Home » Language IDEs » C / C++ IDE (CDT) » C/C++ indexer takes too too much time to complete its task
C/C++ indexer takes too too much time to complete its task [message #165610] Thu, 09 March 2006 09:58 Go to next message
Originally posted by: andre_oriani.ig.com.br
I'm working in a project with a large amount of source files (more than
1000).
The indexing of C/C++ files takes along time to complete. One single file
takes several minutes. Is there some tips or webpages,previous topics, etc
where I can get information in order to improve the C/C++ Indexer
perfomance?
I am using Eclipse 3.1 with CDT 3.0.1 on a P4 2.4 GHZ , 512 Mb RAM
Thanks for your attention,
André Oriani.
Re: C/C++ indexer takes too too much time to complete its task [message #165650 is a reply to message #165610] Thu, 09 March 2006 22:36 Go to previous messageGo to next message
Originally posted by: sscout.gmpexpress.net
André Oriani wrote:
> 1000).
> file takes several minutes. Is there some tips or webpages,previous
> topics, etc where I can get information in order to improve the C/C++
> Indexer perfomance?
> André Oriani.
Unfortunately, them's the breaks. The best way to improve the indexer's
performance would be to boost your RAM size, and also boost the amount
of memory used by the VM when Eclipse starts (this is buried somewhere
on the Preferences pane).
The best trick I've seen on this is to do whatever you must to keep the
indexer running in system memory, and not in your page/swap file on disk.
Shawn
Re: C/C++ indexer takes too too much time to complete its task [message #166244 is a reply to message #165610] Tue, 21 March 2006 11:35 Go to previous message
Originally posted by: arne.anka.ginguppin.de
do not use "Full Indexer" in large projects, use CTags instead. after the
first run per day it's rather fast (at least compared to "full").
On Thu, 09 Mar 2006 15:58:45 +0100, André Oriani <andre_oriani@ig.com.br>
wrote:
> 1000).
> C/C++ Indexer perfomance?
> André Oriani.
Previous Topic:C++ error parser says [conflicting file names]
Next Topic:Generating project files
Current Time: Wed Aug 20 17:49:41 EDT 2025
Powered by FUDForum. Page generated in 0.02937 seconds
