Dropdown issue in table column [message #1118326] |
Fri, 27 September 2013 09:42 |
Prakash Kamani Messages: 3 Registered: September 2013 |
The issue is very specific to DROPDOWN in the table column. We have business case where UI is design in such a way that first 2 columns in the table are dropdowns. Based on selection in first column, 2nd column dropdown value is populated.
This aspect is working very well in WINDOWS platform where as failing in OpenSuse 11.3 linux.
Problems faced is that when there is focus on one of the dropdown values in first column and then user navigates to 2nd column using mouse click and not TAB action of keyboard, the focuses dropdown value in first column does not get auto selected and populated in the cell leading to 2nd column having incorrect data.
I have attached the snapshot of the UI in the document.
Have anyone faced such issue. Need pointers on area to look for answers.
Initial thought was that it could be OS issue for events but ruled that out by using another application (JSP based) having dropdown value and executed same step.
[Updated on: Mon, 30 September 2013 10:43] Report message to a moderator
FUDForum. Page generated in 0.04863 seconds
