Home » Modeling » GMF (Graphical Modeling Framework) » how do dynamic popup menus
how do dynamic popup menus [message #168314] Tue, 15 January 2008 13:20 Go to next message
I have a need to create a dynamic submenu off of the popup menu for my
diagram. The items for the popup submenu are determined by the items
selected and the current state of a database table. In the EMF editor I
could do this with the menuAboutToShow method of the
<model>ActionBarContributor class.
How can you do this in GMF?
Re: how do dynamic popup menus [message #168376 is a reply to message #168314] Wed, 16 January 2008 06:48 Go to previous messageGo to next message
We've recently done something similar. These may be of assistance:
(plugin.xml)
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/eps ilon/org.epsilon.ewl.eclipse.gmf/plugin.xml?revision=1.3& ;root=Technology_Project&view=markup
and
(the class that contributes the sub-menu items)
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/eps ilon/org.epsilon.ewl.eclipse.gmf/src/org/epsilon/ewl/eclipse /gmf/ContributeWizardsAction.java?revision=1.7&root=Tech nology_Project&view=markup
Dimitrios
Re: how do dynamic popup menus [message #168437 is a reply to message #168376] Wed, 16 January 2008 08:51 Go to previous messageGo to next message
Originally posted by: trommas.yahoo.com
Hi Dimitrios
That looks very cool :) I think I need to try that out..
I just have a follow-up question to this:
Is it possible to launch an editor (a diagram) from such a popup menuitem ?
Basicaly: just refer to, or copy, the behavior that gets initialized
when you select a new diagram from the main menu
Tomas Zijdemans
> (plugin.xml)
> and
> Cheers,
> Dimitrios
>> I could do this with the menuAboutToShow method of the
Re: how do dynamic popup menus [message #168453 is a reply to message #168437] Wed, 16 January 2008 09:05 Go to previous messageGo to next message
The dynamic menu items are just actions, so if GMF supports this you
should be able to do it from within those actions as well. Does your
question relate to this thread?
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg03651.html
Dimitrios
Tomas Zijdemans wrote:
> Hi Dimitrios
> Tomas Zijdemans
>> (plugin.xml)
>> and
>> Cheers,
>> Dimitrios
>>> my diagram. The items for the popup submenu are determined by the
>>> items selected and the current state of a database table. In the EMF
>>> editor I could do this with the menuAboutToShow method of the
Re: how do dynamic popup menus [message #168482 is a reply to message #168453] Wed, 16 January 2008 09:22 Go to previous messageGo to next message
Of course, I should have thought of that. However, I need the new
diagram to be related/synced to the diagram you launch it from (As can
be done with "Load Resource" or like it happens with diagram
partitioning). Is this possible in principle ?
Does your
Yes. I use double click (diagram partitioning) to relate 4 subdiagrams
to a superdiagram (To ensure that all diagrams work on the same resource
set). However, when I try to make a new diagram and set it as sub of one
of the above subdiagram (3 levels of diagrams) - it won't work (see my
other thread for details). This is the reason I'm trying to launch a
diagram from a popup - but as mentioned it needs to relate to the other
diagrams.
Thanks for helping
Tomas Zijdemans
> Cheers,
> Dimitrios
>> Hi Dimitrios
>> menuitem ?
>> Regards,
>> Tomas Zijdemans
>>> (plugin.xml)
>>> and
>>> Cheers,
>>> Dimitrios
>>>> EMF editor I could do this with the menuAboutToShow method of the
Re: how do dynamic popup menus [message #168497 is a reply to message #168482] Wed, 16 January 2008 09:42 Go to previous message
Hi Tomas,
I'm afraid that my limited knowledge of GMF is not sufficient for
answering your questions :(. I hope someone else can help you with that.
Dimitrios
> Does your
> diagrams.
> Thanks for helping
> Tomas Zijdemans
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios
>>> menuitem ?
>>> Regards,
>>> Tomas Zijdemans
>>>> (plugin.xml)
>>>> and
>>>> Cheers,
>>>> Dimitrios
Previous Topic:Read-only diagram
Next Topic:Need Help with Link Constraints
Current Time: Mon Nov 03 10:48:03 EST 2025
Powered by FUDForum. Page generated in 0.07412 seconds
