Re: [Zest] Export Graph or GraphViewer [message #1105702 is a reply to message #1105173] |
Tue, 10 September 2013 07:21 |
Zoltan Ujhelyi Messages: 392 Registered: July 2015 |
this approach is not supported directly by Zest. What you can do as a workaround is the following:
1. Traverse all nodes and connections manually, and save them (in any format of your choosing, you are writing the load/save code), including position and size information
2. Create a new layout algorithm, that utilizes this saved position information, and after loading the graph apply this algorithm. You can use also implement some fallback that in case of layout information is missing, apply another layout.
Hope, the idea is clear,
Zoltán
FUDForum. Page generated in 0.03281 seconds
