Home » Language IDEs » Java Development Tools (JDT) » "No structural differences"
"No structural differences" [message #170345] Tue, 27 July 2004 14:22 Go to next message
Originally posted by: aspinelli.no-spam-please-imteam.it
I'm using Eclipse 3.0 on windows2000; the CVS repository is on
a Linux machine. When I Synchronize with repository, several
times some files are presented as having outgoing changes.
However, the Java Structure Compare shows no differences. In the
title I read "No structural differences".
In the Synchronize window the affected file is shown, e.g., as
Filter.java 1.1 - 1.1 (ASCII -kkv).
If I "Override and Update", Eclipse asks a stress-generating
"Overwrite local changes?" (there are no real changes, of course),
I answer Yes, then Eclipse looks satisfied.
Of course there is absolutely no change from the local and the repository
versions.
The "ignore whitespace" option is set.
Otherwise CVS is perfectly working (commit, history, anything).
I have tried the Eclipse help, google, this newsgroup
to no avail.
In this ng there is an old post by Josh Rehman (Jul 21, 2003)
lamenting, AFAIU, the same problem, but with no answer.
Anybody having the same problem? Suggestions? TIA
Andrea
Andrea Spinelli - IT&T srl aspinelli@no-spam-plase-imteam.it
Via Sigismondi, 40 - 24018 Villa d'Alme' (BG)
tel: +39+035636029 - fax: +39+035638129
http://www.imteam.it/
Re: "No structural differences" [message #170395 is a reply to message #170345] Tue, 27 July 2004 19:30 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Try turning off the ignore whitespace option. It is probably just a
white space change instead of a semantic change. With ignore whitespace
turned off you should be able to see what exactly has changed.
Thanks, Rich Kulp
Re: "No structural differences" [message #170933 is a reply to message #170345] Fri, 30 July 2004 13:38 Go to previous messageGo to next message
Did you try to "cleanup timestamps" (context menu of Synchronize view)?
It helps if you "changed" (saved) files accidently.
Hope, this helps.
Görge
Re: "No structural differences" [message #173248 is a reply to message #170345] Fri, 13 August 2004 08:05 Go to previous message
Is it related to https://bugs.eclipse.org/bugs/show_bug.cgi?id=64083
Genady Beryozkin
http://www.genady.net/
>versions.
>to no avail.
> Andrea
Previous Topic:Logging in the cvs by .dev.java.net
Next Topic:Re: Mark occurances - where is the option?
Current Time: Sun Aug 03 08:05:53 EDT 2025
Powered by FUDForum. Page generated in 0.24609 seconds
