Home » Eclipse Projects » BPMN 2.0 Modeler » Is there only one bpmn metamodel?
Is there only one bpmn metamodel? [message #1117748] Thu, 26 September 2013 15:29 Go to next message
Hello guys, I'd like to know if is there only one bpmn metamodel instead of 4.
BPMN2.ecore
BPMNDI.ecore
DC.ecore
DI.ecore
I'm having problems with my development because of this, If I had had only one, I would have finished.
Like only one FILE.ecore instead of four.
Thank you.
Re: Is there only one bpmn metamodel? [message #1117784 is a reply to message #1117748] Thu, 26 September 2013 16:13 Go to previous message
Hi Tarcisio,
The four ecore files correspond to the models defined in the BPMN 2.0 specification - there is no unified BPMN2 model, nor should there be because each of these defines its own namespace URI, and each is intended to stand alone. Your genmodel should only target the BPMN2.ecore, and use the other three as references. What kinds of problems are you having? You may want to research the EMF Model Generator and post your questions to the EMF forum.
Bob
Previous Topic:Showing execution state of a running workflow
Next Topic:Can't access xxxxRefs from SequenceFlow
Current Time: Sat Nov 08 15:17:53 EST 2025
Powered by FUDForum. Page generated in 0.03567 seconds
