Home » Modeling » GMF (Graphical Modeling Framework) » Bug in org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator class ?
Bug in org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator class ? [message #167822] Fri, 11 January 2008 09:07 Go to next message
Hi all,
Please find below a snippet of DiagramGenerator#findConnectionsToPaint(List editParts, List connectionsToPaint) :
private void findConnectionsToPaint(List editParts, List connectionsToPaint) {
EditPartViewer viewer = getDiagramEditPart().getRoot().getViewer();
// For each edit part
for (Iterator iter = editParts.iterator(); iter.hasNext();) {
IGraphicalEditPart element = (IGraphicalEditPart) iter.next();
// Get its view
View view = (View) element.getModel();
// If the view is a shape view...
if (element instanceof ShapeEditPart) {
// Get its connections source
List sourceConnections = view.getSourceEdges();
// For each source connection...
for (int i = 0; i < sourceConnections.size(); i++) {
Edge edge = (Edge) sourceConnections.get(i);
// Get the connections target
View toView = (edge).getTarget();
AbstractEditPart toEditPart = (AbstractEditPart) viewer
.getEditPartRegistry().get(toView);
if (editParts.contains(toEditPart)) {
ConnectionNodeEditPart connectionEditPart = (ConnectionNodeEditPart) viewer
.getEditPartRegistry().get(edge);
connectionsToPaint.add(connectionEditPart);
The way this method get the view connections source ( view.getSourceEdges() ) seems to me unsafe. I think that it would be preferable to get the
source connections from the edit part :
AbstractGraphicalEditPart agep = (AbstractGraphicalEditPart) viewer.getEditPartRegistry().get(view);
List sourceConnections = agep.getModelSourceConnections();
For instance, if the edge has it "Visible" property set to false, the method getSourceEdges() will return the edge in the List.
It will result a null pointer when the code will try to get the connectionEditPart from the edit part :
ConnectionNodeEditPart connectionEditPart = (ConnectionNodeEditPart) viewer.getEditPartRegistry().get(edge);
Furthermore the image export will fail due to this null pointer in DiagramGenerator#mapFiguresToEditParts(Collection editParts) on the getFigure() call :
result.put(next.getFigure(), next);
Thanks for your help,
Mariot
Re: Bug in org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator class ? [message #167940 is a reply to message #167822] Fri, 11 January 2008 13:53 Go to previous messageGo to next message
Mariot,
Sounds like a bug. Please raise a bugzilla against the Diagram Runtime
component.
Cherie
Mariot Chauvin wrote:
> Hi all,
> // Get its view
> Mariot
Re: Bug in org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator class ? [message #167982 is a reply to message #167940] Mon, 14 January 2008 04:00 Go to previous message
Cherie,
Thanks for your response.
Bugzilla entry is https://bugs.eclipse.org/bugs/show_bug.cgi?id=215179
Mariot
Cherie Revells wrote :
> Mariot,
> component.
> Cherie
>> Hi all,
>> // Get its view
>> getFigure() call :
>> Regards,
>> Mariot
Previous Topic:Specialization Type
Next Topic:Button in Properties and own
Current Time: Wed Aug 06 03:08:58 EDT 2025
Powered by FUDForum. Page generated in 0.06512 seconds
