Home » Language IDEs » ServerTools (WTP) » The requested resource (/MyWebApp/login.html) is not available
The requested resource (/MyWebApp/login.html) is not available [message #170922] |
Fri, 09 June 2006 12:13 |
Originally posted by: bunchb.hotmail.com
I'm having problems running a known-good webapp in the latest Eclipse/WTP
version (102). Everything else in the environment is the same as when it
last worked, except Eclipse/WTP. Last version that worked was 3.11/1.0.
Putting the same CATALINA_HOME (copied the whole directory) in place,
using the same JAVA_HOME (copied that too), and when I try to run, I get
this:
HTTP Status 404 - /PWT-H3-WTP10/login.html
type Status report
message /PWT-H3-WTP10/login.html
description The requested resource (/PWT-H3-WTP10/login.html) is not
available.
Apache Tomcat/5.0.28
....obviously, the server is starting fine (I can get to /jsp-examples) --
it's (seemingly) not deploying properly. However, I see it _is_ being
deployed.
Any help is appreciated!
Directory of C:\JFP\workspace\.metadata\.plugins\org.eclipse.wst.server.c ore\tmp0
06/09/2006 07:47 AM <DIR> .
06/09/2006 07:47 AM <DIR> ..
06/09/2006 07:42 AM <DIR> conf
06/09/2006 07:42 AM <DIR> logs
06/09/2006 07:47 AM 170 publish.txt
06/09/2006 07:42 AM <DIR> temp
06/09/2006 07:42 AM <DIR> webapps
06/09/2006 07:42 AM <DIR> work
1 File(s) 170 bytes
7 Dir(s) 30,690,496,512 bytes free
C:\JFP\workspace\.metadata\.plugins\org.eclipse.wst.server.c ore\tmp0 >dir webapps
Volume in drive C has no label.
Volume Serial Number is C0F8-2E5E
p0\webapps
06/09/2006 07:42 AM <DIR> .
06/09/2006 07:42 AM <DIR> ..
06/09/2006 07:42 AM <DIR> PWT-H3-WTP10
06/09/2006 07:42 AM <DIR> ROOT
0 File(s) 0 bytes
4 Dir(s) 30,669,844,480 bytes free
Versions:
Eclipse 3.1.2
WTP 1.0.2
Java 1.4.2_06
Tomcat 5.0.28
Environment:
CATALINA_HOME=C:\jakarta-tomcat-5.0.28
JAVA_HOME=C:\j2sdk1.4.2_06
Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem ; "C:\Program
Files\Symantec\Norton Ghost
2003\";C:\j2sdk1.4.2_06\bin;C:\oracle\ora10\bin
Eclipse server properties --> VM arguments:
-Dcatalina.base=" C:\JFP\workspace\.metadata\.plugins\org.eclipse.wst.server.c ore\tmp0 "
-Dcatalina.home="C:\jakarta-tomcat-5.0.28"
-Djava.endorsed.dirs="C:\jakarta-tomcat-5.0.28\common\endorsed "
Re: The requested resource (/MyWebApp/login.html) is not available [message #170929 is a reply to message #170922] |
Fri, 09 June 2006 13:48 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
Based on the directories and configuration you provide, you should be
able to access the PWT-H3-WTP10 webapp and *not* be able to access the
jsp-examples webapp. Since you are seeing the reverse, are you certain
the server that is running is the one with the configuration under
".metadata\.plugins\org.eclipse.wst.server.core\tmp0"? I don't know if
there would be additional details to explain why you can get to the
Larry
> this:
> type Status report
> available.
> deployed.
> 1 File(s) 170 bytes
> p0\webapps
> 0 File(s) 0 bytes
> Versions:
> Eclipse 3.1.2
> WTP 1.0.2
> Java 1.4.2_06
> Tomcat 5.0.28
> Environment:
Re: The requested resource (/MyWebApp/login.html) is not available [message #170945 is a reply to message #170929] |
Fri, 09 June 2006 14:02 |
D'oh! I was mistaken. I am NOT able to get to the other webapps (like
jsp-examples). That's not even in the tmp0 directory! ;) I was looking
at the 3.1.1/1.0 config that time.
Everything else below is accurate, though! ;)
> Cheers,
> Larry
>> this:
>> type Status report
>> available.
>> deployed.
>> 1 File(s) 170 bytes
>> p0\webapps
>> 0 File(s) 0 bytes
>> Versions:
>> Eclipse 3.1.2
>> WTP 1.0.2
>> Java 1.4.2_06
>> Tomcat 5.0.28
>> Environment:
Re: The requested resource (/MyWebApp/login.html) is not available [message #170969 is a reply to message #170945] |
Fri, 09 June 2006 16:53 |
You might verify that "tmp0\webapps\PWT-H3-WTP10\login.html" exists in
case there is some publishing problem. If it exists, check the output
in the Eclipse Console view to see if there is anything that suggest the
context isn't starting successfully.
Also, was this workspace used previously with the 311/10 installation?
Larry
>> Cheers,
>> Larry
>>> this:
>>> type Status report
>>> available.
>>> deployed.
>>> 1 File(s) 170 bytes
>>> p0\webapps
>>> 0 File(s) 0 bytes
>>> Versions:
>>> Eclipse 3.1.2
>>> WTP 1.0.2
>>> Java 1.4.2_06
>>> Tomcat 5.0.28
>>> Environment:
Re: The requested resource (/MyWebApp/login.html) is not available [message #170989 is a reply to message #170969] |
Fri, 09 June 2006 21:24 |
Hmm -- yes, since I got a new system, and transferred all the projects
(source controlled and other). The .metadata came over with it - if I
recall correctly. I tried moving everything in the tmp0 directory,
recreated the server def, and the behavior continues. However, looking
closer at the logs shows (I suspect) a bigger problem. I hadn't looked at
it too closely before, because I'd stop the server in Eclipse, and try to
run the app again, and I'd see no messages beyond "server startup in...",
so I didn't think to look there. ;)
The tmp0 directory had the entire application in it, so that's probably
not the problem.
Perhaps I should nuke my whole .metadata directory and start from scratch?
The only things I'd have to redo are my Jalopy and ClearCase (CCRC)
plugins, which aren't that big a deal to reinstall.
Starting the server:
Jun 9, 2006 5:10:41 PM
org.apache.coyote.http11.Http11Protocol init INFO: Initializing Coyote
HTTP/1.1 on http-8081 Jun 9, 2006 5:10:41 PM
org.apache.catalina.startup.Catalina load INFO: Initialization processed
in 625 ms Jun 9, 2006 5:10:41 PM org.apache.catalina.core.StandardService
start INFO: Starting service Catalina Jun 9, 2006 5:10:41 PM
org.apache.catalina.core.StandardEngine start INFO: Starting Servlet
Engine: Apache Tomcat/5.0.28 Jun 9, 2006 5:10:41 PM
org.apache.catalina.core.StandardHost start INFO: XML validation disabled
Jun 9, 2006 5:10:41 PM org.apache.catalina.core.StandardHost getDeployer
INFO: Create Host deployer for direct deployment ( non-jmx ) Jun 9, 2006
5:10:41 PM org.apache.catalina.core.StandardHostDeployer install INFO:
Installing web application at context path from URL
file:C:\JFP\workspace\.metadata\.plugins\org.eclipse.wst.ser ver.core\tmp0\webapps\ROOT
Jun 9, 2006 5:10:41 PM org.apache.coyote.http11.Http11Protocol start INFO:
Starting Coyote HTTP/1.1 on http-8081 Jun 9, 2006 5:10:41 PM
org.apache.jk.common.ChannelSocket init INFO: JK2: ajp13 listening on
/0.0.0.0:8011 Jun 9, 2006 5:10:41 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/15 config=null Jun 9, 2006 5:10:41 PM
org.apache.catalina.startup.Catalina start INFO: Server startup in 578 ms
Deploying PWT-H3-WTP10:
Jun 9, 2006 5:13:51 PM org.apache.catalina.core.StandardHostDeployer install
INFO: Installing web application at context path /PWT-H3-WTP10 from URL
file:C:\JFP\workspace\.metadata\.plugins\org.eclipse.wst.ser ver.core\tmp0\webapps\PWT-H3-WTP10
Jun 9, 2006 5:13:51 PM org.apache.catalina.core.StandardContext start
SEVERE: Error in dependencyCheck
java.io.IOException: invalid header field
at java.util.jar.Attributes.read(Attributes.java:383) at
java.util.jar.Manifest.read(Manifest.java:167) at
java.util.jar.Manifest.<init>(Manifest.java:52) at
org.apache.catalina.util.ExtensionValidator.validateApplicat ion(ExtensionValidator.java:152)
at
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4187)
at
org.apache.catalina.core.ContainerBase.addChildInternal(Cont ainerBase.java:823)
at
org.apache.catalina.core.ContainerBase.addChild(ContainerBas e.java:807)
at org.apache.catalina.core.StandardHost.addChild(StandardHost. java:595)
at
org.apache.catalina.core.StandardHostDeployer.install(Standa rdHostDeployer.java:277)
at org.apache.catalina.core.StandardHost.install(StandardHost.j ava:832)
at
org.apache.catalina.startup.HostConfig.deployDirectories(Hos tConfig.java:701)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig .java:432)
at org.apache.catalina.startup.HostConfig.check(HostConfig.java :1083) at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostCo nfig.java:327)
at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent (LifecycleSupport.java:119)
at
org.apache.catalina.core.StandardHost.backgroundProcess(Stan dardHost.java:800)
at
org.apache.catalina.core.ContainerBase$ContainerBackgroundPr ocessor.processChildren(ContainerBase.java:1619)
at
org.apache.catalina.core.ContainerBase$ContainerBackgroundPr ocessor.processChildren(ContainerBase.java:1628)
at
org.apache.catalina.core.ContainerBase$ContainerBackgroundPr ocessor.run(ContainerBase.java:1608)
at java.lang.Thread.run(Thread.java:534)
SEVERE: Error getConfigured
SEVERE: Context startup failed due to previous errors Jun 9, 2006 5:13:51
PM org.apache.catalina.core.StandardContext start SEVERE: Exception during
cleanup after start failed LifecycleException: Container
StandardContext[/PWT-H3-WTP10] has not been started
at
org.apache.catalina.core.StandardContext.stop(StandardContex t.java:4466)
at
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4371)
at
at
at
at
at
at
at
at
at
> Cheers,
> Larry
>>> Cheers,
>>> Larry
>>>> this:
>>>> type Status report
>>>> available.
>>>> deployed.
>>>> 1 File(s) 170 bytes
>>>> p0\webapps
>>>> 0 File(s) 0 bytes
>>>> Versions:
>>>> Eclipse 3.1.2
>>>> WTP 1.0.2
>>>> Java 1.4.2_06
>>>> Tomcat 5.0.28
>>>> Environment:
Re: The requested resource (/MyWebApp/login.html) is not available [message #170998 is a reply to message #170989] |
Fri, 09 June 2006 21:35 |
I tried removing the .metadata directory completely, and the Servers
directory. Didn't help. :\
> not the problem.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> Cheers,
>> Larry
>>>> Cheers,
>>>> Larry
>>>>> this:
>>>>> type Status report
>>>>> available.
>>>>> deployed.
>>>>> 1 File(s) 170 bytes
>>>>> p0\webapps
>>>>> 0 File(s) 0 bytes
>>>>> Versions:
>>>>> Eclipse 3.1.2
>>>>> WTP 1.0.2
>>>>> Java 1.4.2_06
>>>>> Tomcat 5.0.28
>>>>> Environment:
Re: The requested resource (/MyWebApp/login.html) is not available [message #171005 is a reply to message #170998] |
Fri, 09 June 2006 21:39 |
Also, if I try Export --> WAR, I get nowhere just as fast (An error has
occurred when Export finished):
org.eclipse.core.runtime.CoreException[0]: org.eclipse.core.commands.ExecutionException: Error exportingWar File
at org.eclipse.jst.j2ee.internal.archive.operations.J2EEArtifac tExportOperation.execute(J2EEArtifactExportOperation.java:73 )
at org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl.doExecute(ExtendableOperationImpl.java:163)
at org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl$1.run(ExtendableOperationImpl.java:131)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1721)
at org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl.execute(ExtendableOperationImpl.java:139)
at org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard$3.run(DataModelWizard.java:196)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
at org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard.runOperations(DataModelWizard.java:204)
at org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard.performFinish(DataModelWizard.java:173)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.ExportResourcesAction.run(ExportResou rcesAction.java:180)
at org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(BaseSelectionListenerAction.java:167)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: org.eclipse.jst.j2ee.commonarchivecore.internal.exception.Sa veFailureException: Error opening archive for export..
at org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentExportOperation.export(WebComponentExportOperation.java :44)
at org.eclipse.jst.j2ee.internal.archive.operations.J2EEArtifac tExportOperation.execute(J2EEArtifactExportOperation.java:71 )
... 45 more
Caused by:
org.eclipse.jst.j2ee.commonarchivecore.internal.exception.Ma nifestException:
IWAE0015E An IOException occurred reading the manifest in archive:
C:\JFP\ClearCase_Storage\bunchb_d820_JFP_view\JFP\prototypes \PWT-H3-WTP10\wars\PWT.war
at
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.Archive Impl.getManifest(ArchiveImpl.java:846)
at
org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.Sav eStrategyImpl.saveManifest(SaveStrategyImpl.java:155)
at
org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.Sav eStrategyImpl.save(SaveStrategyImpl.java:98)
at
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.Archive Impl.save(ArchiveImpl.java:1221)
at
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.ModuleF ileImpl.save(ModuleFileImpl.java:355)
at
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.Archive Impl.saveAsNoReopen(ArchiveImpl.java:1316)
at
org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentExportOperation.export(WebComponentExportOperation.java :40)
... 46 more
>> not the problem.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Cheers,
>>> Larry
>>>>> Cheers,
>>>>> Larry
>>>>>> this:
>>>>>> type Status report
>>>>>> available.
>>>>>> deployed.
>>>>>> 1 File(s) 170 bytes
>>>>>> p0\webapps
>>>>>> 0 File(s) 0 bytes
>>>>>> Versions:
>>>>>> Eclipse 3.1.2
>>>>>> WTP 1.0.2
>>>>>> Java 1.4.2_06
>>>>>> Tomcat 5.0.28
>>>>>> Environment:
Re: The requested resource (/MyWebApp/login.html) is not available [message #171014 is a reply to message #171005] |
Fri, 09 June 2006 23:06 |
You may have better luck deleting the ".metadata" and Server directories
like before. Rename the project to something different. Start Eclipse
and set up the target runtime and server again. Create a new project
with the same name that was used before. Copy the web content, Java
files, etc. from the old project to the new. Don't overwrite the
".settings" and other project "." files, but reapply any changes needed.
Then refresh the project to pickup the new files. Once you have
recreated the project(s) in this fashion, you can get rid of the old
copy. Not knowing the exact history of the project, it's hard to say
why these problems are occurring and whether it's a migration bug or
something about how you moved things forward. It may not be worth the
time to figure out.
Larry
> ... 45 more
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> ... 46 more
>>> not the problem.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> Cheers,
>>>> Larry
>>>>>> Cheers,
>>>>>> Larry
>>>>>>> this:
>>>>>>> type Status report
>>>>>>> available.
>>>>>>> deployed.
>>>>>>> 1 File(s) 170 bytes
>>>>>>> p0\webapps
>>>>>>> 0 File(s) 0 bytes
>>>>>>> Versions:
>>>>>>> Eclipse 3.1.2
>>>>>>> WTP 1.0.2
>>>>>>> Java 1.4.2_06
>>>>>>> Tomcat 5.0.28
>>>>>>> Environment:
Current Time: Tue Sep 24 07:18:37 GMT 2024
Powered by FUDForum. Page generated in 0.04995 seconds
