Home » Language IDEs » ServerTools (WTP) » How to get right hostname instead of "localhost" in a generated WSDL?
How to get right hostname instead of "localhost" in a generated WSDL? [message #169827] Tue, 23 May 2006 08:27 Go to next message
Originally posted by: richard.cambio.se
Hello all!
I have a sall problem: when I generate a webservice from a Java class
the WSDL that gets generated contains the row
<wsdlsoap:address
location="http://localhost:8080/EchoWS/services/EchoService"/>
which when deployed to my Tomcat 5.5 makes it impossible for clients to
connect to the service as localhost of course points back to the client.
Which setting schould I change for the WSDL to be generated with a
hostname instead of localhost?
Richard
Re: How to get right hostname instead of "localhost" in a generated WSDL? [message #169906 is a reply to message #169827] Tue, 23 May 2006 11:26 Go to previous messageGo to next message
Hi Richard,
I don't think there is a setting for this. To change the endpoint you
should simply enter the correct endpoint into the WSDL file after it is
generated. It is generated with localhost to allow for easy testing on
your local machine during development.
Lawrence
Re: How to get right hostname instead of "localhost" in a generated WSDL? [message #171869 is a reply to message #169906] Wed, 21 June 2006 12:01 Go to previous message
Richard,
updating the host name from the [Tomcat] Server editor should accomplish
this, but I've tried it and it isn't doing the trick. I'll dig into this a
bit. Meanwhile, please feel welcome to open a bug.
Cheers - CB.
lmandel@ca.ibm.com wrote:
> Hi Richard,
> Lawrence
Previous Topic:Webservice Client Problem with vectors / deserialization
Next Topic:Interoperability JAVA / .NET
Current Time: Sun Sep 21 23:47:51 EDT 2025
Powered by FUDForum. Page generated in 0.04789 seconds
