Home » Archived » BIRT » PDF Format
PDF Format [message #165682] Tue, 30 May 2006 11:21 Go to next message
Originally posted by: almasalki.hotmail.com
I build tow copies for the same report(english and arabic), and deploy it
on the tomcat.
now I can see the english report as pdf by using itext from birt viewer,
but when i call the arabic report as pdf, the report viewer donot show any
text or the arabic text show as reversed text.
can anyone help me.
I guess that is the problem in the direction,so can help me to change the
report viewer(pdf) direction(rtl)
Re: PDF Format [message #167255 is a reply to message #165682] Sat, 03 June 2006 03:39 Go to previous messageGo to next message
Originally posted by: goeorge.hotmail.com
can any one help me
Re: PDF Format [message #167581 is a reply to message #167255] Tue, 06 June 2006 03:12 Go to previous messageGo to next message
Originally posted by: brownS.hotmail.com
may be you must change the language of the system
try it
Re: PDF Format [message #169006 is a reply to message #167581] Mon, 12 June 2006 03:02 Go to previous messageGo to next message
that is not work
can anyone help me
Re: PDF Format [message #169517 is a reply to message #169006] Tue, 13 June 2006 01:28 Go to previous messageGo to next message
could you post your error message or other messages which are thrown by Birt
when you are exporting the report with PDF formatter?
"Abo Alnnor" <almasalki@hotmail.com>
??????:13cf6885bad974ff7a711bb47ca5dd52$1@www.eclipse.org...
> that is not work
> can anyone help me
Re: PDF Format [message #169556 is a reply to message #169517] Tue, 13 June 2006 03:32 Go to previous message
there is no error message
but when we generate report_which write in arabic language(right to
left)_as pdf, the pdf appeared the text data as reversed data in direction
(from left to right), so the data was unreadable.
example
I will take you example on english language,because you may not know
arabic language:
I write in my report the lable "world cup", when I generate it as pdf
the text appear like this: "puc dlrow"
Previous Topic:Chart with dates on X axis
Next Topic:Hyperlink in Reportobjects
Current Time: Mon Aug 18 00:01:14 EDT 2025
Powered by FUDForum. Page generated in 0.04781 seconds
