Re: [Eugenia] Eclipse Kepler & SVG [message #1109345 is a reply to message #1108941] |
Sun, 15 September 2013 08:31 |
Hi Toñi,
It seems that SVG support is now included with the standard GMF distribution, so the experimental plugins are not needed anymore. The only problem is that Eugenia is adding dependencies on "org.eclipse.gmf.runtime.lite" and "org.eclipse.gmf.runtime.lite.svg", and the "org.eclipse.gmf.runtime.lite" plugin is not included in the standard GMF distribution.
I've tried removing the dependency on "org.eclipse.gmf.runtime.lite" and keeping the dependency on "org.eclipse.gmf.runtime.lite.svg" and it works for me. Could you try it out?
I've fixed the issue locally by editing the source code in Eugenia. I'll file the bug report and do the rest of the work in a few hours.
No problem at all!
Antonio
FUDForum. Page generated in 0.03811 seconds
