Bar charts options?... [message #1112239] |
Thu, 19 September 2013 09:42 |
Paolo Aprile Messages: 24 Registered: June 2013 |
Hi everyone!
I'm currently creating a bunch of charts in a report, and I'm having some difficulty in getting them the way i had imagined.
Is it possible to use both side-by-side and stacked bars in the same graph? I'm trying to compare multiple sets of coupled values, and I'd like to have all values in evidence. Is there any way I can make this happen?
Furthermore, in another graph I'd like to have a bar graph with an overlapping line indicating the median value of the represented bars.
I keep getting the feeling that I'm missing something and that all this should be possible.
Thans for your attention!
Paolo
[Updated on: Thu, 19 September 2013 09:56] Report message to a moderator
Re: Bar charts options?... [message #1112512 is a reply to message #1112239] |
Thu, 19 September 2013 20:35 |
Creating multiple series on a stacked bar and then having a field as optional series grouping should do what you're wanting, but I don't know what your data is like, so I'm not totally certain. As for the median value line, you could use a marker line in the chart and set its value dynamically based on your calculation.
Michael
Developer Evangelist, Silanis
Re: Bar charts options?... [message #1113120 is a reply to message #1112812] |
Fri, 20 September 2013 17:20 |
For the marker, you'll need to calculate the value and set the marker in script. You can place a marker on the chart in the design and simply change its value in your chart script to make it easier.
Michael
FUDForum. Page generated in 0.04657 seconds
