Home » Modeling » Graphiti » Opened unchanged editors marked as dirty...(...when opening a new editor)
Re: Opened unchanged editors marked as dirty... [message #1112214 is a reply to message #1108228] |
Thu, 19 September 2013 09:03 |
Laurent Le Moux Messages: 184 Registered: September 2011 |
Hi Michael,
Dawn implements its own "isDirty strategy" and overrides the corresponding method(s).
Before I do that, I would like to better understand what happens...
When opening my first diagram, no problem, it's not dirty.
DiagramBehavior#isDirty calls GFWorkspaceCommandStackImpl(WorkspaceCommandStackImpl)#isSaveNeeded :
public boolean isSaveNeeded() {
// We override the execute method and never call the super implementation
// so we have to implement the isSaveNeeded method ourselves.
IUndoableOperation nextUndoableOperation = history.getUndoOperation(getDefaultUndoContext());
if (nextUndoableOperation == null) {
return savedContext != null;
return savedContext != null ? !nextUndoableOperation.hasContext(getSavedContext()) : true;
nextUndoableOperation and savedContext are null, thus the method returns false which is coherent.
But, when opening a second diagram (regarding another EMF object of same type), nextUndoableOperation = EMFCommandOperation with 'update' label and encapsulating a EmfOnGefCommand !?
And the first opened editor becomes dirty...
In debug mode, I noticed this operation is also added to the operation history when opening the first editor but 'disappears' somehow before isSaveNeeded is called.
Actually this method is called a couple of times when opening each editor.
When opening the first one, I get like 4 calls all returning false.
When opening the second one, I get about 3 times true and a last call returning false !?
I also noticed that, when opening only one diagram displaying two emf objects with a containment relation (like 'service' and its 'operations'), the editor is always dirty. Whereas, for a diagram containing two objects without containment relationship (like two services), the opened editor is 'clean' until I open another one...
To sum up, this EmfOnGefCommand - a Graphiti object - appears to be the reason why an editor becomes dirty. Not knowing Graphiti internals, I'm confused. Any idea of what may happen ?
Laurent
Re: Opened unchanged editors marked as dirty... [message #1115793 is a reply to message #1113064] |
Tue, 24 September 2013 15:30 |
Hi again,
Just to say that i created a TED for my explorer and also one per editor instance and it now works just fine.
Many thanks for your help Michael !
Some more details for anyone interested.
Hereafter an extension of DiagramEditor to use a CDO TED :
@SuppressWarnings("restriction")
public class GraphitiEditor extends DiagramEditor {
private CDODiagramEditorInput input = null;
public void init(IEditorSite site, IEditorInput input) throws PartInitException {
this.input = (CDODiagramEditorInput) input;
super.init(site, input);
protected DiagramBehavior createDiagramBehavior() {
return new DiagramBehavior(this) {
* Modify the default update behavior to use CDO compliant transactional editing domain
* @see org.eclipse.graphiti.ui.editor.DiagramBehavior#createUpdateBehavior()
protected DefaultUpdateBehavior createUpdateBehavior() {
return new DefaultUpdateBehavior(this) {
protected void createEditingDomain() {
TransactionalEditingDomain editingDomain =
(new CDOTransactionalEditingDomainImpl.CDOFactoryImpl()).createEditingDomain();
initializeEditingDomain(editingDomain);
protected void disposeEditingDomain() {
getEditingDomain().dispose();
protected DefaultPersistencyBehavior getPersistencyBehavior() {
return new DefaultPersistencyBehavior(this) {
* Make sure the resource containing the diagram is added to the TED before loading...
* @see org.eclipse.graphiti.ui.editor.DefaultPersistencyBehavior#loadDiagram(org.eclipse.emf.common.util.URI)
public Diagram loadDiagram(URI uri) {
if (uri != null) {
final TransactionalEditingDomain editingDomain = diagramBehavior.getEditingDomain();
if (editingDomain != null) {
// Adding the diagram resource to the TED
IEclipseContext context = EclipseContextFactory.getServiceContext(Activator.getContext());
CDOTransaction transaction = (CDOTransaction) context.get("openedCDOTransaction");
Resource diagRes = transaction.getResource(uri.path());
editingDomain.getResourceSet().getResources().add(diagRes);
// Find object but using CDO API...
EObject modelElement = null;
try {
modelElement = transaction.getObject(input.getDiagramId(), false);
if (modelElement == null) {
modelElement = transaction.getObject(input.getDiagramId(), true);
return null;
} catch (WrappedException e) {
// Log only if debug tracing is active to avoid user
// confusion (message is shown in the editor anyhow)
T.racer().debug("Diagram with URI '" + uri.toString() + "' could not be loaded", e); //$NON-NLS-1$ //$NON-NLS-2$
return null;
modelElement.eResource().setTrackingModification(true);
return (Diagram) modelElement;
return null;
* Modify the default persistency behavior to add CDO transaction commit while saving the editor modifications
* @see org.eclipse.graphiti.ui.editor.DefaultPersistencyBehavior#save(org.eclipse.emf.transaction.TransactionalEditingDomain, java.util.Map, org.eclipse.core.runtime.IProgressMonitor)
protected Set<Resource> save(TransactionalEditingDomain editingDomain, Map<Resource,Map<?,?>> saveOptions,
IProgressMonitor monitor) {
Set<Resource> resSet = super.save(editingDomain, saveOptions, monitor);
try {
transaction.commit();
} catch (ConcurrentAccessException e) {
e.printStackTrace();
} catch (CommitException e) {
return resSet;
The used CDO Diagram Editor Input :
public class CDODiagramEditorInput implements IDiagramEditorInput, IEditorInput {
private String providerId = null;
private URI diagramURI = null;
private CDOEditorInput cdoEditorInput = null;
private CDOID diagramId = null;
public CDODiagramEditorInput(CDOView view, URI resourceURI, boolean viewOwned, CDOID ID) {
cdoEditorInput = CDOEditorUtil.createCDOEditorInput(view, resourceURI.path(), viewOwned);
this.diagramURI = resourceURI;
this.diagramId = ID;
* From the diagram CDO ID, it's possible to get the editor TED in the eclipse context map.
public CDOID getDiagramId() {
return diagramId;
* Compare diagrams in order not to open several Graphiti editors on the same content
* @see java.lang.Object#equals(java.lang.Object)
public boolean equals(Object obj) {
if (obj instanceof CDODiagramEditorInput) {
return ((CDODiagramEditorInput)obj).diagramId.equals(diagramId);
return false;
public String getUriString() {
return cdoEditorInput.getResourcePath();
public URI getUri() {
return this.diagramURI;
public String getProviderId() {
return this.providerId;
public void setProviderId(String providerId) {
this.providerId = providerId;
public void updateUri(URI newURI) {
this.diagramURI = newURI;
public Object getAdapter(@SuppressWarnings("rawtypes") Class adapter) {
return cdoEditorInput.getAdapter(adapter);
public boolean exists() {
return cdoEditorInput.exists();
public ImageDescriptor getImageDescriptor() {
return cdoEditorInput.getImageDescriptor();
public String getName() {
return cdoEditorInput.getName();
public IPersistableElement getPersistable() {
return cdoEditorInput.getPersistable();
public String getToolTipText() {
return cdoEditorInput.getToolTipText();
And a link to the CDO TED code itself :
http://www.eclipse.org/forums/index.php/m/1121603/#msg_1121603
[Updated on: Mon, 30 September 2013 20:17] Report message to a moderator
Current Time: Fri Apr 26 06:44:50 GMT 2024
Powered by FUDForum. Page generated in 0.03331 seconds
