Re: how i create new ETL project? [message #1107023 is a reply to message #1106864] |
Wed, 11 September 2013 22:04 |
I meant to write ".launch" instead of ".xml.launch" in my previous message - apologies for any confusion caused. The ".xml.launched" file is produced by storing the ANT launch configuration for the "launch.xml" workflow.
Dmitris
Re: how i create new ETL project? [message #1107370 is a reply to message #1107369] |
Thu, 12 September 2013 09:54 |
To create the ".xml.launch" file, after step 3) you need to select the "Common" tab of the launch configuration dialog, select "Shared file" under "Save as", and then select a folder where the persisted launch configuration should be saved.
Dimitris
FUDForum. Page generated in 0.03821 seconds
