webdoclet merge dir [message #165893] |
Tue, 04 April 2006 22:43 |
Originally posted by: ozkologlu.nowhere.com
HI all,
I can see that the webdoclet is set to ${web.module.webinf}. Does anyone
know where the value is set and/or what the valid palaceholder variables
are?
I don't particularly like to have my merge files in the webinf directory of
the project.
Oz
Re: webdoclet merge dir [message #170266 is a reply to message #168791] |
Fri, 26 May 2006 19:01 |
Originally posted by: john.debellevue.gmail.com
> I have the same query has anyone out there got an
> answer I do nor want to
> locate my xdoclet web merge files in WEB-INF as these
> then get packed up
> in the WAR
You can set a propertie in the Ant properties (Window-Preferences->Ant->Runtime->Properties), I gave mine a name of mergeDir, and set its value to merge. I created a merge folder under my project folder, and it includes those files in my web.xml.
Re: webdoclet merge dir [message #170558 is a reply to message #170266] |
Mon, 05 June 2006 09:30 |
Originally posted by: paul_grove.yahoo.co.uk
I not sure if it's me or I'm just stupid, I still can't get it to work.
My merge files are under my project in the following file project_name/src/main/xdoclet/merge/web
I add a variable to the ant part of mergedir=src/main/xdoclet/merge/web
Then change the webdoclet mergedir variable in the deployment desriptor part from ${web.module.webinf} to ${mergedir}. But this still does not work what am I doing wrong?
FUDForum. Page generated in 0.04115 seconds
