boolean hasChildren(Object element) {
return ((MyModel)element).child.size() > 0;
public class MyModel {
public MyModel parent;
public ArrayList child = new ArrayList();
public int counter;
public MyModel(int counter, MyModel parent) {
this.parent = parent;
this.counter = counter;
public String toString() {
String rv = "Item ";
if( parent != null ) {
rv = parent.toString() + ".";
rv += counter;
return rv;
public Snippet002TreeViewer(Shell shell) {
shell.setLayout(new GridLayout());
final TreeViewer v = new TreeViewer(shell);
v.setLabelProvider(new LabelProvider());
v.setContentProvider(new MyContentProvider());
v.setInput(createModel());
v.getTree().setLayoutData(new GridData(GridData.FILL_BOTH));
Button button = new Button(shell, SWT.NONE);
button.setText("Scroll");
button.addSelectionListener(new SelectionListener() {
public void widgetSelected(SelectionEvent e) {
TreeItem[] items = v.getTree().getItems();
TreeItem toBeToRevealed = null;
for (TreeItem item: items)
MyModel modelData = (MyModel) item.getData();
if (modelData.counter == 50)
toBeToRevealed = item;
v.getTree().setTopItem(toBeToRevealed);
public void widgetDefaultSelected(SelectionEvent e) {
private MyModel createModel() {
MyModel root = new MyModel(0,null);
root.counter = 0;
MyModel tmp;
for( int i = 1; i < 100; i++ ) {
tmp = new MyModel(i, root);
root.child.add(tmp);
for( int j = 1; j < i; j++ ) {
tmp.child.add(new MyModel(j,tmp));
return root;
Display display = new Display ();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
new Snippet002TreeViewer(shell);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
HTH
Thorsten
Re: TreeViewer, how to jump say what element to show on top? [message #1123278 is a reply to message #1123241] |
Wed, 02 October 2013 11:50 |
Here you go now. It's basically the same as above.
Use:
and
treeViewer.getTree().setTopItem()
Hope this time it helps.
Thorsten
Working example:
import org.eclipse.jface.viewers.TreePath;
private static int sequence = 0;
/* (non-Javadoc)
/* (non-Javadoc)
/* (non-Javadoc)
/* (non-Javadoc)
/* (non-Javadoc)
return null;
/* (non-Javadoc)
public int counter;
public int id;
public MyModel(int id) {
this.id = id;
this.id = sequence++;
rv += counter;
rv += "("+id+")";
return rv;
public int hashCode() {
final int prime = 31;
int result = 1;
result = prime * result + getOuterType().hashCode();
result = prime * result + id;
return result;
public boolean equals(Object obj) {
if (this == obj)
return true;
if (obj == null)
return false;
if (getClass() != obj.getClass())
return false;
MyModel other = (MyModel) obj;
if (!getOuterType().equals(other.getOuterType()))
return false;
if (id != other.id)
return false;
return true;
private Snippet002TreeViewer getOuterType() {
return Snippet002TreeViewer.this;
// I don't know how you want to define the Item to top. I assume you go via a TreePath.
// Path to the element to set to top
final TreePath path = new TreePath(new MyModel[]{new MyModel(1036), new MyModel(1059)});
// First make sure the item to be set to top is visible
v.reveal(path);
// Find the item to top
TreeItem toBeToRevealed = getItemToTop(path);
if (toBeToRevealed!=null)
TreeItem topItem = v.getTree().getTopItem();
if (topItem!=toBeToRevealed)
System.err.println("failed to reveal element at top!");
private TreeItem getItemToTop(TreePath path) {
// You might subclass TreeViewer to be able to access findItem(path).
// Here: use recursive approach via TreeItems.
return findItem(path, items, 0);
private TreeItem findItem(TreePath path, TreeItem[] items, int lvl) {
if (items==null)
return null;
Object segment = path.getSegment(lvl);
MyModel itemData = (MyModel) item.getData();
if (itemData!=null && itemData.equals(segment))
if (lvl==path.getSegmentCount()-1)
return item;
else
TreeItem toBeRevealed = findItem(path, item.getItems(), ++lvl);
return toBeRevealed;
return null;
root.counter = 0;
MyModel tmp;
return root;
shell.open ();
display.dispose ();
[Updated on: Wed, 02 October 2013 11:51] Report message to a moderator
Re: TreeViewer, how to jump say what element to show on top? [message #1123473 is a reply to message #1123278] |
Wed, 02 October 2013 15:51 |
Luis Fernando Robledano-Esteban Messages: 32 Registered: February 2013 |
Member |
Thanks, but setInput, doesn't change the root? What I want is not to set the root to B, which result in the example would be:
__________
B
____
(B on the top-left and its children hanging -in this example none-).
But to show the B element on top (not top-left), so the equivalent to scrolling it up or down until the element is in the first visible row. In other words, I don't want to change the model, I want to apply the view to show other part of the model.
_________
B
C
_________
Thanks again,
Luis
ArkosX
[Updated on: Wed, 02 October 2013 15:52] Report message to a moderator
Re: TreeViewer, how to jump say what element to show on top? [message #1124121 is a reply to message #1123473] |
Thu, 03 October 2013 07:54 |
sorry but I don't get it. The code above scrolls the tree to a given row, so that the given row is exactly at the top of the view. It does not change the viewer input. As far as I understand it's what you have been asking for.
Of course it only works if the viewer can be scrolled at all. Is that your point? If the content is large enough to fit in the visible area of the control, then you cannot scroll. In that case you would indeed have to change the input or the contentprovider. Can you elaborate on the use case of your scenario? What is so bad in changing the model?
Thorsten
[Updated on: Thu, 03 October 2013 07:55] Report message to a moderator
Current Time: Tue May 07 21:34:51 GMT 2024
Powered by FUDForum. Page generated in 0.04456 seconds
