Home » Modeling » Eclipse Generation Factories (EGF) » Activity Ant Task(Launching Activity Ant Task)
Activity Ant Task [message #1102227] Thu, 05 September 2013 10:36 Go to next message
Hello all
I am searching for some documentation w.r.t launching an Ant Task from an EGF Activity.
I have found code and explanation of how to do a Java Task, but my goal is to try to launch an Ant Script from EGF.
Any help would be appreciated.
Thank you
Re: Activity Ant Task [message #1106070 is a reply to message #1102227] Tue, 10 September 2013 12:49 Go to previous messageGo to next message
Hello Catalin,
You have an example of Ant task.
- Import the EGF Basic examples.
- Open the "ant_task.fcore" of the "org.eclipse.egf.example.task.ant" plugin, you will find the "ant_task" example.
Double-click on the Task, and you will directly access to the Ant script.
Next, you right-click on the task to run it, or you can invoke it in a production plan of a factory component.
Benoît
Re: Activity Ant Task [message #1106093 is a reply to message #1106070] Tue, 10 September 2013 13:28 Go to previous messageGo to next message
Hi Benoit
Thank you for your response.
Unfortunately when i run this example on Juno and also Kepler, also on two different PCs
I get the following error
'Run EGF Activity ...' has encountered a problem.
Unexpected exception while instantiating class 'HelloWorld' in bundle 'org.eclipse.egf.example.task.ant'.
Any ideas will be helpful.
Thank you
Re: Activity Ant Task [message #1114931 is a reply to message #1106093] Mon, 23 September 2013 08:27 Go to previous messageGo to next message
I tested this example on juno and I got the expected output:
main:
     [echo] Ant task says Hello !
BUILD SUCCESSFUL
Total time: 0 seconds
Could you post the full stacktrace of the NPE ?
Thomas
Re: Activity Ant Task [message #1115518 is a reply to message #1114931] Tue, 24 September 2013 03:56 Go to previous message
Hi Thomas
Could tell me more precisely how to do that ? I am still in the process of learning acronyms and eclipse terminology.
Thank you
Previous Topic:Unable to find an Fcore associated with problem
Next Topic:Programmatically invoking EGF activity and configure the contract
Current Time: Wed Nov 05 07:46:38 EST 2025
Powered by FUDForum. Page generated in 0.05219 seconds
