Home » Language IDEs » ServerTools (WTP) » Help, WTP not working as expected
Help, WTP not working as expected [message #165497] |
Fri, 31 March 2006 09:49 |
Originally posted by: giorgioclavelli.optusnet.com.au
Hi group,
I'm a new Eclipse user. I have successfully played around with it to
develop plain java stuff. Now I wanted see what web development plug-ins
I can use with the benchmark and got in some problems.
I'have just installed WTP, which looks promising, and got this message
when I was trying create a static html page.
"Unable to create this part due to an internal error. Reason for the
failure: The editor class could not be instantiated. This usually
indicates that the editor's class name was mistyped in plugin.xml."
I've googled for similar problems and checked this news group archive
unsuccessfully. Right now, I've no clue what I should do to fix this.
My Eclipse version is the 3.1.2 that I'm using on a WinXP Home pc. I
have installed WTP by the update facility and set it on an external
directory.
A few days ago, in the same way, I installed successfully the community
version of JSEclipse.
In case I will not find suggestions, I think I should unistall the WTP
plug in and reinstalling it manually (at least I will have the
opportunity to check download integrity by the MDF file and check out
the case of bad download). However it looks a cumbersome solution that I
hope to avoid cause it took quite a long time to installing it by the
update way.
Giorgio
Re: Help, WTP not working as expected [message #165522 is a reply to message #165497] |
Fri, 31 March 2006 12:48 |
If you go back to that file and check the context menu's Open With
submenu, which editor was it trying to open?
- Nitin
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Help, WTP not working as expected [message #165554 is a reply to message #165522] |
Fri, 31 March 2006 19:42 |
Hi Nitin,
I get that message every time I try to open (or to create) a html, css,
file using the html editor from the context menu in the package
explorer window.
I can create javascript files, but it is the JSEclipse plug in that is
stepping in, I guess.
I can create a "Web Static Project" by both "File > New > Other" and
from the context menu in the Package Explorer.
My impression is that that something is missing. However, I have no clue
what it may be, due it to the fact I'm new to Eclipse too and I'm not
sure what to look for. I repeat that I can create and work with SE java
projects without problems, even with the JSEclipse (javascript plug in).
Re: Help, WTP not working as expected [message #165646 is a reply to message #165562] |
Sun, 02 April 2006 19:56 |
--------------070206050505020702070109
Hi Marc
Marc Adams wrote:
> It sounds like there might be an issue with the workbench recognizing
> all of your plugins...
> Did you try launching the workbench with the command -clean?
Just did and unfortunately, it doesn't seem having improved or solved
the issue.
> You could also try checking Help->Software Updates->Manage Configuration
> and see that you have the EMF, GEF, JEM and WTP plugins.
This is interesting. The 'installation history' and the current
configuration (screens dumps in the attachments and sorry for the spam)
show the plugins are successfully installed.
However, the graphical directory tree, in the 'Manage Updates' and my pc
directory show a weird thing: all plugins, but the EMF (and the non WTP
plugin JSEclipse (I think xdoclet was installed with JSEclipse, can't
remember about it) ), are deployed under the main eclipse dir
'eclipse3.1.2' (note I have an old eclipse installation labeled
'eclipse' that I didn't removed because don't think it may interfere at
all). The weird thing is that I remember having chosen to install WTP in
the external directory 'externalEclipsePlugins' during the 'updates'
process.
If this is a wrong thing, I guess either I may likely have miss a step
during the installation, or this nice automatic process to install may
have problems.
Unless someone will be able to see a flaw here, I will delete all
directories and reinstall the whole Eclipse thing.
Thanks for your time.
Giorgio
Content-Type: application/zip;
name="configurationReports.zip"
Content-Disposition: inline;
filename="configurationReports.zip"
UEsDBBQAAAAIAKArgzQRWkSYTCIAACwlAAAYAAAATWFuYWdlVXBkYXRlc0Rp clRyZWUuZ2lm
7Zf1VxMA+/ZJ6VJEWloaBARBwNFdgkgMpDsMUBhIx+iO0YyO0TVywOhGJEd3 hzS4vc/z/Bvv
9zrnjnP/fH+ucy4VNeW3kpZZ2HTYN1j/VcD/KuB/I+B/W093NwKFKB4++88J WxlERWVGR2dL
S+vMpBbCyurCy+MpyBPMa5zEa5bDa1nMawPjsW7kdWjicenkcUeKvfETs6x4 KxL//v1nSckQ
Scloaafa9/5dgP8qREk+Wl4+WRkAUVVI0VDKVpfPUpeHqarGa1n4qHq0acd1 6CiX66tGaSsX
6apU6qs26OvGf9CDGNgEGwQggaZQY8dwI88EIKjcDDzyObfL2rrc4muMhR/M LrjW0WTPxaXO
EZTsEtnsFt3maRnm4Vbv4VHy7Tv8q0/Ul8CM79EdP5I6QbbR/j+0vDxa/EOC QInIYNe0YC/N
QI+i0NDQoKCGsIxO/8xhsGV5jGd+tK8a2AcWF/sz+r/qjEqtiM7tAReMJdhh pfnBUr3qEvw7
kgJUUoKKk5OTExKRiUX9qVW/U4fPs/zhmSGKWSEdUIgzBALJqBzJ7eqCGtCX gPDywhuhIa0F
4fJFhdNFtb3Q+oni1oVi5H7h9FWlB1a1p1CdD1Zl4BNY2AQs+n1FYg8sq7+q PLsK3l+FQFX0
bsD6d+u/cDX8FG2KJWmIl6mJRTQmcNSnjNVUzzYu3rb6vOkIFuuKxmrP7INn znR15XatdvWG
i/dHYw1ESfTFtiNz3fv7+xGjW32opaHth8Gc/tHK8am634MDmzNYWFNpa9MZ SlOQtelSlWmY
7kzF2HSz3e/Rrd+Tg3/+Yhbwnq+QKKGecczL6yyb2q1WaS3UfUW1+i5NbC+s odYObpbOHldO
MZs/A3ZjUze7f20hAja6Fzf/7O8s1Wyuzu7vrm4ftm8f35wmJ5/mlRx1Gx5N RR0v7J0c7R6f
35/+vTm+R59iMBfl5w+zn+/Wk6+PB68uz6/v/mHaMZgpz4flgIeVSMxqKmbX B7MbgtmNxuwm
/9stut/PeTysQh/Wo896MKcTmJt+zNUo+nIOc7OJwZze39+gMRjMw2FeXmFA QADmP9+MwcL8
b2D+t/1HrHd4/4OA/7/tv0yE/x8R/0fE/89EEKKxnnEgVGryuoMJn/ECwRRR veGU7OpZqrXQ
vihaUSfS3tqCgTgWhUhGtbrCoSRuvTrjobqikTRh6+EstfrisUyJwz3UUH2J TiBpMDFTeW3p
VIFqkrrmUEPZ7xLdjxtZ6o3lfyrEfzktE3uUzlXjp0QyaYg7ztQ7/C6/AjfC lpq/mLplj9Tz
yVFEB2U/rd3sI3/ZjQgS0GipWQ93fsZnLi1StTkQbzud7fLiZQGNgPSvuj89 s0xUsngEjbYV
65Yxha7Z5mMtjYeNCdYjse8gbtsWAqhGCw9YX6NzrkmIYHpGg8MmnZoOfxW9 5/ft0HzrhKrL
xqtDLXvnVe3Ga9RwiTS6ca9p6fcpTS7uM7HYuH+ftmjL3iWf+l5d7oTWHq4K JbZhMK+9B/4A
8CPOhmy3GilH3edQr4E+RXLcliF9VJ9YPWiLf7z0vHwukRvOsHKTH0YXeZsV xlCeuh55KYdc
jRLC4S6IxnH6uEDeBPwOERWQrll703RksQ4qMlO1TFCRv80HU3iCVxO5cgYL v3EaRlgl8W6o
FCVzfsDbTJsf4+b6+QatyCInZMFlTjJ+dIYQTe+wsHRSJJe0TDSU37JR9FaG 2+SaHuznewTe
D20pWnAdLKZHDxva6UgsXoyKdkuvcbEnPXHcLT6im+NJ9JeFl+Tlpzo55Idq QzhTy5sOiqDo
Gq7Zvco4GZM5yO3tl4HCZNn4uUJyN5PdmpyNoaJSHfmhg7IKkSXe/IE6Yoc6 wX4nAZMGu4dU
2LtlOwuSHsK/mi17EXk5IU/gBPk+o2+QKPArrge3SF0ovVDUWA9DdblZ095k I5ZC0THi09cK
fVs4VMWtpVuGe1H+OmbbHUmD7/JaH89eOqXbkyWrgvDnlx06BwoSpXM9lhzg TB9/ZuH5yJuv
R69lu28n5z7vppLWDkvroy4m/nXzi2mKbJbXj8u8GqOf1Pwpdvn7G53036kg HldPPy0JsqtZ
RtHdqzmLcIHreZs01+sFhxLY9aJL8/H10pcBgRuUx5zrzbLXLuwGveJ7c3yz GkAgeLsW8sLt
dh38qup2I1ri5HYzXkXwbiv5k9vddrpPh9tO1s+Tu13IS4Otnbw0t/v9UowW qLas+eT+sKZA
C+SzV8X8cNyyOw7fa2DfbztBEAhJb9bH5ZycDb6qbl/tu+l8/DupIvTzb+eS 4L+reXudXyGz
9qf/btbChdC3W2nu6Lu9kmr0/VHzKfrhbEAI83g55//uz+1uNQb9ePMfW8Ai zcMioAVMz2wG
EGrm4bwYRDyROgukjM7De6XaTWxyFkQ7mvdEYrCbHHQWzEJqiXP+Ka7gT68f t8sqdptK09Om
4xCe6Px7Fo8e+sWesLft+dhLSb3MB8Lh6K+9BKQ6r5Ctz/XCVjfXKdL2eumn 4yN0G/LJIbiR
vEFsb6YQSnxfqMhqmBLAClnmtBD2SJFInIheHyjZu6kIrhPhyC94Vk5n8QDp eTZ6OFhZBjoV
KejkFn3cg3rRRyiuykH51IE05+lcaYxCw+tYp+jNpyWqGaou1gzTe318ANY4 2ZPaONjtIovS
XRMuY15yCccSt/5muGHrRYof5RKvKyuxZ2kww++3YUKjRv2K/YKJqZNP3lp8 JdS4PQuLSt56
zQeJtZMSZYLdFjIr3KkYTzu6EuSp8C6ljrmGuaY2nfUK9Ktpf+u/yAwo5JSe HRr/0bMZ3elh
JvKMddTLITg9Au1gxeGN0FH7ME0DMQoHbE8FM1fiJoO2Crh/e49NFQlkLvJz yrDxaoRFfiel
HStVHljr84iEMrHgl0krq3+wQernPGkIZT4wpnB16H0ePo9LaQZWYG4JJLjy CtLOtsBjxZOL
xbIleEfYGipwGRBH9Cf05VKfLvs/NxeCszCDF5bD5aC/zoZvttm41Kdig46h 26R8Ki/u3+gS
fiy9SA8xmWudTYK6Jdi/DQFSdIe2flsn1UPZv1++ndAENxDYcitQiCf0CQim lFnzMS9Aef/0
S80yfBIgV4SrL0Qop2rTdPTRugXGjIOa6q1hxXNi56NemhsMpVrHElzrhmzF Dcxm6egKs2pK
QrL52Sb3UVaK5DudRJpLMnfhPSnxWqIPeb8zUNZM8+S6MTtSN/CxDn5H2of5 AfUXWRb/juwV
ooyqbYMY1zhVpCnPY97Pd5PZTPZIUE6Z/OasZ/4Y72xWsQZmmJ/rpPuy4ewO 1jc9+94sKqAt
54MFFsHCoZRxKObvl0NpxX9MPvy2klBDvEz8SaG1yaIqNNdnedTNsC1n2y10 mi7ia7oX4wlL
tZPeyMp1kGDiVQCOWT4lIVOpIQHd4PFTjLN+1vVlSRLHGFWYSyRbJg7BOZhA YF6P6Ct4s7vQ
Ju1b7WI0r+nd8BjiDDu9e1vQB0JH219l514bIJLpjT1P+Rpt16UM/tIiyXi8 1vtmNMpcABhM
Iej3lTohAM/UAosw+x8ZpXDeZ67rmy7dxxISGjLwKzEoleDaEwkr1lh5I/rh jIcdqzbNP5Xy
byqi9kTCNDbXTX3ZKzcN6r/SqoMNn228+FYTVmnvSia5dfddGJ2PH8kSbXnb SkgzWUuGPWpa
HcqCR0AeGCH0C/jx6b6L6ZPvPHBppw/+nqN82rBymJb4G+ng8f1fYfRux/Ab wVocLdXmVj7d
vYwcyilsND1BwEigHKl8ilYHJUkan2uzK3wRdW3CJ7GEcA1OkjRfS+npAJyM b7eGUYNbkOyC
LkwXt8VXt691o3oDEd8QLgRzEuJobPR+XWjWGqmYV6e+Nb5lgClJT41878+B JZCuBY6mb4v/
jdRQ8be1TZbP8GT2nxcxbjMVNs7eLamC0dyj0h4PY+t4xdqetNMNOxFhpoP7 ly6Drmaun/3v
TWtXFLL/ftyT0zGbtw3/Udt2E/pAY7q0rH0zFDEZ5DnRtnIzftP58O80gKJ9 jUDHy/7Z2RlY
p33jxcRt/zv0Oc3wGiWXzt3wJ9nAxLa2HYmJu3Ef9N88ig4cifBu1vi1Sw7u wAO9gCDqFvMn
IhbYOKJC94tL6OuWiY4TPtV7kgzmq3Ih7MPPQsF0g+iAhtWOi7SJx513mKCO 5rVTZ0TEx0o2
sg8s8uQWaCFcWsaXx1gsqL8DOuiLzNXrKaF8eRqH+6elQfSIvd6n4LNgxnkW /D6MrCMWwh/t
I/C4Pif+jyDgXxo9tgMJgZcfcUsA6XxA+ydGdiRAvhCgoIsDiicdtiD+BfC/ HsDh+ILTL+FD
yC1OMCjO+TboIS2I2wFAPh8keBu0k+b37C3o6BNOWTxpI4I4bfKJVTy+cR6e ejwuK9iXzyEA
TRBAaBTwsOuv9h8jMWJU9QoSfhtqYBS6RxBIKBZMpRrIKUwS+NHAFIBvtYdn 8zZEWCyANz1I
tTRM1yFgND+EUzXA3DrUwyj8x56ciBEFLiEW50y4fAiFQgBOvTCxmq6/+Fog moESmxIL2y49
LJY21G0wRIs7wt0o5Nsg48/0iIyWCPLkcJLCUAJqcNlZqBJnmAEgTHsSrOQQ we4VUNUSxjEY
WTMYlGUU1WQUnqMaTJ2O8zWe2OELmCMeTDmJRTqJLZbnX0EbDtsLSxiMxjQH YdPGGHlFzRjF
CKRHmaYDFNZAyQiiz7o4ParRTwG4A9xBPi0h8eAwLYcQbcJwdcKYMsuYi7dx r9/GHKRRHr3C
vX1BkBVP+DoPTGURvQWOtv8e5KMQRwiJH07zoxbDQxH4iFImUKnF4vIE4RO9 JYYk0NOBSCXl
FIRxhVkS2NQSnquFxNcncEMS2WYSniFxBO8ShYnQSekvJP+T4MQhcvwRSRLw JGnjKMkFb5eZ
JHnJ5K2bpMlXctmTqq6KyZoLyS32yT+bP/RuqTIgw5/apGhDUhSIUqgaKEk5 Uq5DdOhDUiiR
4TZqcv/mAPYRAMeyFDdvPyCRXF6LPCn1p4uPn0DCqc8aUn2GUkmQ/qQhKb53 qSFwn693gO8L
4aQc1h59+KAzUmoLbJoA7Lvn6QFl4X7eANey8ADH1CxvSG4ZJA8CIRZLLzRO L3VMvwbLRUDS
CTisgWf4E1gEQQFEpQHEKcYZrWWQ9qFMm31IUASkkCc92DGjB5IxCPEJX4jI JUr33wsnwsPX
PSPVfwFJgmQS2WQYouHhAxGQnP1MJBzSAc8MhGTt3CVXeCfn0sp55Jk1Awi2 y1I3JXMRklmr
dLlbkNxdeG5uuCDjTMbRfs7ZXdoWPNvvLnPFO+MGnncJyf47lEs57D2yAMAi lrOosWrGeuLk
DSGkz4Aa5+Le5rsQZWTS5UCGsqkyoKxi+U9b/CjF8EvF8V/YZOGVQ8Xvg/iJ 5TVrCqRbC0RN
5MRABfIHvpLDWQqgwkHjQtXWQsrywqelOZRIDU2pop97hfn2qoQhRQatRfoO Ra2DPnpOGi2F
Gu0cxEBQMeleUc4r4mMbius1bTsnObnIYo9FOaeM0GdbKSSXev5/cC8oPxxT lhTRQdGtkiUM
Uhnk1IW+dNAQUJY9Tw65EyTMpGT7ZwmNQT6xjaH8H1yl7ZILFoO8gFxopFz3 gpzzXemr+7yi
jOwoUEYyKGa/TK4KnrMJSS9MIT/HMgpSAqoVExXQZyCMoYyRpd132a6SlVy8 OaWgvGXjgvv9
ymriinOwXyEkvSvepus5EEcJ2MVS9mS4so++bNm4cpU3i3QxP9ikaqUsu+8O kEQPU6SvkOKR
k0dmT9xl4RpaEKRa7NdYkBXnEoKq1iUzQlrLnwxn75nkYGsUwHhzzyILLha9 RcEpEZI2KhY2
Kqk2GrM2G1g15MN50IXKKqeaTkhuv3cuEaiu6z6PYgkdkFqebmYMI21wEJx0 iKNxTDJ0TN2p
XSvPi+Wt2jQu3yVuwONtKM8ol+WrE8gspuLL1zkADKS6jBgShkdW8vhUcqhX cmlA2RYb8aIa
gRXllof5O4ulGhUBQu8qCnah5GLu7rruwWtypxly332ajO/qcua+2iKwWQya vzk182Y06fLK
vSdoCSMBefm0RDqHBvmUPeUoimKA8y00jJYUXVnAEzPhdepwi4MWCgON5mSN Njx4hmmr9zC8
baD4aKv4i1NrFV9aaWaJ93ATEbLkGKDrR1waNFzuCGkcuyvtMIWyR5VWSUH9 Hloz01su7xsg
IMMsJwN2/PKCg7Zj3qpVdGslm0b7+6h2hoWW16YVpB4VcHqj4EaiDqkOnoqG Mfqag5G648NO
1Lu44YeOAUfY/CIughOIOoBxMlTGgypfVtTxmbafa8St8KV1kWT7t5CQohBt ARbE/RbIvnoC
Bjlu59RFSCk9EEEv2UVI2kncQNJHSdZOSdZXQ0JXYaO5Y0MNrLOVrCIiholo Ihj5u2rb2t8C
u0gaSEA2pD4NJPFcjsl2jgYaDaXlpUsVVQskDerAXsL9bvBQO2EDSftabz+C hKLSZbOmfiWy
7vVjmoVGXf9Ifr8P1O4QOeuFAKu1ESj2GUb3uTu7OzB26aLkpIEUsoxkbTXN 34EIp6xeNClH
DwcjWX8Nie/SgIdvb/Mugix60K9y8CUKruekHJs1+BvklxoFT6mE+2t2keG1 Wku1JrcPJZoO
MBW2HiJbjxvadn+2F2ZFZDMO5TJ+aHkoYe0bbo/q7q6otAemAMo7jg+Hq4+8 i0flMobJJw7L
pqM6FTV6GcXKKqSgDFKjKcRDekdwco7OVpPO3Xe98yP1tm3Z2TzjNppN8eoI Os2xzU+jDB4w
eGTXohQwcxK2wtjfxdNe4lQlmNX5QNpP/g5xUOlTy9h3Q5x952RBiap+2k7U ttA2cdB5g4J0
SDYQ8iEoyLqwYVmzQB+aqFrV4h5G57rDh4nZkcp7xqooE3THi3+ddL9C01xK gt/VR+84yGXV
Kx5VmldOczFVvVquJ5PKes80I9ARz/DLR4+E0GS072Mmom+o1I5/6hUZghk0 3rPUGEs8qmDm
g+taGKLh/g01bLzcrfTLB+QzSMw9amkWaqqV/9ygxdG1+ehxtrB99sMRoJBv ToBhjj55yKuj
wUOr4odAMdS0+JdWGShGrpSUonxUu8Wl/D0oxRM8C36cuwFTktq0NVa2RYDG hVCjk5FQ2bHp
/cg/2XMzm9JNiIrffB1F4VppAdmAgazRqRHyfOJJmsd5WqYxQLkvGcnMPXA6 WGpsSn3hWVQJ
SeHY1kjF+VrFCuP4S/XxOedGYbT04uFBF64zcpyskut+aQvVJU/Wa/44uf9Y DiOrpx4BnGTB
7t9NdKm3KxwuE2eOyD30ncpURWdMzD3U32lV/TtqxG5f4OhYNFBHEQEn5T0m H+i7MfRl5DL9
90yLEzLLALNVFp8G8s5VbTIo1xjkhHiFlGQycSx32wxVBQMwudq87KjlH0Uu aaxSxFa9AOYJ
jv9+KrsqCOx+OTIhWtV95DyVEzNVKTNb/WtMqh0g5lz/RgapLrOu2TlxtbBF U7VJHbv8t2NV
9WFJsKqTpQKpnNkAkF2Tl63+PAxQyZ5Rap+hgo1sO1UOgrrxl9aeCjQMtzbq Mi1bSf/pXM6i
cttE2zI2lGot6qujXNoBbiTNv9oCWM3nMz6t0BnMsiXv/RxYiBz3Tc6OCXGe TTIvic7ZR5nu
98sM2SL3t5h2cgfmoNolOeYbufzzNqC5ktjCTFm5iI75w5n5CYKxTtS6/8OB sepBrmBasDlF
upluE+mHJvKmCdhOGdNK/HKatXQJDVM/UVZHm++uGP9+GG/lElOdoczuL+2m a7Ll+KopobEE
z1+A2uWyerOlC7XNs4cxB7pTHPSmytISOxlKq7KjdWy9+XhLDTj9jXx7g3S7 Ze+wXHtr9xdq
TKyzzalzBHbIgD7ZP2hcXFl+jRqhWt6lmagbRY8xY/o2YsZvvZEMOejf7HwX P09OPN5uiLQB
9skmDrUmOMiWfcbbKP+tXXXuvDW7YPnczuB/So9ZxR7fzWEak9Kp2gZuIkZ2 OZZGhFXXrssR
VwFrRMfVz6QvXmF6HGP/rgPX74Dba/dXBuSXobyXfG2nJoLrYrLbejmbmrlX Tq5niVlnXNo2
3FW1fKjac0gN9PgKOHGtQXqtPX4DoDilwmyJojbem6/7r94Gfr52X702471x yozxyAWoaP9+
W7FlT373ZWITZ/V2Fn19on0773yLjt3mR5+aV91CJ/52dFx7j98mfT4B+5wQ Gezo+5QOjc/Y
LZW65iCnO688mC8NtM7xnJHT2pc7j8dLaPJNd/SjMd/Jsuy/cfd/fDp39VFx FAZ7n2EpA+9O
UhgPabb2Qo2bN96jF+PG0sYP7dXRJy/hZeT1ue+Gzyl2mt77FfthNKUwKRTD WK+P04X08Elm
FdJ11+XDyJhkQ2j1NhQjnwuYI9P1NpVjmWT8ksETs6qmLFqC1Pg6nNI+14bl 1J4fdpSwyJzH
kRD9Xe0cGYlIDsenL5V8lWLoXbnLlz94y4AGTVvFirWwJN4Y9plUO/XAjJq/ Nd5f5X8MtWm0
uxr+eCxfb8tk17ivfwJs9QiMrTR15+7tIJGrxUVZj6SWXGAFB83PQo1rzVbD Ph6lshr3O7s3
PR8x/Do/lPDXD/2ESYpjKJHlQfnI+cpDXmt/uu9Qr1gzTitzo+93Mi0rcNye rw1GBzxcWu/5
Ffxv2PRicbkv4r39iC/c4eAP7JAzW8Kz5w+h//KP+x2tOM9DJ8w0GfD+y1Za NoFOhWHL190x
SVFtctRfdMvYq88EwojWE97jghNG+uGKjDAr3WpQ1gF2vAgWdiHBnA1dSZNW TlRc5+1j/ags
uRJHbUsDW8EEstbwkQK5jxfyuj+JcCYWjhuHmKJm0upeFzeZL1Nk/Ao+HGtZ AdpMyFD/+xvf
cT+bpNPBmW/qJkpXjaxjp9diH+4PA2I9i39F74jEd2uJUMqSn+VIhLPzRGl3 oKH86NohzijF
aaW3CjYXffwYvMt8gWOnPUSIPGFgD2U/XbhWOYtzJX/Lj3evW3kEnKObHxcL xD5wvAqd0dKJ
I2kw0IePxI5ExFq9YSNHblrEy2kXNRqaun90mOSXjI/BBfrji8/Tev55yq7A tIH4ZJlm27QA
B3uKmziWFNGwOviL/GALLi5vMnXvUnrDzc+qBwZ+mVBqXnB+I2U4CVbUU2Fy w2NzWPI47Zub
8azWcCxKNQ8KN42XHmm2COZblFiKWoSp8BRnBfHyBnJ2kMIo9lEO9VH50i3W gGdVJ9WIJ3xH
wst+BRe8fANs89Zp+HgLbGEkMaWNc1aZsKalb6ZUtlsraNw38NG3bvDttLgq QbupzmAYwfmg
qPuzS6MZD32q04o6pbGwHVrH6iTtPwgXBo4HuRKOwskeD+EZ4W3qbF8dWVW4 IGi8+vSJKZDu
q7SVCvMvvA+qzethPrJ6RHFJfchzO0axojbgWzZhM8okTdEpg996MI2Zv2pv 45LHO2Tb3No9
cphLyPWU6P74HmrzVdE75Ct4Min+J4vK/MzVpVBbjzD/xT5r7C1i8nNTZ9tM zHxEt6lkIy4c
PbHFmgERikqMkX2YLpnr9Dn9vsEst8pad+Pz14zcX/A7lQnG9+Zca/V+cCju 50pgU/btr38l
MV0lfh/v5zQudqmqqL68mlBAWaHZghDJxxSv/o081zMKpQ57W8mk5a1usPga sIqwN/CBDmYe
NTU2h9awJS8Y4XKy95D/0PWIKkgnfhn67oNeZFgSL7AYoMqLb0YQtLmpraDY T95NqcwcZklg
Jb7LMXWnycYfsg6iVW3l5NINK7C2wvnpoACzLPYyqtDf7fGikbBNiG6qhzr4 OQgMSu4DxINj
XBysGVDRZ9/BUctJo+mFC5Kv414e6PpZhENof0SqQQKtiIhUBgVjKWO+XaDY ilQbZCK/RLaR
LNW3IymLQ+2ltyUnrM1LocqL4fFhI2x7XrQvhNWnnaI1bZMNf7zhYhOJrM+y nb2lHiIPPVGq
5i/gIUHvtWjSOH8U9NBdYAlpIjbjVmjch/jtzKjznFMJmGnoFfWXjsk8SUqz z4pdt9hXFPiQ
mNL6uEPLeZerqD0t5Zy8wPWiR6Lripv5PfF0/CLHyIeDhNyCIy4OU8dX0WV1 ibVbVru6EePS
69MJB4oOUkkGfaqy37K9e6PKQQRQXK2qb7ZS+hmzBmCHWHLbGcVdwA2dXlD5 9yx8AZTQmLfe
54yv4SzSPBrsGdPB0Kk85Ewm1/Yu5R9sK70Ytv2CJ/tjjDjJZR97dYrN7fVL xZ+nvjEgJ+8z
0jCV3/8R1rBc2iLVxnBw5lnDx3dcIzU6gagHgSAWekB8PmPJePY031IzLX30 KJ9AtTeoQ13l
jHj+4/lz03fdzJbPR/i9BGdr4d8PrTmjJPIGGwWz95A2bx4E8gYLQdmT/awi bcbT6hW1T6eC
xRHYJFMrjYLKDPxKonY90yvl/l8bj+Q/kMR6OQQ3RqQLuOJHaWpYFqbp2PA9 ZzU2/UUnnqPw
cZCO/LWZoMEniu5sVZc0vqVXVi6BC88FvyfsAkOmKll18wRfVGWaWQRdydqk MB2re2lRDL9I
13LKf7OdOXu7oV2xgX9AqGwxGspI0gE0UvBypYe+6JyDftInfy9ZMp2q7VFC M7spX18GxLrZ
EmRW0zUZ/kHPDchnToxX/CmJp6pn9jch5QIS1r3QizYvp+49M2aV2LQbvnZo 7mUh520bJaFS
Sybo29+PU3j/UbmyrwVqc1mg7U5Kw8/bkBj5WPsjKCsBt3GE1I77Qioy2kqk l1Lnl5OwZu9t
07ugqh7nnaTM2hbLR3mxkR8LIpQLtFRqk8HMI3nhHCEcLYvHPD2+Hu7Cloyq X3e+pkiebH5d
cXaoHx+YwnTUA2UrOVHyWyNhRpEci5aEH5JMAl9fnP90/HagScE38Y0nJP4i nuCImPuPqJhg
hSlZ/acR29m2J+LVovQuVgwuv/PLzO8iO446yB/Uj51f1heNbZs735tdFbxA F3e4Qg2WpDDW
ERp46c6tWyK6j0T8zd+3XSnQXXy8tNHpBsmg4Wg55T99MpbEv0Q46ZfawqOQ DdqT2cp6w8Jr
VT9+RIcZIRM5X1d7QyM6Eo5ePQ8PW83Iv/iICwL0wVrz1VOZ23Q+ic4hX9t7 bC0IMOl/xpBr
ZVmMuRv+fff9U2sz30NjzahK2XDabuJ0fsZlNPuYQh00ZUePw2sa28OFznPa MTd6cUbVwdZp
+G77S3FRzASxthRP2aHzNSjFww1abeLd8zmtlI0PaB/57HE2g+ZOWzlLs17J QX4MuCQqwaFP
lJTYwvWHJ+b3+E2ZOBVERmhP49MgPMNqucRhx07cTNqrUAF1IWIFit6Ds/ts JE2eFNoawRy8
iF+gPx2+wLeex9DdIv8pX61TO2iqXYJ4KHJ2n7k/pIhQsMfFEhWmM5RBKhx/ LPQ2XDq/8j1o
hms8bhjcytr7ncds3Uqxfx6PEhWD/RAqgDI3elLzSS3EmPdyVj/vFCn2jjZD ISnub8pMq6P7
hWgaiujRU+BYeMJim2eV1cFaj2D8e2zm9Ttw87O3gPPXuKjK4ySqLhEifOkI TH2jib7EExdE
14dmUurklt8I8kda8ksEJVKakrr7KVDqqVg3tQE7tUE3DSMljUc37aUwbXI3 vS8LfUM3o0sT
1kw3sy8N42U3C5CWhbqHjTEmRLSHAyXHaSOfz9LD5SJPEtLDIy3PXMjdw1cp zz/T0yPfI3DZ
86W2R+hRnoe6l4+jVySrR1Sxl9u3502yXB4hIda7/wdQSwMEFAAAAAgAdC2D NGiXWOtlDgAA
VxMAABUAAABkaXJWaWV3VW5kZXJDUm9vdC5naWbtk/VXE4zbxhFpkRJwlHTD AwKOTmkpAUc3
A0b3NkBCYoyuwahJt0in+AASIxWUESLSCAoi0sL2qn/A9w94z/M5577u69zn /vG6dPS05eSd
ronu3Dgj+kP034n+u6L/uv7fLPdXjR/+PhkYGPj4+Pj6+kZHR8fGxqakpOS7 3yjwIC7yJMF4
k5X4UpQH3KoMul0TSlcPv9MYwdwUCWiNYWuLYW9/xtEZx9kVz9WD4HmF5OtL 4v83RbA/VWgw
XWQ4S3w0RwKLxY7l3p9AS0/my7wvUcThcMu1misrK58/f95uNfr+yuL09PTs 7Ox82JEw6U74
4EdYDSdsxxC+xhOO0whnmQRCPoFAIPqP//ifEH4dlpRU/E7vn6wQiP5G5rf8 cb/hviD5+yX2
R/50AkH0XyP+4/81/7sRFHiiKAp23aaSgViKOyK22KbSNwg6Xv0i3eay4WSA tOcytrl8NJ2L
tMWylFiLmpXbrM52rAWsy0xiWKG221I1VSgnobAwll2tjlZ5dnl+n2eInJYd OFRDT682XW1S
vqf0pX816Z5Si5t4zQ3ilCrVIn2ORx1iA3XEw3i1RybDNByC6+Pi3MSa5DTs zmrmXh0vHYq8
51o4EnlGkXEKkZbRjnTRGzFpxfo0bCxHLuMRBM+VqybPzdFYUkz/gEbNbgkw wtzDxGTfFevk
Uo1S7gXufOyqHWQGXCKQbKIRxwCjiHNqTkZAG95A8dRrpzF/B6OifNi/wu9b dNhc3nt2IBWB
NzAxkpT+PNYoLls9jQ/93k6ms8y1xou4/nXqcJ6hFtn584iwyLwats+kCzKm YGUcvM11Hv0m
lk5l4RktfVOHbfAXJwEQGGLntorYH47+QMbqGj1AymyuNkDCoNnUf5MRTLae IoNXe0hFK1my
kaYkdahGdR8n5JoqM7Q6mKkrsDuo9xC4u5ltoi28lWMOgmyh5FPNGbItQ614 DW6OaWbnud5L
LDEmvcHP+Fg7tYvREjwij1Lvs6ucA5GEnMzZkwCHnFworoXdY76fbDPbBg5r 5dnBdk8yUmgq
O5fVs2iW7EvJmEIBGkhxHBqBKj0TRDyj+uJQkstQV2rWlwpaguA1KjusvZqK ZVeD2rQQnhoZ
VXsYX9JrZtuAYY685fj0xcsiV0CYx15r9aU1RxMJuPMT9HO87L0XRLiC+rC+ 00WvrlnfBIj6
0QyCM/Lyx+h+NOFJ2NfOqcUl9+6D4u7sZ9QKAO64O6Bz4YQfWVR7A6i0Jafa 81khZ1N+DHo9
Sfw1wPUNQDHYJU359HxjmAXRYJKpnztZiRWqbjgaF+v8djQhB4HMoiXnqenR xEhI0NTlQeE2
bVUz3NzUz37z27Qx5lFGMTRwCzUzo88nMWtiNWrjhRCo87CDboHpu/1N7XLn DlHk0U6JwiML
8bckXjm1+Eb9KhgIchAoXhCBj9jiPbL6qOppW6xhnmFx4Ypsa1L/iEI/wKCa wM8QSp2GAOyJ
oOMagk3lO7zUsxG2wa2M/4doIaz6xdZJ2GvYdsPL1/IbJV4Vx1tftzs5905f r/SsU/bi4d/u
nVDD4YR1uqbV3L6+0j3WkanuTyEStOKH4vxpZUliPRQbOo5mflwVRMFX93Wo wx02uvQx3pHj
a6H/Ro4gP1+rTGT1qKpecVRp/bw+nuhYw19lZx8KMOXcbkd6GFyYE1XL9DZJ ppLP/orBEDHV
ktaNAxPCHtkC22oa5alCc1pWK6/esxnua4sVW9scLY0MToON4KKMTobHoHxQ prYQm0aqZ4bO
y5OrNCt8xwCK2o6nx/GGTqCyP3VASnzvpjqtr/okU1AacAjF2Gy9tGa0G+rf MwNvhppNODBZ
zaqVTVartE+o9xYAtCYvfP1d+Fzens+VrOslaihFYO4My2m1DkimgeEApEGw chKENqN2yXJU
iYxP0zrJlf9R1iW73pi+9VEWui1/UiB/TG5tUlZ6ly+H7Ly1hAnsoa9XovFN cLwo50cMjBVL
cnddBdSRxWvBrotrww1ozxzlFoxVqhlghdu5vaDTXvduxSAnnqBSuRovC2nc 517AatOgkyRI
yadBQ2OPDyznJumk4O4T3gquhbhZ590egNEnK+nELZlqjXH0PzI431QHfMTG 9wN+Y2RGFtet
unKOdKgBYcaw6B3SXVWCB5vIJBXOXO9GeteaWeufQJ2Nm9wfhTyZdbWPdIs2 a3R19GezcoOz
iWR285wZ9FE0eobq9AWF5pQP8nAkuUr+SxjJMpNCkGsecq9yHrZnlkf3k0u4 Yo7zfuuoCX1D
DQBZJXNTtvZeWivwV9yeZly8pvP9gODZXd6vuWf5GM8nXLvLPHeH32hz2t+p v1IS1dzL136w
Mp1swSEqtaWQGX1ZDyNBfamh2VNtMM18SQMR4hYkm9nnBkkz99Wks15YYll3 y7kMIWDZicXp
sFBpoWsxX5Va6Zmlzec3Y3ZNjOTfFwW/bfjegl8VbZ5tU1IW93YIqjKt1BZR 5cC5gUn2bLu2
H6nQo2yVQzYk1C1Gyln5atm0ljm14ptwLzJ6jPf3bxnXfOpFGbvKkKSqV1zK 1nVIqzmmlMAZ
WAeggxOpFNdFYRtU9p7xtYUrV3Wc6lvPW05N4BR9y9sFw2K9fc1NiFifonE0 TrwlO6BP8ftX
3NcXcZQBfYfxokp22m+lcUzPd4ptogi9clR+Fv3jIdXHm5WOEqUgrsj28h+H ck1CplXxvL72
Mc8tJe9tdNk4hYjI27BLDetThzMFfXNLnKyX0z4tY7GTOov0Uk+PlKmommrJ 7ZzcmslydbM7
uAWxYd1+N9Wc4+UsjicOsHFTWLTgkpsTtkSLza96ZuQNcexpfrzarmca6iaN aeR8ObECiLzb
vAaeg/nJzXFstw4WtO65TWCf+J2q/Ws09CTC7xtQYSJ7wMr8a6xhZQOBaqaV A2TBqq60btpq
OYt6+oPWWcmE1S+ndsFuu7TXexMhwOIakYDNvssC3iBT5AGl8eWmT31zU/y1 SEIp3uYj5TZl
xMbTAnphMN/Q73V2kX8T2eoDrZtZ6FicTqTyxKjK9dHd6+32EK2qJpv6wKzx ozj2REbgzm3f
GcmeV2m5kgk2yg5PoVmz58XsVWt6lpJuBe9DDoJi58dArzou19+VteiZ+bwN aV4aEXGz38NP
i3hZ38ThYh8ufMyCeKQGdcynXLd3Kkp5/3gcus2m1zHWkPoT8+tqhw8FfKdq ul8arvnR04j/
EfV0/amT6XLLqxf6Rvv0TcLHvRuB3S/jeh9o78rzGUCh2W+YVZsRT3WjBRJL bvuYiGz3ji4q
i32Sm2riUg35tl1VgsXeEv3JwL7pQ0IHDEoJaCn4FFK/jFrXAu1egQ5msk5f 1ntpOboiAfaA
0VcLJ9PwTEN2m3KVJhtSxZdX8hxY3JTSHP/SRWBecmP9ay9FXlv/AZsnr2Mk GvqkUmynv78G
CxAsHHevlU5AsvMnRpGhawWKvaPvjqh3DhqfkgbxcZp69m8HTrHgu+++2LCT Bisrvg7GqGDY
rq++GEdh4xojUxj7rinGgO9mI9QqJaDbrX1mRqNTGdaY3re2UGKNYd9CqM9h h7Au2OBXu8XT
TbuVHbMrt4eR76E3oAGvELDieP8367BV1xi/eLkyUs/5dUcm2fBLV88anHsT 1LhlJ8bixJMF
5kY0JyEFjAh4H0oEdFy3MJ1z16XfCoPv+Hwc5R12U31P7rMpqLdNHmWwEGfU Jf3tLI7+R6Rp
F7MU2vrnXTM9CxmzHQbzjtjzrKh2ppBNstBjFD1Ilt7yrhCtnD4RzH1vO4QE qzwXFJXO8CCQ
PM73i1sUsx+lnN8QIvYBDoi18NuShuJVOqLHdwJXXRB2DDHJwJjqNaiPjIMA BQT34AHaBRYm
C0ureewIMHiKg1GdwfIAcOcQ53c//H+FwM2hMc8pNEqFkiIStXh1Az4GJhUA bArdwj4jHF+e
g5BnyWFC/OxnTuLo8GPTcDRa4SQ7vKjG6cA8mlcwlTg4XlI7tl1AcqYyETov r1jldXXiMiOk
hYQlOp1EEAGTOWdjUysTFjvBDxMfy85H+SyEPaWPvMqO023xfnKeTsSSkcsQ T1xLZ26ZQRkT
fDIaD0VHmgjStQ6FnZ8H3ZCL9gYGQ2TpvCw8ZGvs3C3dImSRTGiLys6wSe0k e3DSINbe6dj7
eZ44fxc+a0AuSPRLwBgg8C02TYQpgt45ll8e2oTzPhAKohCm+1nDO5yQcYW2 0lrMMbrIKVDP
MBFmEGuPI63NqBnK0LrIYOAL2XMKM9uMzskSmw1JF3mS+RX0RBaX6NYqelWZ jc7JJG7OZJHK
xsE0evLA3BDWHA/DNQqd9TIL/JyVkJWYSK1TKGUKWW6eP1xPAqJwH4mOWYQg 30RwwkEPxv6R
lfcvFsocgeZbD2cTxQZWVNl0jgJ7ZtG5Mjnz8zk68lYm3TmPnFFmVoUd8kGm 8ijyi7gjd/1b
emaac2DnGqZAYKKTFbSEJTmWJe5hm6GHMKLG2fmDJT18ITinzTDw4iYbngVC Qpw27prIOpo7
ZKmVYUkXziLKS+lq/MG+EBexIazKoIfhc6WL79ZEjIXddQvnWoBssDyvy7// hdGTD51cnPd8
Cl0QWVY0X/vsHnP4gWk0WV1SJc73X/dUAvI+f3Wq4GiqeCdGMi7CbzSBGVh2 NFSgqqvy/rRA
D5nwifx5In8hHlYopVAus0fXTYnq3Y3r04uyoixqxhYJWyavadsMjUXdlk9R KwhZdcmV2izy
l7N91+3+fSwBIeiUH1cceW5LhXaZ1kk8FcAkk1ekmWPeHfsx6hp2QJ+Jyme+ f1PB02Z4cmFY
czMQg83aFkpW7SkBuNKlU97L1IOFsJbeubBWfxGcQqNQnSebGjKe/NYZSY5I ba0qHdQpmKDI
6RJIi02MHYGW9ruU6VflyPFY6Vql68Ot0EzlDwrq6qzjZRWCb9wgUvw/UEsD BBQAAAAIADss
gzTVnNiaG+UAAGXqAAAYAAAAY3VycmVudENvbmZpZ3VyYXRpb24uZ2lm7LxT cK5N1P65kx3s
cMdOdmzbtm3btm3bdp7Ytm3btpMn835f1dSczcmcTf1/dd3dq7r6pLuu1VXd teoWkxBl5zAY
AZ2BeP31P/j/7+f/v53//0Z9/7HVVzpx998QhbgVo6wtk6wdt4ozj4oTPz+/ mJa7jL6XtU+a
v79/QHx5VGpVakFbRcPI0tzY8uPPxfvP5X/6+Ln6+Ll+/7n++Ln5T58/tx8/ t58/9//p6+fx
6+fp6+flP33/vH3/vH//fAB/Pn5+PoE/X//p5+cb+PP98z/8+j/8H/6/8fN5 l59f/J9X/8dM
P7/+11P/Nf8T/QfBO9j/zqL+n+Z/ciLs1//JiP/D/6/5f8+IP8BfFsYY4nX5 /QEo+H+4x+oK
BsMQiCSzxesLh6Og0HW3xuqLRuPwhSJxJBqKx5NwmAq1x5EKBlLxWGSVoRpL p7MgLQ62xhvL
ZvP4gxSXKJrMIQpFoSaSw5krFgtl8iRzJJsrVRIUalumNJ0thGs0B2PBqFoA 643mrT3SnYnU
8rUICaDpMH0GOi3uxwvdmwl0O73+v3/HcLYS6PUG6gywdKwVaAeGE5CxSrEb H42nM1ntiL85
QswmbQOtt+7qj2ZDFHZLOtctTMYqLmtMqz3xr1fanC55O1r2LNcaYGbx4D8q zfOKMTNbbORf
zmc7IV9fpunZnU7CCsR2Z3jsF3c3aoFCs7m41/e5406yf2t97N66hzuLvG2y XN7vbw4nd2d3
z14vfRPI1n2Sq0+VPSFo2Hb8Z5/dkH1AI09xXOBVzQvkPY/F9gPXWNRXPLgJ 1Occ9xzedkKo
Bcbyg8kuwg6i6EOL94KpRcd2wiBISQgFMCHEtawrhtWRfCrn1Y19wtrJjxKl eZmJEp+b0bPC
DAPaFmMjWd6TU0Itzo/TcB0qstJZDcazMvRn0ohEWkvOT7Imqs/xM1jm+ftz 3E8qyHKhr89P
8/whKM/yg9EszwrCST3N8iJZL86K4kUpz4uTVS3PS9JNP8iKMl0rKcpyKaH7 y4tTLS8qyksr
LyoBLRcXVcC6EcpLQNOK5WV120nlZU3Xy8VlbR8E1VXdEJoVdSUzcdVVwxTr 5VXjnCjVddOS
qtV185pp1XXLluvldeteKNVN21Gq1U37WWnVTcdVy+VN590I1W3X04rVbffb SdVtz9fL5W3v
L0jquz4wdOu7/j9kgLsBWLaru0EEsak6cBQ1a4ZhJDPA/QiO29X9KJxWfv8Y cZo1yBh5GeBh
grr1yrGR0K2uHwJnagoEAif7iubXysMXY5cTxWVjkxDyte38LOF09cIu4zRg cVnw+3Hp/IGa
BU6tkboBEs//DuQPnj5+ACSnkFTanABMztW6VVm366ZQY0zzphOXVtPW5EQM G3DL4hbOfktd
Cbt1N0Auq3nP6dPGpcWr24Z9e960u60lTCnH4TBJDL592xR9p/14IhJH8A9x OH3gGka4POup
3e+djo0aSPi3K0svoPOV+OKN+3WXmq3dTfjmTMe8DMzPU0sH9k7jg1RQDeNi mNju+3JPEfUD
OEm6/gA4or68IFSV2E377NHjTdtCRpmd9w4grffz/TZO7m496VKH66n7Fc5r 90Or2u1nujDv
CijG+9094xJDpQ2K3MoFOkHrEESlf5UNybhXL+PgLZT1Q/zGCWEaH4jW5v+b 0j4QmvvXb3L+
fqiBtCaIgdoAZGX8q5dWjv32aZ8WoT3w6ddWTMI7X+DgoMF7cBsfeoNdELu3 /sORWOdRu10E
49UeiNla55vCnBHX0PZ9+ljPL8qEyMvP9WcM+gAIbXxwSnEimO7yfrIH+ghN Z0LsVnURKjy6
0B/LA9AAct4/lgl2F1x5vwJOBwlBkQIVYYkRz0n787evA6qj8kFq37jFPxyi GrPwTyDI+bki
FX5Tl/eBUvYFotbtJVtdEWJHrInIBDLEV0aXfA24C+Od1MfnFeXi/qiLSdHG xisFF8Ddvk2g
x87G1H+ZAKPVeCQ5pTNyow8YzN5F9FkfjQi9+mFI86fRm/LBacVLyPzSxY06 5GOdiclQSqAm
/VkS4pYAh381zicNTW985oBTBOhWGrKuLQ/Zzc4kHDkRDd4j8bnP2YScOWQN mH2/IJjiA2D1
8YMwwh8TXQZP4cig/rVZ3BW1RukDsSiGYnSddDsa8+Dc0oViW6aLlqyJyd7L psA47dPDhY3J
OCoUEoAPgaQxpAIEpotpnndFGTjaEJdmC0muV4by3eSPgWxLuyLTOSqdKyxV p0uVns9VDw86
av2a3JUfVgDTKoN/zROqDR3P1fYxVdqnkqsdG8817tNVuq8Tqz0fz7X+cAB9 SKm1ASxWPYXu
NQP0ybURTlYtQqoM45KPtQnNlwbfmIxp61CmCdnnxnQbqs4lycm5TFa9Vxzd kZaV5toQG2vF
bmAFvohnb/7AUrkzt+WOeQfHegd188kCyeHSBfNAjqsJLjhNSzSVlK+vrFEh Uc65fFlH84Ci
j0MTGbfdqhRRT306ndDlwwqnrumBXPnotzrTPGU3GjR6B1Zf7kvbKc+djkrO rskJL03FxvXB
Yuq1M9kvpw6tvBmU4uDflT+2myObjG5pQ1J2k3NmmzmCyEFgpf9kuMT57z+o gomo96GU2gb2
9tXS77WI4WajWB8FbvJ3hi2Jjbp26SQZcj9xDBGsvra2ZhQGqC/Jow/D5f14 F6Ighh2GRtRH
mEoVwJO7saUMAHL+L43tTUNGdDxdNSEntkltOPrYvVsSuLOInRPNJcDMAO25 +AfW0tGtTUIW
jjEpy3cDQphjcikPSbShlhDg16nfZIQYWh7mHHPPcUrA++4lKFuvqSxZnJ/0 OUtjeyDvS0Pi
fsXSVenLDPzkCWvn+7R9oloKpW8By2sUrwdWQnwVXnppDI48+izjckLpcwyV j7GTLlZ74goz
Xcy7uFxjphGcj7kwmeZ8FOlrKLjoXTqu9aY5F0Yxuw+rxefwwt+F1AC+7btm g4sR3c2mDfAT
8iaGj0vWsKZ+THCmoH6ZQbRL5QAZEVdDqhWa+tLVCm3b1j5IX1q/sJd+xBkj R6iZu1Cur32E
uLYhMtn7SK2vA4zZthG2mfvYJJfdr5e2MaCY7P2YZKpxLkn7hJqt5vRCdCMH VZUGNt7d6HP6
sZOJs9/thGZtgIy1MRFWB8eYfuE/VDuWZMYnd6uzhZb2k/BYz9nwrCabwy83 r653r0es7YUc
WdAKJ1b3ywwdwc/VHfbSB9tVXpby3a4FpZK72NqZ6+MPjBuXbt2XltXu2xLt BGbZwnU3GguV
Tc+5VN5L/0ZfZzG89C2J3bq2RZnrarKdc+e/VVmI3Mfet6hDxMwE0CpnGqoL TtvZpoaBOrhy
aoYa84ayXBg2U3rNq3F3o7Z0O/NZ73Wum4EG8PSzh1KiTIUKMXk0lVdV2V6/ lPCWU1fao5E7
FnIWfPvDpF+v34Fawy43eJa2t91Tejb7GdC7NR5oJBQyERPBMJkTNWSdjxQ8 V9LY1ivvcCfM
/XESW5PzD26jXgfodFUvfuwhHvYkllvFMiWkrk5hsoFm/qpLlkOphg0ovuBs rmPKXktp8m2u
RhUjPm6rVgvM/h+K/hvN8tplIPDgCkgiCmglHPzHhqisNjGvNmsj4hzpsmek 9NupSruqZqdo
wQukQiel+mulPvTFQn/MAq8JjZuPxXPIJLzBHTEWudVctH+dBmura0CEaci8 uX6B/sNYCzF1
DzVPD7VsC7VeC7V9C7XHCHNkD3N+o1FNd3RJD/NcoyN1c8TyD/PCCA9kp6NV Y2Je1AAenvrC
qoWCKHPEsYa7P4entdLznGryo2sJqXlUK9uIm5lDjTh/D4c3hPpzDaouCbm4 GrnEY7BEtzpp
lkR+QfojLLosgrsuP2uvulgHnQaorOpMjrq2oerKmUeuLIc7tUaqq+uOMTnN kLhIoel5ien5
uul5g/mJl+q0qceEjXqDugdGlbELoNo2PUfgMHtkn7rLrjp3hkVPuSsdjyqj tPFjiTrf/bGb
IxEsYDMsNjPcCDdcN5WrerVkQPPbDqfLQHFvTDM+QbO+O4wwOIkWJIl0/BOC Jm78R8PorSg+
qZxe2tRbDs1kVs3YfsnHSCyI7iQK3d0P68z0tTg+Udj0LB1oZe4WX/biWTwW q8kW3P6W+M1m
xKOi9ECa8JDo6zXi61saHmoWUB0W8yHiR57hV9Rm/oLuTTPid5tmYm6aguCR xE7hQm5uonGi
czYmkteSAFXkXwwhC+9u3oERIC0RMOdm1U7iw0Oc0lHqN7wSF59s1TdqwCUW GLiaEj0Yr6jh
96c56UEtHjLJmnbMmiFdlWlNSSRcoQE8VpJF8f1Ui5ddgj89KDZMOLMtONTN GLfUeLYl6Io0
fULdA7xJeSVU+dlUOcvYuTrcTHXNrgoqdLI8s4uCQc9dw6AtpbzZvlsje8Qj eywje6I9e2o9
e+Y9ew4zZ8sxbEEj52otjAwyfAXYnmOlHk5fllNDnn1Nmtw/lkNpkRQJpZry 5lRH4swunsXp
HiSR7lz7nnmE4Z9CnKBopD1cEnkynshEFuVRBlJ06LLUnBqukW7HIRuqkcgg kmvGEh1O6mb9
njd15gsqqebJpudjphfuZPgjLt3pHo39x/0bskDmMaYbNTbuVOAVylYUMgHT siDjJFbJPE47
LI6Q1ZNkhBvfM4NA0hWEIq011FMCM6XezOsj2LQnXbEtLO9ToghwpjhTknD+ roJ7bjyWZj9h
FqNVGjVObAbfEQz0oHtzE/eQSKqwMIOLSJ4PLgzEtBKw8M1izfds8fV5Mbt2 SrgfLZbhSMH9
Y/DYmAikkEihK0kp0kiqhSxzkEx/QLfyDEmFLU+NlCzucvf3hU4DuFUMq9A3 ogWuqpWgqtva
QaarWRbovZcbRfpSl1vTrVkzjvGRcmRsoAVTQRc7hGYOjZdLDWZMkOUdYGS2 Y4kkumceimYr
aroclymxfQgkeGaNp5umNoeMa1aXpIfoq5fua9Aam1fvfFTvYdUccNYcadac eNaccYYtZdRc
RTqscWhcY9WinuaEYTitehb8hizYoKw9FEw7o1C7fNcUIAt6pAC8mVYplmrS VWpJjKVgEUUc
DFTBdZr2V4SNXaTYVhaAUeroobsOq7supVWkTuigY5a3EdVDUBRksgVQhwIb iFt13yxSbZsL
vNX0/MSKdSkrd15L3DDTGSn0TUfc4VEA8a3OxxhFIjDyT3+iNj0rHf4knb4J 56JXcFJ6Eqt6
gr7nx0PEP2U0S7c1w0vRMVcUW2TGZ0gALhvjjbDTtDBLut6rfDAr81nVNDy9 5VO9lSBaDKFK
STMqabSyjMTLF1VbeNtLUd4bMZe9+SLKGS4bKMnKbsdKZbmUhSPKrtUqSDaS psgaQM5a7U/b
jlOiQiLTVCpcbDaikMZiDtYrhs/bb4daqMplYM5kkilDUy0La7j8HKACDo8q gqErJSB0/40F
cGolapZWFHtkt0t1OMHUVW+k059Zn7JWHZkGpQA9qszZAGJpPklS/j0fXtTQ mQ8UmeZSmdnm
PuLpkXuTwZ+SYSgedQcweddRJXMdWW8XIS+TtTsfWYucvYydGf5VvaDcfWDa fRDefX+y+6C7
+obba2C/+qKea0h/96NYqz95Mr1EZq1d2H9o9iNiN25fSoN4Rdxo1B1yaeVm 1PG11MFgD8D9
rv8H6BmA6ghyry9Ir3furIewjPoDbTbQkm8Q7Jk72QLEZsDVLliHiT6BbvyR HJwl12PhivlX
mVbnGkOkWZDBJc9/NBRYVIhiqn9wWdiNGjJDWdSCXSOv1aQoFZKn1vyxVjT0 WMRU0b7GUuzY
1a3GUc4r0dIMETjDlghE5Bg8h24lpGz9qcodWjV2hUm8I00MT+sYoypVC7UE 8Q4MjCr1wfGy
uojLH2n76egNYSsTd/Z1rfT1dm1vyWoPbGn3pion5giQ6aQz8/Qv8CzHkJyw xZ7Mh/WB+FNR
z2WZZGlZke2JD506AJlG0BaATz3ZC5PavCUn7+w7liUddFWu0V75eyNwEq27 fiMzUaN73a1b
L7v7D3bIPQffbpWtPmxwtrusUlXwRlTQ0UcP43LJbbQavDRHO1T2+2X/9Hiv rvqQgRQH69Us
hM/cn5w56O452O05+O857KRZBJ55NeJ+crF5DJ15LHwmOrXavfbYSW8Lsex5 DK0KrEkWXjJg
XfpbLgRV7+N5RALZ7OPIMBj7XNC5F6BqkkV7XNJjhEM7v/msfv1PA1RmOsmf aO+txTZOA7HG
hpPlqGorNxntkLmxAlapGDHN4ZCrMmLOSrOwNmj0plSoLIPsns5P09uTwjbj FcOzcZ2MEUNr
/pL1EQLT5s+zImXu0SrtUZ2oRmNAcgCU11ra0hRMp+96cZe1OAzH1EF7ZLB2 F2X4bMRVgpak
rk5lKy93qSTbELd6/TPj5C1VK7eHaajEUjVkm+31gN2fdiOK2GJAvZvnhFhE O2rbagTPeI31
VN5lpytUSr8WW+rqRkV5W+VmU8V07KSUV8RIZUNW6sBWyxAgrQOoY2493ikw tUlwuRwKPd3o
VgGzUeYnMR2WHTZuU8Iq0z7bOV0HndHwMW2JO3PKNdOvPtPoMtOQOkPSPCNU XlW/nkFGbedQ
DbiIzuiWmJVaBoCNuDxXzWJ7239LL8T/mYs7XieImeGG28fI3cfq2cfZ2ccD 7uPjOSDhHhD7
pvq6z5PkHpDOzIeG9//T2a+8VieCW4C6rj28ViHaygXTcqahAeSU1zHw1MNK LfI77RSKHDJ2
VQvz+oPDlcfgqjWt1beyF2RU53dirEVIrcVTzv1lOqS3/S9uWB4fSms9QlZa VrgqmHAa1ZPZ
0tlurKMO9DscjinfZY2cstQ+pa0uB45OZ9tX61tFF71djXBHNvtOjzsDPH18 RilJthfZ1syk
2oaq9PyjK5LQcn16suNyAtcA9ejy3pqerdqZrf4yQ9VbimQRm8aWJ2GqG2dU xaxjQeE+w5I3
i5l4EwlWe3mQkqXWyZ4dkt4dMdlRJtnVpoCdi0Zbq9jU2K2S4ynfkVFZt+Np n2mYY6y5rf6u
1ALqLkmfC/ed1O6q0XWftNmrbROKUS7s03CzI3aO68GewI2vyjiKvZ3oi6aO XQgpm2Tp4ArM
a4vu9SMpu/vNmcidsZitoP3oTNjP7I5Yjj+++3YsB2Kxg4zAPcqZUCTaQ1Dc 623Pe7yfe/x/
D4R8D8R6wAfSW1okvwfKPFo0Hka6ngf6OBr06PBXymrQslryy1u5zilOO3oO 3rp4i4Ge5tOO
5VUYv4Hn8Rs6wBNrbQOJ9qXL2lHR5xFU+aAAzzGX6Ybm7PWgTgOIa4PN6ZOs TrSh7gsyxbKJ
7LI8dYylLbP1jZUoXL1f8pQD/GCD9KkFzR2maewpht1aVpMX5tEVNYf8bU9W 2ikk1Rm32Jna
ZJxG9eo8rkRU7qr71ZlLRnFC7jhNxrto+nPX1VittiZHzJFF27kp+vrg63nk V4I71Wp69/NF
7l4Znpn2zlJ3zLjyujJ9u08c2oZssougdpmBxHNJ3OUAz8RA3mD99aVt5UQF EP1j1HuwsiY2
EM5M6WfT6Dw5p/a7o5qjke6jpSf0xva8M/a66XMrHe/d3Gsz4KPM2W+J7Wap EKYLN7xTeSht
5qtCq9tisSvGiR34C8R/hD8AFApeOF1+XzAUDpc3GEPhQDgSisY8HeT3CCwm o/5YuME+wa9E
Yiis4gDGkvEkCIVUYw2kgqlUGIsa6bfE44k0GrdSAIayuXAmpQEeQKMRXy6N y+7COcL5fCpD
1mhk6pyZYrEa2kB0G9rlTL3BZDpXJEu1eraCvx3P5fPpRLPD5Rq+KV7tdqfL REXwy0vtTn8A
/rcct7b6veFIDC5fKI7Gg/GEIDJTl7YG02G7AJMdsObzmcl8oUQmTzRH89ly pVqnNxRX68V6
o9lmdyRH69V2p9vnBwJP+83+YDjmn1iu9rvjyXTO7jG2zpHTxXK13mgu7oEI 3Ha3V16Nzpf7
w/H0as+awSAE/CWH/h5C7pV55anMotznIoPv5/c18Du695H2oe83Au+v/t+w xHf8vFMARkpA
XiZSFdV3/EVlJXT3glzfzgbS1OAc6yWAd+rL65oq4hcY7PA18x8CMCRhDAMB WGH7OapKT85y
MryAB4fRD6RFaCHYTcN7cUQ3Lcdy0mVPx+p/VZZnguhyj/QSgzXOZ4UwkvT9 wTCEffnBSI6A
heq22CUFGQIvbyYZ1tVgoBJl1oV1dXmbZLJVReDHFD1FRg00rHzuBfW9fA3K cbwgaxnlxAQr
WXeS1PIvZhRaMZ+GZAIYWvv8QGRK91+/UeTZQaYlPcCkpgnDoh/lqPzAopbV rp0fF3C1lpGE
+Q6dXRTF76eg1P95lDCLE20ro42pBm0/CHNwDSvOmiSAMapaoj4kBkBhteGD o46oNKvDWbEg
rnI0DjfOATiXWhRLC4+od7RVohG0/nBxQ28P3rGkbXtwMCNuAqDhXSVRy1Ja 920ELlMW8UF0
Uzei1Mv1A6DV1QPA4yarMVYpzo1VNxOculd2nNVkq9cTmqdSVREoSpxOkhF5 M/TT/kmrH88z
Ajujd8J+kFvM2InwMkOjdN0NQEv1zAvA0flJkVZcl32UjyM1Yl7X/dU2NYyN wGdWLU2KIufO
AKfGDFctMrJsZm6HQM7zCcIdDb1Urm7yohjOD/LiBGYVDEESou14uSpQVufZ 9uAT2Cqnv6v0
pkNUZV0niSRbS+WEn1tLDlO7nmzyLYxuKoqd/4rWHDSstldtz98eogjHrm0f XpbdTnksgM5l
rApD7ujVbodxYrwex2lmPR6neWG8nudlZT2el7WjvF7XrWxWL91tkHze9xmH N523/Hh8Ps+r
aTQ8r1tBf79RbczyTvqV6a5eP5KCNDYKoJgRAlGG8J9YZJ3RDrbOgPYLdcKY 8gHkXLHTosyY
3xqiigKb/3TQVgo7OKYM6RMRY6yDixLWpOysiLCbwoWrCrsB+n1RcLBFJBnQ qkfG6MkG3w3G
fHiaE1L6SMgZU8S9VQnUEjcTWlDroYK11RRhbvPIIdAm7HwmlqrBmvkHlCgi iwS0zrfQOXcv
of2wghUKWk1oZ8aQlAoJE8rlhIQN0eIlWcfVAX+yiIpiMRipry11yKPX12xH aJveZ9V8g9G2
I8OZ9KfrwhCoD9WZmxm7Q679sNr8W/tIaB0RwaMvNojwlNwH5RhpE6KDYNak 3UeELmAov7CS
c4DLdEo9SErROEdQKWd8f0UVE0WItufNgeNitDrURtiXa6PsbZV8JwkRZbCY O+ovdKvqDX4m
SZjEtyRSura0IUFKWcwRy9NivA4+BzjHrBEeJSUs1xYKWRu0Aect2qGLQdpU hsirElhWgQ3G
EJOnG9AWLAHryFbnKJvL/iN9tRlKPmeA4hXeM7ZYdzBiZSLtLdi0jkmSOgVn 4W0l2Va2JfUo
JZxqbdR6DLSpd5gUc+9U8ec1hdjQ+0jSFIoib448gw5bBdbhvKiusrQNODqv 9k0LxZTIVCxF
uejcK7n7VE6VStXlSrVhS9XmDpUa1+UqPXAr9WHOlX7YZjpjESvNHDXeR5ew cMsQK+2oCpDn
Okjfew4pJRcMYPs+h3JN47kenU95ACguuQCMJYI+K2XKMJ59ae6hyW/sT/7e i8oG0ET98zGL
jt4bspSHpRNeBecEjOlyUaQ2xGXV9VliPJRiWu2jjkDK7InIFnWYbSwWm811 BI+ThM7m2b+D
zKWMORW1pkVHK1cRWqi8yCa/p5FVi82RKTmtihJdliRZuKZ+2bQEdVWrUaCy jI+urLDnQS+X
S7pUKk/Xtkd0LePEsVBxTzCUQZlM12euA/iRYFqCccoSSFumdjPRu/4mbrFC 4mzauFxq7WOl
QR+dcoz3s9pM5pS651ABZlusU/StTQasxyWnp5HMtk3W7P5KYxQ/K5eQjq/r M5QyAGM9osHB
k5NwoDwNdGZiTFNxjFj4srUJTJKix+A0hZW2hH7XrhlUX9eS/1uRLWOAy61k KXbqhjD5t9pq
5W3tqNBbwfET+5415mjhOCs6A5M0NQ6wItjy39KPNi8uDBg0L2buGHYCeQ5g 8jk/K14zrSN5
KwsMrXf5zm5nZnpJmcPBkMTl2WSTGh9GkjK6SjRdaaVdT1gRsiwR6abplryt AOuZhRDrtlRt
3ViuDXUBmPBYaa5urLSOPJtPZ1rpvm4wWNtYlfnwWBtCDvu4msh9PUj2MmKl LwzjaZpKeGL/
wnL1j8DdCsX5ZI+7SO7x86UOVJHenDsJC0QHLDSaVF/IAb1MWzCEHezEsQcW S13Tfl0zbIFO
NH5b0mRNMdily0jQe0DhALhQmMztoiy3/7CFD/tU9TtfbXgzoec9WSc1KfHM wYd9DtN0Vyj2
kJeD/Vh23b7cNNnwiKS/WB/xonqctvhYbuS3xlyGFHnRAQUJN+83b5tTQgKk ML8Fk3pJ6c78
wlTkRWIZSylrNTs9tjtaeSwPHr5vak+27KUtkQZyiOk9QmgnvMmqmLRqK/pp mI4WDZATEm6c
It5jDEDcvDfESFlLu/7sNpl9XaOsfJT4GEljkT2OwI7akXdrvABGNdoDu/9u Lnsw5x7q3JyX
drKVyCo2hz1nVnV3Wt/jHps6AnMsVEIzl+q07WlWnS55RZkclXQzfQ27x5w3 OQonuuxDWHVa
4VjUTnlu3xjieN/azIgPPRbZuH7fFK73TORqYb3aQ0rSBphSbE1OywklrR5G 3rDm5WB8Db88
HVENnZ9exVqlytFG1RdbF3o1sS+AqLwF7jsPIPJ1ywtt/rRQNJ8VtE8nwVV8 9P4W7gNT7gM3
7oNw7oMM7vuT3Kc92QvV1Kf1m/URsQXmqO83V8uLOGsXY9Qvb/Jhebbvy76t ubbrrBhLZPwh
yvwRTWYxIeYxw/z4S0J3EHa07Lg7x9byLB5VIza5RtxkqSR3LV4ExmpEze55 Ixofp8agczaI
z9bjNiD1P+OWU82ClEcaFOl21C6+sz5ifMIaAs6aoUcu3IAGaiEhb84eemrB 2MXCZFC+xKyS
lEwh1AFCwQBcm03qyajml0ahtMaeJM7k2EAUmSQ2VsVaNku68onupXOOpPYi koXB+iChV8dU
CmnO4ANhHSz2LA1OEqOOdqqyFOSu5Y6ONRjG4t/lxFPFkIfEUEGVSZoiIIMk TFVcuEvDgxwC
WIldKxENfAU9yEF8SJvDCs7tvgVxu0FdqotcvEediFw975uNfVwj0sUwA0Kk 2IMMFu3DSgcN
uoHkjigNIh9dm0pINgd0fz66WaTIkJXYXY8GOjwEDRcY3omEixPY4Ni73YCK 3R7etUxOPBGB
3StBxDbapIdGIhODw+JgIp8NPGeOwyODmaxKY+KUYmiGBZZfZUdM5b7F5KfI OINj5TrZPQmW
2dza+fGKfLZVpTdSfPVvbRdVFAL9PflKovWLtBeJGXkAFoGvivPCurhMOs5C ks/PGOgvkqKB
XOBl/8jYGIrxPyTvXBDiAdR3kdKG/OeiiVqwyTqUyXriyQbmyUbhyaZsllLl yZajSljuf63J
k9UffZ0bffhfNUhTeRuZE7owAIfHv+jc1KCK1DZZ/RlM0mZDtPZO+Efq/YhD A+xTEz1beQRX
pMTFjQtIBEuEBZiOgnOXPKucUBQw43CHeV8R0kCZbMIpmAlaZQ482BoGHFoC xpr3gDHmIx45
YyFGorF/URIcXQj8FeOPQnUzUDOJ2MIWwtJDv4XVo0Tjq+hFshlFnYleIomk AILDTiV5nTI8
iQOrwRjCih1x3JyEizJ0QoS2jmOKxTXjwiJHU9OR0fXtkcMykXVQVCX2Rwzk Vw3wQp0Lj/TO
xAytjSMJjKI+YPVWXdyTmMmmXwOegFpr5Sa14kbMS1ETJHHnCqJdqmlzQl7G wikLBt5HHFFK
joYMB9EGLfniT1k5qxm1TXEX4um/H2JUMGPTTkIRVOIQXjW4vztEJ2r/Wo0h fTdMTRaV/K5z
t+6QB+O9w2nG0JGDzgGWnzSWJ0qz8QhJZCuPP3DJ5vTx3jYNVkfDJnE2gVWO pzjzMaLy5T2k
SXtxCAQpzQSK9huNnHk3yWw2ly8NXQZMlEpPt0tTVTnjAYakklDYERn4+VWW REyWRF2WxEKW
xFOWJEqUI/QnJYeXLgKk7saWZJeVOzzzELomzcCkb/alvtyl5Y7LHGHmGxCm rKIEBq9ajpsQ
hocEcir7T8RVeJqnB5zl4JukFZ+Xv41mu4pZSbakvR6nLMBk5JbKUnFmzV0W dtsEP+rbXpiH
oYTZdUn46bUl173Zma5UmJ/EgbDVsdZjpB+TliCyBdElqwEzBzhDcdCkU0Oj 8M6rPMpivECG
IYgUjhIc7ouhdrGj/Jtg1a2tGbfkbhsrhTViznvmWQSqWVyT2e8ldudJSchi Thbueops9ViV
nm17+k8wLg+kTgnl+dXFOnjcNm4o0cckOUtueShPVEOAiJGNSkOkaOGUiKtQ 44BE02rCwtbe
CNagPM4zWVyTelCXdAQheRqqvJc2O5HWistwBHjWKLpPnzM1r/jj/PyReGmW 3GY+o380WfFz
mbg3qWJmGaHNKH7MBkG1eGuIILgXcsgyt2ASPzmcxHX07ObnrBHuOOV049nk wn1hT8qVYnwi
Mz0PH0MILEuOBGewWlaXEstxdsF0xXTIVtfjOPPx+tumbLH3KnBKZ4L7eTEL vHnJREelhEXA
Bk8QVVUopFDfZXtzeHtreXv7eHvneXsXXLdAcHuPZAe4ptxKuXMUM90B2v+K IEA3pX7PoXLc
TIA6qbHmroKBo2qXtYzpjaPVPcinhbH+jRCmw7XhI8/frFOBOta+MOV5KY1o ogqCOxp8NZb7
PF1wGGO5LTNis9ayteLTsbNq38YIkJFjVI9kUlyxGgzJ0ZneKxSZBwgBhA6e JA6b1DyVd5kC
Z3ide38Q1cW6Zv7pjMKplEsSG4Sm7KUql4CmqGLyEEeCC+F769c/9VRSzdej VtYkDX92rSex
GKwbavR9zslh721EcYFuC/9u7jCaAmqCck+iJckXPGticpEW8XTBymzU6mzC ejGW4RLrRGgi
5WxWVWv2SSsYxRwQjmj+wgVgyXQ3kgzgyOzT+nKTbrf26Sy3gRcz3kyzWG+S 4O6RmRhh1By0
Y2lzB/WUxvPSxDAPT6/SHWvzdaFkULdfVGozN4sIfW7Fg7I1ba212i/+zW3Y 59nl0dEh02C9
8GFaM8F7UDm8ZlFWNz3WbDnWGjnWXjnWOTnWvemTej7Wlx1oOVA2YD0hNtbt 1DZRrpFExjHG
btFdJwD8wpK2FtK7aZbQfGa9Q2W7JMo2w0MMQ+Ldn9+oeJR8CTnA9dUj7Wp9 v9742B6QY+bU
V4QHhjRuAQ1lfmD0VVNO6DJkwrmEdpS5/7siQozUYpFynjMOaePKZk7M5mav gjuZo8uYvRzu
0Zf0h9jWIbTI5mip08EdBG/LwKnsz15sffurR07vpzYfGhcIaw+JYdEu5w9R xMYsCJmS4ZFq
aMJ2MgtqEKhqKJpqIMHN1cjIk7RoXCMzkPnSONGIRsbqRsEPU+Bh4OLRwNXJ UwNFTTPNHJwt
o4Z2UbgO9J0tvJNaXKUbpha1KqhOtQ+10IbPcUMPqRYPmlz0m3vI/nXLVIXq E1wbMS0qEA0b
HCdllQ2P/fa2Mks5Efbt0TA9GsyRuLacuvQqGBpf3pUWTRsSvQXfLmvUJss9 A0K1WHO4WHE+
q/1dMY9iMFlV3r44V1LhPal3PD4uMPnO0cfS3F1bud4+ud55ud6FuNlDu3nR uN5ntR1n14XD
WD40vWkul1LQOVnhJTODP9tr1twkjbsimbJWyh982oHaP5EdWRbjPd9cW16h KfjVvyao0rcF
b/QSO+1yMkXqfDoLO01ubYk5o/dogrTUtOJKym7d3eczs9f/cGrPs4cmof9V w/4L/Ywz9zzY
Vu2edlsZ+rrAu73bawU/6gLcWzZaVNpeFy7Laig2dChuxq57B/VG2IGe5VyA tgO95/wbQIKv
02WIO/2Ee5cJ3Iz/zv/44sxl1ciDP/gIZSasufeKAZogeWjMuXaU6VqCydwX +x7A2916FF7I
9xQDWLuqZQfrO+/zd24LfG4TCa32mKzg0LSSiIVPAOZ/6Y6enQ/bMy+xc4xQ +cy7Wv5x7lxa
+KjzqmITTh924Fp/4Y11Da+y61lc4f09+cQe0DnCMUu9lNSmjTmaiF20pm1K z9QuKReSGbFP
VyVqr1hXRHeogT7mFLlGta07mBE8P+F7Mr0+Ua1cV83dOLmVm6F6LX3WfX3W g3zRR38xIHsR
BT8xFHM1IjoxlH0xVXsxDrUdc56YKLY10+sE5VsZ8Oy/7jFNZ86/bRFohNGz 67E/ZLdbw1t8
Fj3TOHwmL+BwJ1JtEFF9A5bc1pXolcWe1qyI+HLLoP0W9Z5Rna3WPeMRsU57 /c22Fy61H9Bz
G/XMGLRhj6FmrvrTM9G8FwVvI7ylFg4cZAubm5x5EEzW9xuW8NcZeqqcyeZy cORRL4l5SJDV
zPC8d9I2xNRz9vDdpJc751B7/WP2qlys941CHI9ruYWxjj86y/y8lvrsQPz3 sjREq0j2oOKb
60fbgSLt6cPkILb1YUV6Th+arAqdAdyHgZFPlfZ15JvIondYrwX3Uajn5g7n kJ7WCDA7nL7i
tCdpxOe33drqBle6ARBQ6CHT93Mmw04xuj147FzxpGvphjy97Ly/5H897NMd FIRsGOgZI102
A4qIHdD4mg3jdXF6OYu4XgHQr6VKK8ZL+aZHnBdKeaROUKXhn6+qvpsCjPX2 36Tzjn4m1QZD
NNQ1LRfgNBdxudXyXtzDcld5TazSdtROe2d8kLTDkHTdgJejwKtV4PUp8OYV aCgIvKV7OdK1
vee7OXXdeXh9VKqNPWfxy3p5W5uztepZuLnZuft9O9ahQpOJoDPtcgb5BwsU HJSc/Q4f7tef
v5TaZ3cEQ+FIZIoA83vCkWgsNserswR9gSBkbFtYDqRCwcS/Kr7W5wuBoQgE 4uEYAQKgEIho
hInSHHVmA3kCUNDglspncyGESQ3ckskFgyW0ZYoiGiyVy2WwGsAjoOcz1Vqd 4WhizkVK2Wjj
n+UPYa2Xa/50dMl0egcC0FAkEldFa64mAvlyiSgk0spUCsW+kB9LHdi0ovF8 fyK7a4s5M/HJ
pG5TiHYNwlNAnFgSrc0H80qzFFEW94dHtdk0lEgDsDOT8aIKjZa93L5w4Dcs uXz2HoxmleEQ
fgKpbjYS22PfuI1ULQ/7q8PgYhbnyFYOh+NQmFktSsw398fThYAb/FXXmeva Afjgiy3G10es
I6a0uT1BCDQIlpmuWTSLqb77K4X7tj64aBmOakZMWK4SwshJmvGBBWlKaPVz Clb4ewQ7YYQ9
i4q+11/bsZzQvZK37DDIVHdEaWrlOn5wIDWgDzTudyi5ujd/x1uu1xuuOoHW 03Q4sS/1zumO
SaHB2F4cIxYHUaqGpUdC0r6ARYG3/MfxhouILQeiNF0XfUAmXdNcIAzvRJmy Ewzp6VG6PiP5
ttefSmaCEB8sdYNQkZPzU+9jnueyRP/cd/JiooMM8hJTCAsyA49MzAoh+ulf v2GZxvB/wzIO
4ZuZNGF6brqSN2ygqiVLkGSZzTucnXmsDIduVaXXv1DWVsqiL1vWbURSlY1T cmkCALItl3mt
ohU5JnOKkFQNWpp1NK3btpuINeu0USVtqobKN23nlZ20ndeBqDWdCYKjJMY4 SJf6Xe8XnXS9
3x+fdH0gMNz0wH5wbG/6ASiqLvpBOK4v+iFEKW6GYVQtb4YRzLRjmtFyyy+G MYIoHEZprHTv
h3G8uC7GSZpObnppXOs6EEgmJ38QSEotsNtJ0hM2k1kBSNin7KuBowBIfO9f gZBsHvmP1k20
0FdLioemdkHqk5a1wZLQ0szdpgoazOsjqhRNgzp5yrfBErFhN9H048JJMuzn R6qhutCVFnlm
qF7F+aqG33RbBgHby5IF4+zsGzBmWm9rJlyuL22O8yboup4C226BLoLDRwZ6 hBOnuQk/0tgu
0xMnVHWP0FpVKwMtKcWFTpQ77EOVWbhGBc2h7SzRPbM31l2dzy9a9oOorwWO acBrYHvpo6C7
maFfkfnN7J1LjVvpLk3uWR2cq13uUVZm7Ge/jhYnj4f+yCh5zsuxD2/Z5/Or nj+lNR7NxQ3b
C0lSZGitpIaIjdRGlqX7Kte1PpWqQpbqW+5r9lX2tHe8kF6P7FOVhYql/62W SrL+UD9MZLko
28R8rKdwP73NXwVK6Ow967IyAhMKfxOkva9K1A5sQnOqx3WD6zMnLlhGgBTY UHLh0BDve7O8
joWmUtYOClnX+F04InFiAk4b+YxGeLBJPcEzWhP/fQJtWBBotpL5Kx+Bzb2k sHQebP8YL2vi
fYj3YG4DN/j/vqRyKm0+FrZ0QnzIxocwa30GhohX7AMdeDo88wkNyDLgaBs8 DbqQ76nJ+2Ui
x6PspNNuXJd7UAgUE5cEcYjDWgsOXABaexvrZFSBtG0ejKktXSTF7qGTYIKl xMYJ8jRuFFMG
SI3pI9ykjEkVUyaMjRkz3qTMRRTTFoqNmWhWJVTVFdM2jkw8JEKYE6yr0w6J jdn/Iv636tKh
pi5nCbaUo8BCmLP9ylxCS3OR+I75hf6BJRSwQWjGInwOQhe+QITzveVB+5Cy YHUfnQZS4c7r
jiVty1QxLuP4IAY2geicqzQdFFxOBoUWXXj6sHmd+SzvyyPrCI+acXzhmNZ1 JZI6bWXwNiVO
7rmzFEloY+xp2ZghD50IdGly3LbS/D0ErTteTAWnXOlqhrvHgWradQ9nHyyE 4wAx7nFJtPeL
C12UKbI2gpBxoqTtlfg2hTZmTelQTudDWf4ikstY0HDy6vTfLyhzm0Jpq78g fwYB2xOJFC5F
RIjplLDjdoHokf8onCLXBh+ca64zlSmZRCaCdaeC2RcQ49R/sfQ2J4SFDhy8 Ul7y5WbSebmz
EBbBi+TiNog32IHPI9B01kh4oDR6LPtnrhWTUtiitFriXjqITWxc56wAakgu MYfX1mYF/nq3
lhhYhKmobGeGtqo3EUw+YVQqpFwoczukRGmKjfmhJadNcqBREr3LOT7f1oI8 x1YBTMdZC5uS
gHcpdG7nE50Fgg+ahVNUrL3LUlmkTqkw8PTBMRVShnjJHpgCaPREgH04p7ZB PCB9uBD1AWJS
2xApL0OkknQ9GJX6MK1v/VAPlGxSPfIIa49D75wEk8vJFRFyzYmrw1e9x8Sz 0Ysy1mI2q2Yl
pnsP0PrWCxyDS5Q10uGbEydIAmx1Akxh7LS6bnXnhTFqgabILWkBiSNyA+8D oSyIhKI/MDqn
34ImynHFXkqv0ix+GMWJ2eS04FfWItfMbNvXcaF6M/HS791W+WuRyjvawYzV b/oFKZVqjVsc
Azg8l8qhqlOVhLLl4+oYZ0kwHHUorIVXH2VnSOM9SxgenbfmZno1oDcBwKL7 OE1zbtKnwspn
BHL7znIP9GvdCviCroLegrU6CPznXKlkdkr60gx1tIeB+8kPWVnbpPBC3kTV dYlpiTWQvg1Q
MJGyxvZhDSlUMXeWidIRtEqw1qsmNHMiGqVXUotoMiFIEXUXzheNbRB5Yal0 obS2xMZsk8eh
zY7s1M57kN+v+LZwmuQcPJ1wBUTjuuYrRGlHBXk3xBQWuSLuyNqbeR16r/SV jWyKPRaCde/j
HRmtTx4JzlDmC255ROB58OSG1fXJp74UZEmrDOAtdEvvH/mp+NIFlC0sVgHI ovQyjo0419IU
fzilDCgMqAY3a9sjydcWa16aG7uvbf2AXFuHtK/ti903NmYOMdc1r918wiNM M1y7v2fdcFej
TS+f6teaNWyzaHXvwneZ+rmqQIoJOPI+vxwp8raccl6d8pVszT2x/y15u3HQ PGG/ehPouTW5
aUw9R4+LXJYqdLl47z3dVChq52jHM3rrFfLNbMpbnrFy5T6h0vFIR/m0Z1jG 3rt8ULaucnvH
HfrGPqnABuTcECBKqpSEKl90A1TsQxM738Q8m5brWU7kzVQ8tGXi1bKSt+pm EpZ3VrpTm9Ev
45A12215gDoEerBw+vdw23Dg+R3V0br7cnrVc3MCetrbucmoqssYW7c0yc00 qrgFy54+ssY5
eZFteEqI+YfAnE1/mQWoHrzOAnnzGFWkdg30ao3ue60BEX04itQvqCz4AhEb KPhdbc135pR3
la1rGQmrbm17EYUhiaVKhwS3fRU0FTVxEqx28tTv6mWslHncmC00pLFxlV3w yDVkShx3Cvyp
a0SP9/m0Csmz/a0WRNyU861ZFamlgAyi5bR5lkyF/v3K51kSE0UlgRzv4f0d Fy3wE4LTEIPO
vZwVDYxVjxxR8gOEme04qCRcxv2VbphLGUIy10IyX0Ly0ELyWEKK1EKK3EJ6 BkLKGsLYd1x2
EDyqEcIwRLy4fsLShDxmiUJqVthUzLxUHExeCkw+E7x/N2oMohopMlgEjDoS 7wfA/owcKdxk
Ws910p2Dmfjtt4j8+T7djPWYoWVdsfH89r6MRo+8yZCcHqjdIUQ96pP1IINC DIWZhifMx+Wl
sHRNeNF/pdSovIQJNQQruIb/iu738TQ1bzCLU2K0aq8JFRQWdNpnAihUFCm2 SUQj7/VVHqxR
H58OF4+JEsqxvq53+ERze853u+//lbzlVeus/oHYou3Z//gVn1+RIjWDxU86 CfqQAkzf/u15
hCKpz5i515RzeGaCTzCsGnWUDTkSbhOzy1m5Q+6IFQCVqmiqRnj/17dA6968 DzowFbqf6Lkg
WzylQGoEFQSvwPNKC97QQAyIjV2gqzFiwrWRlamT1rsORES0NUES3ELZL0R7 WcIg1T9XP0bR
1JvTIJCRRS90KVCqSUBZ2NCONdGpWbGAQpO3NZq6V/D4TphmOHytXp13mLaZ MvDm2WbMRcXD
0hdAPZrHPBxTQZrtN70oMBQCRr6xbEPZxjSb47FqGq90G61fK66KHEjVGJJA m9lB4zM/KImg
lTnxkjmLljnLkrmolrnokrmqJlGakrk5JlGFKrmFlrHOF+4/p5+bHHBFkN08 HTCrgtOTZvDS
aPDhEom46oYjoMxtazPZprE6ZnBb/ktSmF5+K0t6N2OpWQoQJDlJwfWyPd7S T2Zb0M3UwJ5c
R+O4wbsvKLn1mfeA07Mo1PgF/DZyST5slYltN8C3pzQL6oDhMY3lyQUTe9Gv uy4KJsXViClm
Sh0pRMUIsP0Xp4jU5xPa5lGOUJjwdK0X/FUcAaFuA33+xn8UJ7kh/GDqpTgs Epn5aXP0uB4p
d4EiDkpaiGkKPN7QLCQu4M8HUCwJHmye9Yn5CJxEyBuEKVscYhyAhOLD5lok 6p50HBk33B8p
u5wH82IbQJWA7+Qr8KIpOuqrvMS2PJuVpkDGohkYrBQnruTbShzbEEZAekD9 MTGBpiVUy41X
68FWRypFmdFDqVzpXtdHJaX8JYjeAr6ZDiDP6kjoUDF/Ho6varYsXSAJydx6 8jcqQDT5Zs+2
bx8HIn2YuDgUV+pqI3OWjliQK49XqtBexH+VJCgqqPkQwCZq/1BY1MKvaIOf 5Bda4J7D5XHO
Y05smdbsN56dmp1om6+QWhAWLROfrluo6TxDQz+clFyYvsEVWmeSljjovuJa d7NulB7vLI/H
mmUiQRcuRPUR5PQM2QkeOCqmj1SWOZDihZxXsaiKhHoAxnOpJ0oBEzXUky2A yZ4rMluyqRnr
Q2+ziTnqmUI4j51oD9aDkUyllEhrd6SMQEm8Y3Ajb/hDAhAAA+FV2MQlGPyV zIBCM/AqJIJU
EWRiYGR1BVTR/wFvkvhMk9JskKf8KkfjGsGqbqG81aQ8R+Wi4lhWgRN4EGST EXpx0RSogqMi
N68bzcW6MHxQ/DCeHAWKlV6YyZu49SRxqcUqtkcay/9gPnBBkPxscARqcWFQ I8RLwZq4Uj1y
lBBoy72QX28JWyZj68NbI9KgJ5qo6TpEvgqanQZvgglnmnVCbkF/gUi6NypQ EHhWY0xL6+JB
OXi9IRFJotlN8SCKDQ9XPFZ+Et2C02wYnceK3wpBebCBr2F4HIeTuqZqda2j 9Ugu/7BQo4pn
InmcttFTEIlkkclb1exLZa1iOYZx8Tfn1s6lpLNd33LKGLah+vohM9dkq2qY LuLi/MyX1rWe
KFHx+NzgoPSokn2FtkN360k1uh1C/9ZkChlIQuWQc9Fsa3GHZNm9b155QNuI X7ojuWq4Y7sT
eQe9qZuSbzVBglMyQjSZc7ykKQ1xqX8uqWtaSjAtQIs9YdVrSTsHZU0MoihU UTMYqlUlfj6o
mAPo07NU1ET1Kp22WbFesMqAWIjEIfoguJePQFgMvX5vEfvgoJM2oXYoJBsd MJrxPHA4WCDh
ZLBMvsK5Zfj3Wv/vhwEfsgH/LyPBaAg2OiMhUfT0gjohWwOhlf/UlbrHxgHT zR2rReZcB/W8
5gOLzA5P/+nx8pY3Jw3//Km8q8MQa/2QOxLCxH2IAO36i7n/CVV2S2zQnRy1 z+39d9lIPGbw
DF44Xh39p9HB3C0wBP6SslcEV6/684V0J5J81/Bsac4up5B8L3Z970PjcZsI dvLsjvKGc8U+
nvMm9cpc3QaBRqyC0VGuieLqkttYsJIiYYd+C5oA5HDXM7K2xGBh+Rj1Mnbj E9dWzPSW15cC
XG7rp/uCWAH79uT6BniztvePHRTtyIM2S5fg9Zvuj2VTeg1ZnU+jTKLxsPKt LCf+y0RWW896
A4gVzvy/URdnrKTaLMNq6YPUj9wqKbZSlhdb2LBantVHiM7o7w4IYA12xQ1d V8gx1GH1L7VU
EaETg4HKGkGnDWCxnUG5vqIsldC+sh9KLejz37DrnYUzlax9XUorPeg9PU4r OSPNEQsgIoiY
y5ehs2SoufhK3eMYPe/iHOyARUbLc8FKTbah/N9GE9Uk6U7LUqxIR0Sr+6wT 9MGJh25GBtvU
R1S+FpQqPQWWa0pEFnA/rKEDRmo1fZRZbOOo+qtsBzQxVsT1c+Wa+iPKPQIt J/sNBxsuxi2a
Rppth+xzRtsfVnvIVvu/bA7orQ7/3BjGqR3pXouoGyDkGZ3EXi2urvZzyLZ5 UbhDYPCydkmj
niI9HP9bYiAaOcWq2YlHrogbw6OoNM29s5saI05VKxNMOX99i7nfLg2y+dzZ g5dda4v9IV1R
tQPH3YdkPmdssrAThZceOO6D427DKPfuEVOcfRf8FjPkczxwnrWYdFcb4SaP Iy/G8xFs1Vz/
+VZH6+XY1Eb4RfKYNCfuJKaJ3saWVUMqtfks8PF+ZBb0tlm9lpkzzdE6biql JU80VZNtlPZh
pulOkOVmOrYwo3h8uy0kD7GF8LyF9FiIryQljL65GFWZ6rbLwXGEn048iIoV e/P7rLjBouVH
9iIZ3fIV3l22jAS+Mq+pne3TdbYIeFldTwdcuYi39ADrrcsga4udrE03mpK3 Ui3Hculs1lcs
qixmcklgvVX6aIVVctehO9e8zodio4+wtY5Ne6ffPaP5eNLvlTaIQwx1e9Dw o2909Ojqv4Vl
XK0ceU6fYanmcq7cWIY5dWFnbAKqd8yVubmAIreBk3XsxrJgJlIZQt5POZTa YDGYdjrhUNZb
eDqYUG2YiDmIYuOiJh0mG+I0ozOgR2Xhm3Y2edpw3jZaQip6vEZbCcFYz3rQ zbquabvhHB5k
S7wyn7vSut1oHNfYfXb2/+MeIOsaoOMeZPtyoGodFOPWYGdzluoaXvxDXLZI zJfbI7bo9Y94
8JWN9R8N+SQZQ+prp9ikz0KGb5VjtogdQONaovoROQ7Mp6qLYtIRs5WA7f61 38Az9e1h3few
Ha1bBzmKAfuD/y+sdf/x2ElnjFQb+8NHiJxHiN4d4/e1cM77Aypt+GhW+G/6 1Aj4pCAfUCno
C+O8Y1ng8a2lPMNMG1+CXOqqE7wdR0VtZwNfYZyQ9UXN7j1C+2UH+FWqeaLb eyLXkqbXq8Wv
WrjL6p8POZk8Iyiib5HZXTGmG/JrdpbTg+Ok5sZenEyirGekMYko9oa/HaaN T+obXG+RFmpK
L/XBrhwnTf3tLAWLjbWSzyde3qgWJZhhz+JxF0V+JoBWj3Q7OynRJ9BJlsrf LRqBHcxVzXU7
3Y+t1SWEHQeXPhVMiHd+r1V0VU+TnOiyPAdh7Vep331m+DpEdetRPjm7HwnI HzW3yoVQrmI/
XI0/e6dsOE29VEZ6PPxzCOK/+fsDwEH+SJcj7AsGQ8IxarPH6w9FopDxAsqB DEUiISgCoSgc
icYSSQi4hkfhCwSjYchQeF8YyCRSoUjIA0sYDQaSEYx+MygbTGcjmQIRWDQd yKWKZWQFoimc
KZYqVWoVSNPhTkVypVz1oahcqdTiMGbzpTzYLRbjLSb7IylcauVbrc73J8ud aXZ6vX4gkGjc
6lc6CaFQZKpfzLSGXTy4dKncGY4mk2kMZitdGU5ms3kCYWg8mc4Wi2UKZard mS5Wq7UGo6k8
Wa42m60OpyvdWW52u/nLEK13We4Oh6MJZHRWAkJOp7NhVGm8OZ4ul00Zbmt1 AYOu8BjswmZU
LA/PExzjaWy9eB5KoxfrTK97IEOQCHj04nf4vkdAtRwpHsuKIhAVTumSTueH M/L8WKE4gdex
IJj61j7C8V5wOtC7XnAdwwv+F3qpCeI/26CIlCeCfwLAEEXH/v5GfDuUKK3m 3YgcSbfORiQH
s7OeLMQOCyTngGRipqd8E2WWFshMv5IbxXIbOpPI9M1OHKK8ZHRgIM66UhSl kTK8CUSSpt8P
/ENPXhCMQWO8QAVh9jA/zUHmXUcLfRidKDWsinQ3wU5kGS5JuQ3zJCYUISzX hwSXzCSF79DU
ICVOEPIgSxEEptQg+PcZeQ7ktWkmEAanfC8YGq/vFziKrP6iOJaPY9ICvg2A flFgf4pZjI6l
6nmFm6h5sV/DDy51Rj0F6P08KbEv/LLGnzWsPMZRRKO62A9Worog3Ny9Qg1H q68fCEErLhDi
pANOIWDeOfysakulgy5nUTJNsTnjaqOmgON15Fbi2YjapCefdHyuaxWxhKYr 8c9macbT6ZmV
HgmKhVysmjA1nQONUj0fFE1VX+DImWkkRR3/8VhVh0iNFtNkTnHGZTf2LHjN 1MBhZmGcVetF
0USzNabBjOKzm0M5YrLQ3YA8RfRjE103/dcFuqZ5P3iiRwmrqVtAy9KpCdtX x2YR+ObGtsbj
8sd2Zqdt2k7psi+7mVHajYeV2LZrR22pUU3W1Xl6FggEhmm8AASGcTjIZXHd kn25P9cwAr8/
8FtYtb+XzDSNKoRFGmOFi8smosqFxvpLZxHKVdtlhEhPcnvleearBFfvY5Vv KgVZtvo+Nlpn
oMv+VedtnySUzr3b5lvn5SjCbuf9tCBO9+O8onbn47J+Vvfzuv125/O2/6/e 14WLnNXX47wc
3+vp2uovq+f9OD3flYbHGa67nbCJt3cNCCcJoIJQfc6wLO9T/V/fp8cemPlY ftgjef8TleQC
klrBUSqZgTNDgYkrOovvd70V2JW+sj546gov7WtJjL6ge4AxzRJKpPIQIXp/ uIIzjObmV2lj
Fj7A3PFzz4Z5THDF3p76J0rN44OUGedmzmzIU+dX439nPoeMtDEjEDlzKZmv trvCQE+KEIYv
jYEWnjLc83zxhPcJWYRmTlVb2OBPgmG9SLNtiAU3kVHygGjUubmCYDJ2N9B8 sOmcKn44UQkT
ZLACAgLgNICtUiGbUqnSLOnXwZkzlaouNsMCZTcTidpjekQd/l1mG0xMhE9n UpHcNW5tB1NC
8PudyUtDKroZDLv044VOVpHWOt4InfBnYCxUJ9oADCytbcyE1jlHWLfPcIWW CbPelFYqrNlw
x2SqVHwWaiHY+yiNprNlgru5QdNZqwAKnJUNUaExXmPTlLk1fFyrYVF39Ql2 a2G8yTvwLgRr
L32Un5QRjdzerFDZkG6dlJWi1DGXc0oayFoiLhliEG9+coQqqMExY9jBmPv7 KIuTal1e2RUl
l1X5bPoXZgvMBk3BpyAFKssvlgqBaku1KgIprYupxIPruPsPVPpT0PnG6wcz 0uuC1bYWKofc
xGIclopxfs4611LGaFiWEny78EUZ3pS8V2MLpPGIpj64Gvswqa0D/FVqzobi OFmLwwLyMORJ
KAS9zMsJKKsGUWGHMwO9fis8FkvG6fvyuOLF82vXNjnuh2WXGJ59XZU0MT1e +WBU5f0rXhW5
2uCZhGMtGNXwPz1FIKj+JSw24gqbPF6x4qzx79FWctha6zOpLc3N1zYOWVrb N6mt3c/XdgHY
W/seL40DLDcOwNPR7BcOsagxlxunWjW+my06bpFoeWsJrqErQfQmmOeaVmj1 vM8jMz4JJINh
+qUVcMZ7m3/MV5dnldiRG8fMBTTRkIjOxEiC8Q1dVwl98C3bDRaJuYBnXFi1 JUKoLnOH4SkD
7tuTfkFWeFuRgxh/8K/0SzSGQF5BQ1U+j1aiiceI2n1F716vasrUc2kLTaXb AXdGTJ/5Ismu
cqa0D01zD+gej+dVwrQjUQ7PtjrRbQbfhMAdvE6X2iFtanaitwUcVXcbwmdC axQPFAPCl75i
RtRK5WFKmsiF/FLsShYu60PZUGTT2q4LVikKI6NtdfVcZyYWn2dTafip/Kti k8y/wA8A7ytj
SNYmY6oLFAGZE2rpPpZa+0xJ4JdM46xETCXzXxQTzh/2wVeSCtYIT+qWGmvT FEqkkdzgC2DJ
VXZRT5Xy8cUoHxdUAYJrnZtMtTnoKnrZ59IlHm6loZ/rlREBdkZAr/K5QNDa bJarGYfA+3m4
6lMvfnZGfHKwQASv0zL28gVSFuVl1/GrScsNudwmRZ8s5GOVQBGjtAlncyZr uokrxIrYYPWc
5iHSRjZiZXcGWnVlIU0JlI5Wfx/ccs6Op79QCKnQfYxK8Uf8wbGrzBA6mmqM Bb99MBPOAcpp
alOgbUKN7q2WxQu+MNyLY8H8sY6JSL6eWIu5rwqj/uYnUIL9oKv+FrfdsPac YBT6u/5i2+7Y
3PcJZXV1tagR1+yvtPZOyYtX0fHN8rzZ7nX1S2lpgI2OW4xLfVzOlQnb5/p8 rmtzbc61jdvn
5n4PxgEr241L66dFcqf263bOrU9ZHkQTk87N3mxH96BtE1ObbS9626Xhcp/3 UFTfQ+RXl+ju
3Ph7lNlrqcM4LWDaG3txG9a27Y7L7sUgmZeGFDnzTBPqzm7lfPSVXfE3heQd 7Pn3EqTUVjnS
iQG1CvxndwRvebEZTD7MkLQpn7aJKS9LDapdBjJdd5Wm5j2qztbWyeDDxEnN vUFKSctZ0MsY
/enXFXPVMf6u15heSpEQV/EEEF9ItQEzTb/RScdO0Szl85D0PpkWtsf/Ki0/ 1r+LOnEgOjGZ
zrayOspxPPwDOgUi1uprejr7zwys7MyOxcjN9PrDFegrYMa8IrMPquQX7fdI aJoywomzbA+S
zQ8o7S7rzHwixQIpzaI9wOTF5nUJGlQMenqkljLYcomYcrZDcJ5w+J3QfmaC QkGTZkVXJscV
7l3UckY/5jX7rCSU4sr8dx49FVTWTV8oXH60TX68DGT77IF7PNj91WcgXBbG zY+2pCqABqoe
LhrUKrBLZsJ2eumuFowK+sCxsjLfOlLZko2+xnRn+v4gphRA+uoZY+AcOzJH A+5iuq4btf9r
Bp4OaAIaZpHMST8BvN77sK/Mj0BQgQajcFj0LE8JtGdEcpiPhC7lrAHww1dr F0I2Tx0p3n6p
/4WerfqYGawJtnjuiwdqzgYgRU2ny38Lwkp506IXyTvOxNVvTfQm2v5KqEen mWRTnlZqAfx6
Nr0ptQUZHL1Ao8MNG3pruQmbYhA2rFU7UMA9r8e7vse7Z/j37PDvvf7f9/0/ EEecElp8qAZ8
OeHbzKAbWEeCd4WODqO7ysnFcnh/XQaGrQSConJontkPvFn/EaqAKapuwsuT lckBZ4fl6PLj
LgWMSQeptYQ3zriPD6lAT4YTctg+6Bj2k4T7IbguS7pQlOh+S/FUx4lPYMvf Z9KrclLJt7dC
QhNHomepH0nYdTzYInOxzAb55/SFN1M52NHg4bqzYUqKkaPz+LfaAkHqL95R irKD2IszQVPa
WByTxgsoODvb8S1HILVcTNf5+Nrcun/cyAfdTwc5govir5wEWpvCSXyoKVKL KWoLClx7LXJz
KDqGOc06Ner4IXp6G+a7/bdqzBzL1KcrZIuSBV8EBD/KJN06KKeFtJE/L5qL 2y/2EAlQC6nn
sH9tGKls/5ZZbNhakO3LbzBWM91Sv9TIQCUh72teQMXZOxfTnxU/dLLao6Yk Qr9Gw9gMwgRc
Y3Qm0WgZGYXT5MdW33PGs2XUkis1wpUlkbCRAOFhkpDP6TVO6rgqYuDXk+bf 5De+EFaVGysA
iyNAxUX4ejbDejqZ+jysBEu8ee7D0tc2G7hnGRiG+apwJ+TLRfpJWIgqAJhY ghO+JAUHNKpY
43Z0IioFPH/MIb+RPB9bDRrfDYB8Vl428VS9rOFJkarZoSbXMSicYZ6QjFau pnbPMikQvsE7
9gjN6Zj9PEzzlnTZvqEBEaMd0XUHga1n/vwPgjLnZKPmgkDrDWUfMtG4c2Tf k2dbDdm7MHtJ
nMzkk8w+s+yxs+x5k+z1k+w9s9xzE9OYg9x30/WDbTvKgxzUcxtOYgfEsvQy s++IswJJscI2
/DBzQx7+rf+YVAAA6EyXMo/R3CBKRk5Cghq+pSRtoDgIG0f9p2qf3I40o5y4 k8JlBUrxVZSr
XUYFd/bF2Lzf/M/f2nhytfkc4eSBpgvCTvs3cRe6Jlnp+kViK+oB/ov3UqTh 8OUhxoVHY1SW
mtrhhj8jwaIzzEt7cwuVHSpy2jVfO4ziflOYSddKGEJj7rDPkYDqJRVa1Hvg 1yPduzy9FLII
ib2yGtHkkSLDvDnO3zmGYerisQeHiURGnzsBsmSbmmaNFLhfTM67gg48TtZo 4A51oSlCfHUh
qSl6TgjTqkrHoMYSNpCIZosrzDNkFghsJNe4bo8ZrvI8XvH8z7MybH948xr/ xDUuS1anAiWv
YUTmJbMfRX2Wl1FS6Dnq2OSYeRdjlsybWdqYDgfm0oEVa2CR+UuOBmwrbGkt 0DTw9+ENewjJ
pmeLhXdHG030PJ9KqHnPsEUrBj0vFlTzP9nQUjIoVWgOh2jOOzjOoMgvC7SP m94TSDTKr6Iv
vFwMc9KNE8wzlESNagJLKHRy05IoKHIo75qIDs+qTu8trD5IotOUR5JiWFlN R+UoYhHSYshJ
YmSoWb7Jx8a0OhzL4lFNqBko4+43WEroJgVJWNX3EkXMwNInDjv0R8Hm5gEE MvCVL7AFKaln
6UZIXJhnz80Hkio3TZvnAmc0tF50r2E37/FW7+lX73k2n2U3oM/6KvNHk8++ Wgtosw8Si+/1
qhc8KuFlq9j3M84+wiAhq2IFnb8UURc1KrFaCqmYopKYOAqbnHvnPP9nq2aK XWfis7pMrVgK
27vtqxuqOmQZ2vyCswdZGycCtVpIohqUGwLJ/OuWqHpMqH/WgvqoY6hcM32q i6afiiPUsQYd
GRNiQmCnZKgYkdag4ifGnFWvSzwnGvMoy9/bcW2FmVH5OuAKajc1DE4cs+71 snv12vgVhXG9
00TP9E+spboqCsPvVB3I1Eho1UR4VxBItmPzVAMONe1/KDFM9aKkaBWUrnxO V4WydZtv7vRC
d8xi8sarjyjXbcb/TITW47yMijASgHUiLCus/2QyDFXZlNB4qNh2fRett+lk dpPYI+IdeqGg
uyOYRV4SPTA4PO65YlQ5q2GBC05OAbUWZJSBQWummbKNtOtkjanc0/T2TvTM 22jWP3MmHzZM
ofS8TE+kCytQWph2yDMTgiiUw+krmfEhLpFgQc9PLU5217U2Pg922E1k4K8R am1Iy3eROWsZ
LPU2R06bOLEatK+Zne0n4gl8NOgZiw1ZAmnRgyz/GVQZskPXxN55nFJUBr3X XFkiydpF4zng
ANojKCH8+g+kUWykRnxwOPNxrsNYQ/UYBhUWEdZZNoqkzApLt3sQQ4dkimii iHqq3vV5G/NF
MXrQbv0F0P3D9/spsD4sGXVZTMhdJg6rPMWzIqOjIuejooCzssSzcvjUp+Kj ssjMd93Mr76j
6vD33ZWYn1RtGcWDpqx00WlY8DwWOyfjAy0LMd+aSlxaNzfL6V6KXz0guDlt 9UUzOyTe7XsD
nSrO5dqzJmKDrket2uKvWpCjWlZzTkYMAof7EGxGzXFUaBi5l93b28Zig1NL iE+6o5+LGcum
psUtVb2dltUb9+WaUX9zBIzyfrrkaOqFtlVrZPdbxO4fuizr2Kb7z2g3dd2P MJYU8yCSaC4v
fp3/Ulw+jWpdhEYx5vLWI+mDE+98ck8dBM46VuVWDh/ASNRoP3slOWvEBLMI ZP9es2KrE2ay
bNHJMJzOes1s+6vQiJCWkdCbZfQp08tUbAIVlJi2aYp9zcryDpHGDBcj2qeE bhbU2FEfYqZS
nSsHZ94/J6Qkk5K78i3bXnwFwcqH6TGIpgf3OOgmpwk13vtvKy0GO/2v5lpo O2z7S2T3c4oe
+5ANZhzLYnKBxiv/LPx8anwc9mC9Ped10lDedVdMNqB6vZlAq8Eueg/to3dc owAZRTr9d46N
ZA5DUg66bcHOOu0hxyiqW9fsi1YrZXdSRgXjSuY1hwWZrVAjR8Lj+gJYxzjI nEVYF5/S1ozC
1gRHTYEUOjrRRpCNsiSXu6MmVhGJWbVXWuI8KngYUFnN0U13U0v/G4HMDdFE Bb1ExAzr2sVd
A+sAFrfULlnFwBMj5rO01ZkByhzfL9Mz7GO525MgBEvGAqtW5PCynNXbrHvV 53s1gGctxGct
onsNbqEyhmc9SaiqQGg9x2e9X/Ouh4iwd0lhOWweGWozQap+uE6Rz/FBVo2Y Kz1AaizgESZQ
RTGwUSpUgt1Viot026eGrOshGU1VrxbGImUzJqLewY48RrtJYFM/kTHtXinQ pm2aNesrUSss
LW6kwKWh4PYxuI0qBqq5WYWaKj2n2yviFqeFYSURg4fOKZnOIQvo3Pntvtm6 fNbKtxl7Jp4a
0ilrqZHw2BUt8lTJmasJ5PDsWMfw3G5jaMRmTFI3mEfW7ds0WIU1RORN2W+Z okGrNNRytOIa
FGgVem/sSfnsOd06e896120UMnRKVGN1LurK023pM2lJ0urMe2ZK/qmdgefq cOkyU8hIMeAw
v1epCNYW7EfNUdzONm+Ptmk3FdscEskeNiuyRL23HHWAbW7hbv7KjWufROew k7E/n1SF9+iC
v3TqKfa9Re265WAaP3ZdOWOdDvsqPmnJcMmdBd+1KxLdWWj3enQ/I9icvNxy GM9qGsURar8g
l8PJSOEdU9oV3u9COcbJr744/+18wJnsWIAUiaSJptWVJ/6KZta0CIUrHsaF kXFViGk2P+kC
LDZYJQ9GKSbRKabgqaPeNqG3Kg5YXfxOdEfevuz0I5XarlvM8VDa9vDa6QcJ DO0LAIPB4g6n
LxgIgcVmbfrFUCgcDo8IWu5eXzgSg8Pl+fXGQCSWgC+VyR3BWDKRQq3V4Q3F VDqVwYyaqO3e
WDqTgwfyBjueVDpbwOGB9I3JXLFQIp3F6QPNUrlUoVyl2R3JUrVSrd3p+Q3N ClirN57M5Ili
rd5ott7s8IFhq9lqd77cyOFiqA3p9P78+IZhp1eCwYLG5u1SqzsYjsbmMpVu GwyFwyF16usj
YBgrRPtndtyF0SQynyuF3iWR2WQRFMzj/useJBgSFonbHI/GkbwfGN0B/vJy jU0Rs9sbhk6i
4f1quz+p8Nld3mH8VLkYwAWYiXd6CFiMgKED8nA/nGwNp81Ob13Mh87Y1KyI swv/QSIUnRvB
P2jp3xps/zyd/Wf/C3iq5wfpo7bnCNVilu8wOx2co7ymgm4geK6xqu9xhUiu H3DoYo4biP/C
theOitWMGJTTfYpggJ6sHwiFLuwvAEVyZmYQ1GWwpis75yBe6MVtmF4QJgTR rmLHh+VW4MYn
eGpszxtKTpL0SVBCnAhh6pEdpm7YXpJ4kmBmkqIKP7YZMnGdtpdZ1lxxnKiJ 174XwNmjYZig
XIBGksSVek4WRaO7xw9Opnz3C4I83x4UGOu6034cCIJlYZhvjfdekOVH6GEo /8t2Ij9b4ASK
oqTQVYMsPaXSw6xUHl6istR+4p0iJ61Hgji7JXDDMlXYFAsnp3LkPaNWZEHy qjiQ8ojwNzKz
vQA0pfQleY0isMK62KWmkspxE/eTPELYIsWs5TImDOB+zkNRUwOv62WZ3hGg StVVUtpZmGcB
ZKaoPjyhuqx2h8imjj/Z8LBvz9PopOs57ei0Fgiul+8HRa2rA4XBUoNhaGm8 sbSvuCnMvGwh
UUJ3rKFsmCwq//1ZVRZKZQVz3037umnZU7BD5Rjbmsh9V0tABTBLgyrzXp6B 3tV2GgJFfBmA
QRb+FoShaesDOkzFI3VTAMTdNk1bmH9nMS/gxbFbrmllRbc41R9I124Io3eR bpk+wtLXYoJ6
0bf6MnE775FJ/Xlb4Ph787SINfX/FOXGP3ve3vCQehpa+u6knFl8lNSPu1yc 16U66h4nZbnR
AjJubyY/Jkq94EkudkLxPmsvILDPrtEi/5BfeOWFdV76aO6Y3RmBZj61gXDe ViUVc5WuCmcZ
JLNL58jm+bzu+P1DDtkrerp2McEd/s5NjZv1/bzp/ev39TAr5/f9shvnB/y4 nfX7Af787fsF
TU+wnDT26294H5hrHH2Yhf4Kyp/+P5J3tAn10Sb0j31wGXaBgp6yH+zlQDTU ECvvag8Za1Ol
LEhSOV0AzPxD3++mh/cZp5WOqEn1h/6k8Log0nn4qo5HwROweZWfBcSnvsG0 53t5KxknTe8T
pbzPo7KgsY+sfcoSlr33P2ZgRinajuHIyTZ1YcSbhRDnoo2DIRVaPlxwGJ1I BbgrCN60gQnR
5sZFsIYKdsmKM6guK6PpOTSKdrD/0rFEB5ciqJxkChcyMpW5U+vtZSscia6m mOlAdZD0rbHX
R4HmVF0gMzL8lTB5GBWU5+2zoMGMKIUow+Q8FzFxfU7GDT3DIg3VcMIh3hLd Gxh03i4LRh04
uf7uKrV5AVTJKtZqs+Lr40kUMBk/iLgULGJDwDm4heSVpyLSXlExOO0+jblE tOaGxWyBl/Io
y2yke1HyMcvUOHt17tTHrgxpktJrlYUhU/prVLYmTAen6adV7sk/s4ob05H/ lEr70M5FWq8A
bpldZAdIbPWR//NXAJjDojdzKbXmx4KFYNJNz/PE9ggEHVYjwk5eMbpSB/FY XSJ1GbFI2bCZ
eys/QCGXGMeo4YiIRUAW+Wc+KUulBpyV1BbaqjJpW+H5Uwa+iIWUMtbCPkuS eqG11hx5+5w9
TUQq+3Gl1CWaeA8LSswAGCX69MRQK0KKlhPR/gHWa9uYTI3jT+XxfXjrOCoW XdYL1pnsslFH
Twt9UjMMAK37qV0CmCrhqlOU02LqzilsyJoQarPODMKlvo+4VF+osyNCYqng wbISsqZtAkIB
msyAZ++FD6i2mSTV+jXDVGYkoKfk7bW5B+3WNkRT4xAXtXVE6dY+ZVPjlAez fSaZRlYbcu1c
G6VzxFgXEDpv5NoLs/NbNZ4RfUr6b72adlXpUKWDsp37rNXCIK3875qAGGtz I+zs9NQmF+zC
QDBSIUYNxR696Cp4oyihmPA477b9o1vJy+phaIU+8aEUXi+tIZJS0xSs+L8+ V0QgX8o3turX
53t4lyMGkhcCjAS4XqjRuoyRz5Jm1larbWgrzCVrfQYRRAFy2PWcI+aiLB0J 77mjU4nrQPaa
9uhaTvCNLlwCx75IbRpSbA8N32qp3Nqse+O/HtVziu/uXx+kj+IfU+6CqMk8 yFkaGhNGddkL
rvObOp/qGuVC/21RzAJ+ohb0coLpmjGbq3nEVlWiXs1zXvFFVvLhJAUlgXLx oGWVVm+l+RAB
ynQeqjNbyMtuq6FVq57CVeY07Kp97KPGfGYqNKN7J1lRypwJHDbt308KRT7w qnNjZxaBKDmz
3OUEtitUc6dsEf2yFu0g1wYyxBFZZEisxUQsXE3SDutwW5ZslEaMEeYRUNSa P8VGSSo6UtD6
/KyIlF26VhuarqoSqRrbcSvnXRa4VKirTpvwso2uwqYHfFyfwGp9rkltGFPl TlEbSwWti/Du
ryWThpTinFTKviTnVsfGp0ZQPk0SuirT6sS25GPTsx6fVBWjQM0DqRm22T+5 jo04WwZ7X3gG
GKfsYxKxjqznl8xMZdY/iu+OOSK6MAFTN0ORM9yVVLp32Vi5ACRktubJba6U VhmVHtoksX8d
5ugwHcsR7xOGo56rIWSP1q81M9XdTi61aVogCy/dzrXXgcd4CnGVteunnfbb P/BvfTC+d8F0
Xft/496GqHzvo+289SsvdUalfB+s1mndWBA8Jqx8Hw0w7UzIgwTech3awtF8 IiVnPSCEPLcn
KQt8FNJ3c4tyeuNT7INBvoRALnlngDYUroWIgH2MLN9XAFvnJW2roJ+q1iTq S/Tuv459LjeM
SHw0BlQ9XsekT/pMclLmi2EM3j0YvduF9Se/5x7jlE9l62aUo1ev7MJ/j7ki gj1GCd2Xi8RS
KdNpqu+AhC9fY2W7aTQSGTGzG2ZLFTNbzVBb/WPnqiDS0VGLWQhl2BR7nRK7 HWUsJzQuazcX
sWVJTwgpn1QlvxW6WFbm1lAK0mUHi2CtGTBpwlVzOBU7MgjHZGel6qKAkVRT uD/MZC5KqqoO
v1NklFQ1Ygws95ACno3VqlRlayCszlGcWoJ9pMu5LAnF2lPdOlMdRtGsR8Gs d4fkBiEck0bo
ed3splzlgbqkevdIwSYpISju0h0jhvJpoRsrQetJCjsjCvuivj9iQZZGjjOp ttbsftLztosv
tqIodg4HXp3K1naN5ioYZieQFlqo9gFHQXfEypEMThxOAaxlIDBlymqP9qGp jCkkNtTk4Whs
wXTq8oqvIYToTrZGtkNojkbLnCRoMoHk9kD0oAxzu7eVyLj7CKl0y8JwJ49m J28S0hZTLgFI
g2wWA2M1C61UYkm3mGwjf6Mwth2CqGBhFzYMTU5RBR0xA30zboNXf8EwbkEz 7+FV9L+DmoLq
sTXPmvZsnr+Z3SpO42bYfH+Ewr5brGbLkPue46Aq4mHG4+HO4/9CJSBSJCBL ABNQM3TizRIw
KxJIDDy2UjywoRKxzz2OnxOgQhyLzdCvURM/MXzERPRInfUoivUaT2MSU7wZ kr3O3E1BxNnD
R5JkwJPB1hF5n+yuQOLGWvVQUpM5192cxZUe3vDkngwUnSPrx6I22LC2IJ3I 1MM2Bm3p0dx4
DCK6gnzZRSx0Hxy0l31W0fyqwpwDFf2EU8XETCkDxG1oxayAammJI6jaSKa6 aqaqLyZ/xjS5
JKzV1b2SSjRZONJxxZ3MQq0cyw2t0YKsFTM8yNFwzGNC3tPw081qh8wamgL9 W6SligI7i419
iqOOHqxsSuXNjzIP3qxZ2I2SRWXkS4OIRW2DMRxZgS5ZCOCMjYJShM+p9k8W zipOO4vUAFPZ
2hGtsiK/IQ4HliE3B/YwrTOUiHI6xrXMTUxrI3PmIiT5AdG4wFImc/MUA/YA uDeV5HRfpNYg
0WNT4wAbbbLcl/ck2/owbHDbgxeF+fXIW4oMKrWAd45knfLwB1ImDkK7hLbw cCi7hwpR1D9h
6RIBfGNKCil+CR4Zj+taIUrKKJSRxWv2pRjJNOaB+JYhaGW+aQ+RFwkOve/5 9xlZuiV+4JoF
iWe5XJUWjamiliw2NGKOnWsheJkZlJH24xx6k+VOXiReeqAxqqc54424e+o2 ISGuYeHhG38o
pSGz79OlFF5jdJ2FFTM1gPPhHDZlMhYf+moXGiCRoS2n6dfsMdEW9pZuwlBv AcRPrgfoyaDr
yFQU5Rjoqd9M8aTtJd5ieRAc5TEX5XHQFQmUFUmSFSmWFWmRFXYBCRkTFVmr CfBLFQWcHkRQ
nickuCAeWhAXUpUdCXIa2QrvibVhepRNyeOnMfTMgiClSSuscZqcSBQkfrbr qdmogFZKYZcL
Dc3kspwxjOgL2/DKsEW2FAJWEfK0XDIym010yTG2CGMLIQRClHLOZCMJ5xXL 1NYzQesnwE5H
wKCnJqASzSFCTLSFgALLXGnA76o4rW0sbZ3dX+WiJFDD1YuDbq28bMJZ0igs LxtJ4Sgzyk0C
6IhrGf45SpjJkQ5pRZF7LumFJuXbkhbtXkvxp6B8vLAVqpZhRK6fPcpWPZPV 0qAtI5Xlw1Rn
pUjJpYA3k3ZUI/jqLU3MPHo0o5iqMvtAWLbaVfbIzJJcPJoKyypbPStSUo5p 02oLKjSEJHTL
MuPAoqYgMPcGqhn+026BopjNUikPrLmAQXJ9Rf2LtWl7JA/XpVBJ3dFuzJeU QpkO2rf+jwx2
q6HDYv79U+sfqQI1jQhkqyBUthbat7o5MkBueHHcetSjSKGKUSEZJj2iWzT4 aRZ4WKsXUhFH
eX4Fe8aHZ2MDa45iVlWRRD6lVYA1uSX6K17GJsFpabT7cjH3q7480DNE8SN2 jNLAIKzEbDVN
+6NUxbX0oo3FEKuUgcWOzdTMqkNDN6xrqD+2ycy7m6os2qPhKLAMPEvS1VXZ B6s8BLockrLy
1KvyqJMvLNI0YqKH4hhwRtX7KNX7bNX7GtX7XtX7Odl731jxDdM39VwRjtgH DtAu9sQsrYyb
pdDe/Cy7dPGMu6js0cSqcRNs5EwSM+tmbddj10hGIg+Av6JAgU09uUw5gK7u 9cTnyMAVOx+Q
lEhS3TQy66wZhk5bwBJZ0kzhirRGFDPa7Egtfq+mOSmDCh245kI6isxZj6yx Em41f69U3zca
oBwwIah9FUv72mhAgGnkVJdueAlX2k8DYlKVbYu70mqmd3nWRX5wJzSl37uP mHUFd4K3IGe1
sWHlCkCnKFpLQIbXM+MYE/zJxNUK/IetoeUtRfQZxWfSEAwdlDTWStsp6xRI yTLWwqTe/B4Z
oNqexdaZO2KcmeIqw8UabBNmUChdBFppKbKZreDucqRqLped6aU5qKk+rMUl XcFSdGEYVXko
QVfiGlLkzeOdC3bcbGXeGIZtg6U5mZU9APBoh+lsQcMyxtpr2YVoTbUao+t0 rNzKGm5rn4vu
gPowjXtThMlsTmyqpiEpcB/vaC6dBq5ghlvlKqsr9o7lOr605ZMXCnG1w6O3 7ovHNkwV8rNP
5lCN5HEVFHQCxYqy0pq8HIKplIa+QlmyHPkjR5+jg7ivOp7aZ8fGWqQsOz1D OpXNYq0jJRbS
uyWhupQou/6zjM5EjJ5kiWs5QaHx1OGbWi2sM3mOhgFa93lbrFAOYEXK1MRt yXkj2a3Ndddq
wjszToQ6GbgYB8Hd64bOf7vZto7ZW7KyrAq3YkCzYiSzYmKzYhazYqGj/VO1 YtPN93tLx5Zm
9SOoryCt5xNDuzV6CKNgFYqj32fbo96zn5HCC0s7SdQH0D4xEG+R3n2RpGjT ru6zKmQ2qJy5
FoYbOpht4N+NovO9inNiwGHt0yY9N1DeZjzuq9Vu2C05dAiz7lWtL4mDK52d Sga0EY10X5y+
qIEYWddzGHbSqN28KpqixpJhzaJa2zR6GaH3zoMMH6EuHskeH0GsWjIzNHW2 bouS2grajLJh
Lg4wqOeQ0RzfRnVvqSciz4xv2wjPbozMVi0fk4rNbojvaqCBDtfbqh1nL5iB Zcvpisj7IijQ
VuHu9ObBHtYDa4rHXpi/CBa9zBbH5nGVKJamComOqvPPzvnTkZMgnRvkOnPN 1ul+ZsrJWQJj
RaiXtW3QORVknrPLPd2BO+3GPi16IbwCUFi7CgOBm+z36PjdUcs9M0rW2vqM S+17Ge7fGX4p
fZBH3vQrtjy9bfsFsC3UMwq+MhTfOZOYpUwyoXwfnQnEpuwEnz4Mlsive4vJ h1HDvsg01Jqn
lFRF0mECAe6AfMwriHSMqR4LqZwS7BzNTxQTX0d3XC5KhS2VsqjT2DgTcHfN dMbkGI2wxFBM
XPootQxMd3byVGkMsXVPRLY5WALggtZ6pAYcl7unXkc1dfoPrAZgqd1qeFYT KNdBI3KUcpwx
bMVbgBftNZedM5fdN5e98Ff9tFeo/SuDtldxIKshComjM1eOCqvQXxussAKt OCOVo6tJH+sL
anpBuF42nt7YOBenbjJRMVJr6cJFNT3XUAAx6msA/ICdxXor5Gj6snc8y+XW ZfKD2I42QUqh
TrW/8DxW9QmXqEolnB0AF+ir4T1w3rMsatEmNTVFszHSPF3TaGTfuZ0oYy7m KFF7ZlwbjnN8
8VL00876mbuQrDuit5G+Bcu1UqrRwSlhdHXOpbG9QK3henmIB5lVH3GEf9h4 ujjqNJFhLC0W
OFVPfKbwz28sKXvsBH0yjUvpQaaRWqw52TqNGttyPGI87ovtuyxLg/c4l3ru pa2j+GsuJ8O1
HKfQJ1ZBeDJb/i1bgmofh2fSfHdqtf12QyO3E+C9G9GcxnqwrZGbufXaby1v nHnw2HVQhh1W
eLJvjXkIjzzl6jLtc5Y3W92EpOeE8XFY10kveGML62N3PhUuSzeLCP22O/24 qtk2nm39JL35
GzjqUwcn5pV7tLTlWdR2nLx5DBZR+E9rA0XsdGvrHYrmiHFizvJ8rtn9o4m9 kRPrboNjgjhq
3sDWQkpKRV/PsqU2n1l32m8nWs5yc0omeB8+PTw3uCvylkGna4UmmM54sWvw LNBCgyvm3Fzy
dtY99lZ2aUlq6fgvArP5L3xye32BADAQDOV0+f2BIAQiRmH2+T3+SCQ626O1 +UOxeAIRUWpy
xAOhRCjcTGv2hWOpdAaTGTCL/hOZbFaLSucKh1O5fIEQeBPxRTKFYokUWpON pXOlcoUS2RLN
5cP5OPVq2+PM5kLpah063i9KNIr1OtPlGpPNlWutNofjmRKt1RudLqDH883x 5uqtXl8A+F9S
7bU7g6EIVDrTrbV7o7EEErlS7XU72Sk0aruTrfVHszkZGnN8nY2mk7kKlVrT bc2HM3hsVvv4
aZDfkEt8i7Zb1xvWt5UwAWHUl5vuWnmdYf/KGDaCIBH+8bv34fcL3VShaj1s 9eAWidztRPnp
ebhcud8eUcD4dWTzTB3RpUUtZfacjd1s9F6YVczz/dSzc0KVrIwNxLEdpDtZ NCEI4gsEI1YO
8oNdgVFPFMMwHUERwXJ11fLCshWf8T6PGVk0vrs61grXHWFD8yCJFcsJwfPB ypcgNBc58O/I
GtIOv/FLzrfO05L3gyHThv8KQpIsp6dCbgdG3XcW7VQhihFIPDlIUhR1PdSk 7hDddQEtcZim
Dlpw5NsahqzNpcHqiRu5OXen7KepaVASpOjcohnHkISE5eV/yr/qxX4pFSb2 Eug07oFCUrIX
BELS84OEIOdemUsJfS7di/51aJpVQqxqUpgRbb2IV+KvZk4a4e10RqUKFjS5 n2U3+nZchhss
TJnVk7p+nqU3on7qMkjSYVIZ+4OiPKNWYOLaTIiZnh8AoyhvoCXjpJK8zB43 rKLJowaNtgaz
nz25YiaR6bIaxGj5uCznZOKmpC7jvDJj8IltN2vcDSe/5XW7/agmeAzu3Kw6 Pbzc54r6ZM78
f1eYGhzaAt+vmnTsm3HShp3swNj3tA4Z2eXt1omWlgXcQjj0qWZDMI35xnPq txIhWVfkgmSa
6Q0ClICA/UANXo2DGFGv/RCoXN+CEDTtM/ZjHKeTpt1sGbR3K3k/iEYrFgOX 91OAArBhMcEG
qH6UYvWi3h0/XOI1UTzuomWWuCwLZ5G/acpZPG/qDxKKaRwPAoFp2LbR5y4l s6THfQ5GR4Tp
Vb2sMdVdU6XuwUK3aMI8Wbz+oElCZ6EcNnnztWlyDmTrWpXp3dyaGMzy1tt8 tHJ5KVKYuJeZ
88lTbZ5yXJge7s+RfH47KUrz9axQLQaK7CEnw9A0t/UCve4G0f28HybZfryB T4tqfj4vm24/
Pm+HaX6+H5dy1B7ZV6t+fsDef9PMv3Sr/X4T64Nw/M7aWDphBeWWl4NtYzrC gAucCdr5fd5A
7x0yyzGXAO8CIOLfDaBU2MIscJcc6fiZs9RNzdBQVB2i3pOe9BQEUfDxVBz4 frLlc2rQ3t0C
xxizsLOVisILwgEjgFIgl7tbwN4CXSUBQYTTsPTCjCx8EERlmSOfgoGO/pXK U3Mera9bmbZF
SFYEXQMuLmJU9BTpXExMUyEBi0KE2kve1oQwbVs2oYlVm96xRgDtVLyZM7fU 1PE2JKvDHayD
LxVWyWoz4/wViXYpi1avtU9tp/+IjXzbwoJPaJkIHDZKfsNDrZBQuVDMsNTf qHSvo3c0V/Z8
wsFkORp9KZ6MnYtc2bA3LefhJE6dmE/ZQkrtgEVLUh5j3thZe6O2r47McJWS HbOuKO+1h0/F
08z4YbYHsTKQ0trKzGf14xgh3WFwPu4w7qA+T22LeNAZKdaeEg+rMTAtI/5X aDwdnMaRJHCT
N6hNzMtkgec8QJXb/GTMg5mZFloSnPU7ZW+P3JQh2iLaSBB2lbbgXfgf72PB P1zsXXp1cqaR
SbXuLbLZDjR57h5meUQXQ16yMYm4EuZSF5QKlPZgqapfNRHMzyeLhS/MlRo2 ES8NFORsFMzp
B8k2/Vt46/nss+oZ82U9QG5c0jxKdt2JylI4khQP2eGWzWvFAvwYSg0uyaHE 2OV0fXC9ffi0
tmGWG4dPxpUjlNAOxJVY/cTsE+j+oSk7qBfrrqrt1YffIhGaiW6R3gARz7IO FyRV1x5KIzOJ
D6Htc3uNdhiDv8/gS/mKyQ1jzLkU92VJ1Jx1frNasJY07pugDvW+t0dnWl2Q /7q/0FoHSWwd
Yry0j0jV2idNbJ1yPrXPRNU6FktodXRhNi9M1ToXvv/9khIavQ5V64IQ3rNG Cc+
Re: Help, WTP not working as expected [message #165780 is a reply to message #165646] |
Mon, 03 April 2006 22:07 |
Marc Adams Messages: 15 Registered: July 2009 |
Giorgio wrote:
> Hi Marc
> the issue.
>> Configuration and see that you have the EMF, GEF, JEM and WTP plugins.
> process.
> have problems.
> Giorgio
Well, if you don't want to wipe out your eclipse setup, you should try
and disable the EMF plugin that shows an error in your configuration.
You are getting it via the external location anyway.
You could always get the eclipse platform with EMF, GEF, JEM and WST
here: (the All In One version)
http://download.eclipse.org/webtools/downloads/drops/R-1.0.1 -200602171228/
Re: Help, WTP not working as expected [message #165804 is a reply to message #165780] |
Tue, 04 April 2006 02:49 |
Originally posted by: giorgioclavelli.optusnet.com.au
Marc,
Thanks for your advice Mark. I'm downloading it right now.
Considering I don't have any constraints to wipe out my eclipse
installation.
I hoped I may have had came across a sort of known 'common' problem and
to find here some sort of already tested solution for it.
Mmoreover, I'm not sure yet how to disable/un-install the WPT plugin, or
part of it.
So, I've the feeling I wold be better to go for a 'clean'
re-installation of the whole eclipse thing.
Thanks again.
Giorgio
Re: Help, WTP not working as expected [message #167459 is a reply to message #165554] |
Tue, 25 April 2006 06:43 |
Giorgio wrote:
>>> I'have just installed WTP, which looks promising, and got this
>>> message when I was trying create a static html page.
>>> "Unable to create this part due to an internal error. Reason for the
>>> failure: The editor class could not be instantiated. This usually
>>> indicates that the editor's class name was mistyped in plugin.xml."
>> If you go back to that file and check the context menu's Open With
>> submenu, which editor was it trying to open?
> I get that message every time I try to open (or to create) a html, css,
> file using the html editor from the context menu in the package
> explorer window.
> I can create javascript files, but it is the JSEclipse plug in that is
> stepping in, I guess.
> I can create a "Web Static Project" by both "File > New > Other" and
> from the context menu in the Package Explorer.
> My impression is that that something is missing. However, I have no clue
> what it may be, due it to the fact I'm new to Eclipse too and I'm not
> sure what to look for. I repeat that I can create and work with SE java
> projects without problems, even with the JSEclipse (javascript plug in).
Are there any other editors shown in the Open With menu? You might
be running into an incompatibility between JSEclipse and WTP.
- Nitin
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Current Time: Fri Apr 26 04:31:29 GMT 2024
Powered by FUDForum. Page generated in 0.04169 seconds
