Re: high CPU usage on BP [message #167647 is a reply to message #167502] |
Wed, 26 April 2006 19:45 |
Originally posted by: ifedorenko.rogers.com
Yes, I saw this problem. In my case, this happened when the suspected
thread was not visible in Debug view and the problem was going away when
I scrolled Debug view to see all stack frames of the suspended thread.
This Eclipse bug was fixed as part of solution for bug 120200 (post RC1).
Zohar wrote:
> I just came across an issue that when a breakpoint is hit, CPU usage jumps
> to >90% . Before I continue investigating this I wanted to know if anyone
> else experienced this.
> I'm running eclipse 3.2 RC1 + WTP M6 on Win XP.
> Zohar.
Re: high CPU usage on BP [message #167742 is a reply to message #167664] |
Thu, 27 April 2006 16:13 |
Yes, CPU usage was 100%.
Zohar wrote:
> But did you also see the CPU soaring?
> "Igor Fedorenko" <ifedorenko@rogers.com> wrote in message
> news:e2oil0$ce3$1@utils.eclipse.org...
>> thread was not visible in Debug view and the problem was going away when I
>> scrolled Debug view to see all stack frames of the suspended thread. This
>> Zohar wrote:
>>> Hi,
>>> jumps to >90% . Before I continue investigating this I wanted to know if
>>> anyone else experienced this.
>>> Thanks,
>>> Zohar.
FUDForum. Page generated in 0.03439 seconds
