| Installing problem [message #167048] |
Mon, 08 December 2003 02:40  |
Originally posted by: nikokun.libero.it
Hi all,
I'm new here and don't kno if this is the rigth place
for this kind of question.
I've recently download Eclipse for Win32 (I'm on XP)...
eclipse-platform-3.0M5-win32.zip
I've on my machine the Websphere Environment, even IBM's JRE.
Well, when I launch eclipse (eclipse -vm
g:\websphere\appserver\java\jre\bin\javaw.exe) I'm getting only this
message, "Exit code=1" followed by startup command (-cp -os -ws -arch
-showsplash...)
What can I do? What need I too?
Thanks for any help.
| Re: Installing problem [message #167065 is a reply to message #167048] |
Mon, 08 December 2003 03:53   |
Originally posted by: hcs33.egon.gyaloglo.hu
What version of jre's you have? Eclipse 3.0M5 requires an 1.4 level java vm,
and it does not run on sun java 1.4.0 series (it is too buggy). You need an
ibm 1.4 jre or a sun 1.4.1 or later jre.
Also, there is a .log file under the workspace\metadata folder. Maybe there
are some exceptions in it which you can search in bugzilla or post here.
Btw, are you interested in just the platform or also the java development
tools? If the latter you need to download the sdk instead of the platform.
HTH,
Csaba
"Bad" <nikokun@libero.it> wrote in message news:br19t8$4dl$1@eclipse.org...
> Hi all,
> -showsplash...)
| Re: Installing problem [message #168646 is a reply to message #167065] |
Wed, 10 December 2003 05:23  |
You got it, I think.
I've only the 1.3.1
However I'll download the SDK version...
Many thanks for the help.
> Also, there is a .log file under the workspacemetadata folder. Maybe there
> HTH,
> Csaba
FUDForum. Page generated in 0.03487 seconds
