RE: publishing dataset via a web service [message #170200] |
Fri, 26 May 2006 10:57 |
Originally posted by: notValid.ontwantspam.com
Hi everybody :-)
I'm a Delphi developer, but would love to create a Java web service to
publish a dataset. Once I have demonstrated Java can publish a dataset and
Delphi can consume it, I can start to learn the Java language and Eclipse
and develop this project further.
For the time being, due to my limited knowledge, I have chosen to use
wizards - and I found the WTP pluging very helpful. I have published
simple function interfaces, but not yet managed to publish a dataset.
I would be VERY, VERY gratful if somebody could suggest the best way of
approaching this. Ideally I'd like to be able to pass back the datasets
from several different reports - given a report ID.
Thanking you all in advance,
Marc
Re: publishing dataset via a web service [message #171846 is a reply to message #170200] |
Wed, 21 June 2006 15:04 |
Chris Brealey Messages: 104 Registered: July 2009 |
Marc,
could you explain in Java terms what exactly you mean by a "dataset"? The
Apache Axis Web service engine that WTP exploits conforms reasonably well to
the JAX-RPC standard [1] which, in turn, supports complex Java objects
including "value types" (see chapter 5.4).
Cheers - CB.
[1] http://www.jcp.org/en/jsr/detail?id=101
Marc wrote:
> Hi everybody :-)
> Marc
FUDForum. Page generated in 0.02659 seconds
