Home » Modeling » TMF (Xtext) » URIImport of a non-xtext resource and referencing of its declared objects
URIImport of a non-xtext resource and referencing of its declared objects [message #1110772] |
Tue, 17 September 2013 10:07 |
Fabian Meyer Messages: 7 Registered: September 2013 |
I'm trying to write a grammar to define rules over entities of an existing domain model. My grammar defines the structure of the entities and rules, so that the corresponding ECore model is generated. It also allows the definition of URIImports, where instances of the existing domain model can be imported, so that the therein defined entities can be used in the rules.
That's exactly where I'm stuck. There's already an API to read the domain model, hence my idea was to write a custom IResourceServiceProvider, which handles the imported files and creates instances of the generated ECore classes. I started writing a dummy resource service, which simply returns true for the file extension of the domain model and does not contain any further logic. I edited my workflow and removed the comments for
fragment = scoping.ImportURIScopingFragment auto-inject {}
fragment = validation.ValidatorFragment auto-inject {
composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
It seems like my custom resource provider is not injected into the framework. I added a breakpoint in the "canHandle(URI uri)" method, but it's never hit and I get a "An internal error occurred during: "Xtext validation".
java.lang.IllegalStateException: No IResourceServiceProvider found in registry for uri ..." in my editor.
[Updated on: Thu, 19 September 2013 13:46] Report message to a moderator
Re: URIImport of a non-xtext resource and referencing of it's declared objects [message #1111523 is a reply to message #1110946] |
Wed, 18 September 2013 10:35 |
My domain model is not ecore-based, but I want to wrap the defined entities into as objects of ECore classes of my DSL. Maybe it's easier to understand if I give you a short example:
You have, let's say, a set of Excel sheets. Every sheet contains a list of cars. Now you want to write a DSL, importing a subset of the sheets and referencing the cars.
CarLikeModel:
(imports+=Import)*
(elements+=CarLike)*
CarLike:
'I like' car=[Car]
Car:
name=ID
Import:
'import' importURI=STRING;
The editor is generated and now you want to start using your existing sheets. You have e.g. two sheets in your workspace
"Mercedes.xslx"
A-Class
C-Class
"BMW.xslx"
1-Series
3-Series
and want to create a CarLikeLanguage instance, referencing some of the cars.
import "Mercedes.xslx"
import "BMW.xslx"
I like C-Class
I like 3-Series
To solve the references, I need to have some kind of adapter, which uses an existing library(e.g. Apache POI) to open the imported resources and creates Car objects for every defined car. I don't want to edit the imported files, I just want to use them as a kind of "car library".
I'm new to Xtext and EMF, but my understanding was, that I could simply implement an IResourceServiceProvider as part of my CarLikeLanguage project, register it for the "xslx" file extension and return instances of the generated Car interface for each car type is read from the sheet, when someone calls the e.g. "getExportedObjects" method. I implemented the provider and bound it to Djuce in my RuntimeModule. But I don't know how to register it for the file extension, so that the IResourceServiceProvider.Registry returny my ResourceServiceProviderr.
Re: URIImport of a non-xtext resource and referencing of it's declared objects [message #1112361 is a reply to message #1111546] |
Thu, 19 September 2013 13:45 |
Well, it finally works! It was kind of hard to achieve for someone without EMF and Xtext knowledge...
I will give you a short overview how my solution works (maybe someone else has the same use case):
I started from scratch and created a "CarModel" EMF-Project. Therein, I created a simple ECore model for the cars
<ecore:EPackage xmi:version="2.0" xmlns:xmi="http_://www.omg.org/XMI" xmlns:xsi="http_://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http_://www.eclipse.org/emf/2002/Ecore" name="car" nsURI="http_://xtext.org/test/Car" nsPrefix="car">
<eClassifiers xsi:type="ecore:EClass" name="Car">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" lowerBound="1" eType="ecore:EDataType http_://www.eclipse.org/emf/2002/Ecore#//EString"
iD="true"/>
</eClassifiers>
</ecore:EPackage>
and a genmodel to generate my model code. Next, I created a "CarResourceFactory" Plugin-Project, which imports my model project and contains the resource loading mechanism for the proprietary ".cars" format.
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.Resource.Factory;
public class CarResourceFactory implements Factory {
public Resource createResource(final URI uri) {
return new CarResource(uri);
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.util.Map;
import org.eclipse.emf.ecore.resource.impl.ResourceImpl;
import org.xtext.test.car.Car;
import org.xtext.test.car.CarFactory;
public class CarResource extends ResourceImpl {
public CarResource(URI uri) {
super(uri);
protected void doLoad(InputStream inputStream, Map<?, ?> options) throws IOException {
InputStreamReader reader = new InputStreamReader(inputStream);
BufferedReader buf = new BufferedReader(reader);
String s = buf.readLine();
String[] cars = s.split(",");
for (String car : cars) {
Car carObj = CarFactory.eINSTANCE.createCar();
carObj.setName(car);
getContents().add(carObj);
<plugin>
<extension
point="org.eclipse.emf.ecore.extension_parser">
<parser
class="org.xtext.test.car.resource.CarResourceFactory"
type="cars">
</parser>
</extension>
</plugin>
Next, I created a "CarResourceServiceProvider" Plugin-Project, as a wrapper between my ECore objects and Xtext. Here's where I had most of my problems. It's not so easy to use the existing Xtext implementation for e.g. the Resource Description Manager, because it depends on the injections of Djuce. Hence, I had to do some trial and error to find a solution, without having to implement the whole description mechanism on my own:
import java.util.Collection;
import java.util.Collections;
import java.util.List;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.xtext.naming.IQualifiedNameProvider;
import org.eclipse.xtext.naming.QualifiedName;
import org.eclipse.xtext.parser.IEncodingProvider;
import org.eclipse.xtext.resource.IResourceDescription;
import org.eclipse.xtext.resource.IResourceDescription.Delta;
import org.eclipse.xtext.resource.IResourceDescription.Manager;
import org.eclipse.xtext.resource.IResourceDescriptions;
import org.eclipse.xtext.resource.IResourceServiceProvider;
import org.eclipse.xtext.resource.impl.DefaultResourceDescription;
import org.eclipse.xtext.resource.impl.DefaultResourceDescriptionDelta;
import org.eclipse.xtext.resource.impl.DefaultResourceDescriptionStrategy;
import org.eclipse.xtext.resource.impl.SimpleResourceDescriptionsBasedContainerManager;
import org.eclipse.xtext.util.CancelIndicator;
import org.eclipse.xtext.validation.CheckMode;
import org.eclipse.xtext.validation.IResourceValidator;
import org.eclipse.xtext.validation.Issue;
public class CarResourceServiceProvider implements IResourceServiceProvider {
final org.eclipse.xtext.resource.IContainer.Manager containerManager = new SimpleResourceDescriptionsBasedContainerManager();
public boolean canHandle(URI uri) {
return uri.fileExtension().equals("cars");
public <T> T get(Class<T> t) {
try {
return t.newInstance();
} catch (Throwable e) {
e.printStackTrace();
return null;
public IResourceValidator getResourceValidator() {
return new IResourceValidator() {
public List<Issue> validate(Resource resource, CheckMode mode, CancelIndicator indicator) {
return Collections.emptyList();
public org.eclipse.xtext.resource.IContainer.Manager getContainerManager() {
return containerManager;
public IEncodingProvider getEncodingProvider() {
throw new UnsupportedOperationException();
public Manager getResourceDescriptionManager() {
return new Manager() {
public boolean isAffected(Collection<Delta> deltas, IResourceDescription candidate,
IResourceDescriptions context) throws IllegalArgumentException {
return false;
public boolean isAffected(Delta delta, IResourceDescription candidate) throws IllegalArgumentException {
return false;
public Delta createDelta(IResourceDescription oldDescription, IResourceDescription newDescription) {
return new DefaultResourceDescriptionDelta(oldDescription, newDescription);
public IResourceDescription getResourceDescription(Resource resource) {
DefaultResourceDescriptionStrategy strat = new DefaultResourceDescriptionStrategy();
strat.setQualifiedNameProvider(new IQualifiedNameProvider.AbstractImpl() {
public QualifiedName getFullyQualifiedName(EObject obj) {
return QualifiedName.create(((Car) obj).getName());
return new DefaultResourceDescription(resource, strat);
<plugin>
<extension
point="org.eclipse.xtext.extension_resourceServiceProvider">
<resourceServiceProvider
class="org.xtext.test.car.resource.CarResourceServiceProvider"
uriExtension="cars">
</resourceServiceProvider>
</extension>
</plugin>
The next step was the actual Xtext project and the grammar. I created a new "CarLanguage" Xtext project, added the model project as dependency, added imports for the existing model to the mwe2 workflow
bean = StandaloneSetup {
scanClassPath = true
platformUri = "${runtimeProject}/.."
registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
registerGeneratedEPackage = "org.xtext.test.car.CarPackage"
registerGenModelFile = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
registerGenModelFile = "platform:/resource/org.xtext.test.CarModel/Car.genmodel"
and defined my grammar
grammar org.xtext.test.CarLanguage with org.eclipse.xtext.common.Terminals
generate carLanguage "http_://www.xtext.org/test/CarLanguage"
import "http_://xtext.org/test/Car" as car
Model:
imports+=Import+
likes+=CarLike+;
Import:
CarLike:
'I like' ref = [car::Car];
I had to add the Xtext project nature to my model project, otherwise Xtext wasn't able to resolve the ECore model.
It finally worked and I was able to start my inner-Eclipse and create domain model files and a grammar instance:
BMW.cars
Mercedes.cars
Test.carlike
import "Mercedes.cars"
import "BMW.cars"
I like CClass
I like EClass
I like Series3
I like Series5
There are still some minor problems, when Xtext is trying to create org.eclipse.xtext.ui.validation.IResourceUIValidatorExtension and org.eclipse.xtext.ui.editor.hover.IEObjectHoverProvider instances, using the get-method of my ResourceServiceProvider, but it works!
(had to add some "_" to the URLs, because the forum won't let me post it otherwise)
Current Time: Sat Apr 27 01:40:14 GMT 2024
Powered by FUDForum. Page generated in 0.03573 seconds
