error while importing MI of C++ project [message #1115510] |
Tue, 24 September 2013 07:41 |
sachin satawkar Messages: 1 Registered: September 2013 |
I tried following steps more then 5 times but getting same error.
Steps I followed:
right click on selected project=> import=>TADE=> All managed Item under root=> Root folder ( /vob/code/) => get MIs= > finish
then get following error.
SEVERE null
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1029)
at se.ericsson.tade.eclipse.wizards.ImportAllMIsWizard.performFinish(Unknown Source)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$Import.executeHandler(WizardHandler.java:150)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:277)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.IllegalArgumentException: Path must include project and resource name: /mtas
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
at org.eclipse.core.internal.resources.Workspace.newResource(Workspace.java:2163)
at org.eclipse.core.internal.resources.Container.getFolder(Container.java:215)
at se.ericsson.tade.eclipse.utils.Utils.validateLink(Unknown Source)
at se.ericsson.tade.eclipse.wizards.ImportAllMIsWizard.importMI(Unknown Source)
at se.ericsson.tade.eclipse.wizards.ImportAllMIsWizard$1.execute(Unknown Source)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
FUDForum. Page generated in 0.02286 seconds
