platform-independent target platform [message #1116341] |
Wed, 25 September 2013 09:15 |
Carsten Reckord Messages: 27 Registered: June 2012 |
I recently tried to update out Buckminster-based build chain from a somewhat
dusty 1.5.0 from around the Juno R0 release to the latest 1.6.0.
After that, we weren't able to build a platform-independent target platform
anymore. As far as I could figure out from the logs, the resolver still
included platform-specific bits for different platforms, i.e. I see
org.eclipse.swt.cocoa.macosx.x86_64:osgi.bundle/[3.102.1.v20130827-2048,3.102.1.v20130827-2048](&(target.arch=x86_64)(target.os=macosx)(target.ws=cocoa)):
Trying provider
p2(${p2.url.platform}[http://download.eclipse.org/releases/maintenance])
Found match 3.102.1.v20130827-2048
Using provider
But after materialization has finished, only the Linux artifacts matching
the actual environment are found in the target platform.
The target platform definition is created with "setpref
targetPlatformPath=/some/path" in a clean workspace and we are using an
MSpec containing <md:property key="target.os" value="*"/> etc. entries that
references a CQuery without any target.* definitions. I also tried adding
properties to the command line as -D target.os=* ... but without effect.
I tried downgrading to the latest 1.5.0 release from around Juno SR2, but
had the same problem. So I'm back to our old version for now.
Has there been any change in how to request platform-independent
materialization?
Re: platform-independent target platform [message #1116358 is a reply to message #1116341] |
Wed, 25 September 2013 09:56 |
if I remember correctly there has been a similar problem in the past and
an easy way to solve it is to put
<cq:property key="target.arch" value="*"/>
<cq:property key="target.os" value="*"/>
<cq:property key="target.ws" value="*"/>
in the cquery...
hope this helps
Lorenzo
On 25/09/2013 11:15, Carsten Reckord wrote:
> Trying provider
> Using provider
> materialization?
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
FUDForum. Page generated in 0.02855 seconds
